Windows 7: Drive - Rename
Drive - Rename
How to Rename a Drive in Vista, Windows 7, and Windows 8
Published by Brink
24 Feb 2010
information   Information
This tutorial will show you how to rename a drive in Vista, Windows 7, and Windows 8. For example, a hard disk drive, USB flash drive, CD/DVD drive, etc...
Tip   Tip
If the drive name is missing or was changed and you did not do it with the methods below, then look for a hidden (not always hidden though) autorun.inf file (OPTION TWO below) when you open the drive letter in Computer, then right click on the autorun.inf file, and click on Delete. Next, approve the deletion.
warning   Warning
You must be logged in as an administrator to be able to do rename a drive.
CONTENTS:
EXAMPLE: Rename a Hard Disk Drive
EXAMPLE: Rename a DVD Drive
NOTE: Devices with Removable Storage, such as a DVD drive, can only be renamed by adding a label at the end of the drive description using OPTION THREE below. These devices do not have a Rename option in the context menu when you right click on them in Computer or Disk Management.
Drive - Rename OPTION ONE Drive - Rename
Rename a Drive in the "Computer" Window
NOTE: For Devices with Removable Storage, such as a DVD drive, that do not have a Rename option, you could use OPTION THREE below instead.
1. If you did OPTION TWO below previously, then you will need to either remove the label=new drive name entry from the autorun.inf file, or delete the autorun.inf file in the root of the drive that you want to change the name of.
2. Open the Computer window.
3. Select the drive you want to rename to highlight it, right click on it, and click/tap on Rename. (see screenshot below)
4. Type in a name you want for the drive, then press enter. (see screenshots below)
5. Click/tap on Continue. (see screenshot below)
6. If prompted by UAC, then click/tap on Yes (Windows 7/8) or Continue (Vista).
7. The selected drive is now renamed.
Drive - Rename OPTION TWO Drive - Rename
Change a Drive Name using an "autorun.inf" File
NOTE: While this option can be used for any drive, it is really useful for external drives like a USB flash drive.
1. Set your known file extensions to no longer be hidden.
NOTE: This way you will be able to rename the file extension in step 3 below.
2. Connect and/or open the drive that you want to change the name of.
3. In the root of the drive, right click or press and hold on an empty space, click/tap on New and Text Document, then rename this file autorun.inf and press Enter. (see screenshots below)
NOTE: If you already have an autorun.inf file in the root of this drive, then skip this step and proceed to step 4 or 5.
4. If this is a New autorun.inf File
A) Open the autorun.inf file, then type each line below followed by pressing enter. (see screenshot below)
NOTE: Substitute new drive name (ex: My USB Drive) with the actual name you want to use for the drive.
[autorun]
label="new drive name"
B) Click on File (menu bar) and Save, then close the autorun.inf file. (see screenshot above)
5. If you already have a autorun.inf File
A) Open the autorun.inf file, then add or change the label= line below. (see screenshots below)
[autorun]
B) Click on File (menu bar) and Save, then close the autorun.inf file. (see screenshots above)
7. If this is for an Internal or eSATA Dive
A) Restart the computer to apply.
8. If this is for an External Dive
A) Unplug and plug in the drive to apply.
9. Open the Computer window to see the changes.
Note   Note
To Restore the Default Name
You would just need to either option below and repeat steps 7 to 9.
  • Delete the autorun.inf and .ico file.
OR
  • Remove the label= line and save the changes if you have other lines (ex: icon=) you wish to continue using.
Drive - Rename OPTION THREE Drive - Rename
Rename a Drive Through Registry Editor
1. If you did OPTION TWO above previously, then you will need to either remove the label=new drive name entry from the autorun.inf file, or delete the autorun.inf file in the root of the drive that you want to change the name of.
2. Press the Windows + R keys to open the Run dialog, type regedit, and press enter.
3. If prompted by UAC, then click/tap on Yes (Windows 7/8) or Continue (Vista).
4. In regedit, navigate to the location below. (see screenshot below)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer
5. In the left pane, right click on Explorer, and click/tap on New and Key. Type DriveIcons and press enter.
NOTE: If you already have the DriveIcons key under Explorer, then go to step 6. (see screenshot above and below)
6. In the left pane, right click on DriveIcons and click/tap on New and Key. Type the drive letter (ex: D ) that you want to change the icon for and press enter.
NOTE: If you already have the drive letter (ex: D ) key under DriveIcons, then go to step 7. (see screenshot above and below)
7. In the left pane, right click on the drive letter (ex: D ), and click/tap on New and Key. Type DefaultLabel and press enter.
NOTE: If you already have the DefaultLabel key under the drive letter (ex: D ), then go to step 8 or 9. (see screenshot above and below)
8. To Rename the Drive
A) In the right pane of DefaultLabel, double click/tap on (Default) to modify it. (see screenshot below step 7)
B) Type in the new name (HDD) or label (DVD) you want for the drive, and click/tap on OK. (see screenshot below)
C) The registry should now look similar to this. (see screenshot below)
D) Go to step 10.
9. To Restore the Default Drive Name
A) Right click on the drive letter (ex: D ) from step 5 above that you want to restore, and click/tap on Delete and Yes. (see screenshot below step 6)
10. Close regedit.
11. The changes should be immediate, but in some cases you may need to restart the computer to apply the changes.
Drive - Rename OPTION FOUR Drive - Rename
Rename a Drive Through Disk Management
2. Do step 3, 4, or 5 below for what you would like to do.
3. In Vista and Windows 7, open the Start Menu, right click on the Computer button (dark right side), click on Manage, and go to step 6 below.
4. In Windows 8, open the Power Users Tasks menu, click/tap on Disk Management, and go to step 6 below.
5. Press the Windows + R keys to open the Run dialog, type either compmgmt.msc OR diskmgmt.msc, press Enter, and go to step 6 below.
7. In the left pane of Computer Management, click/tap on Disk Management under Storage. (see screenshots below)
8. In the middle pane, right click on the drive letter that you want to rename, and click/tap on Properties. (see screenshot below)
9. Under the General tab, type in the new name that you would like, and click/tap on OK. (see screenshot below)
10. When finished, you can close the Computer Management or Disk Management window.
Drive - Rename OPTION FIVE Drive - Rename
Rename a Drive using "Label" Command
NOTE: For Devices with Removable Storage, such as a DVD drive, that do not have a Rename option, you will need to use OPTION THREE above instead.
2. Open an elevated command prompt.
3. Do step 4 or 5 below for what you would like to do.
4. To Directly Change Drive Name
A) In the elevated command prompt, type the command below, press Enter, and go to step 6 below. (see screenshot below)
label DriveLetter: Name
For example: label C: Windows
Note   Note
Substitute DriveLetter in the command with the actual drive letter you want to rename.
Substitute Name in the command with the name/label you want to rename the drive with. Leave blank if you do not want a name/label.
5. To See Current Drive Name and Change
A) In the elevated command prompt, type the command below, and press Enter. (see screenshot below)
label DriveLetter:
Note   Note
B) You will see the current name/label of the drive. Type in the name/label you want to rename the drive with, press Enter, and go to step 6 below.
Note   Note
If you do not want a name/label for the drive, then leave this blank, and press Enter.
6. When finished, you can close the elevated command prompt if you like.
29 Dec 2010   #1
Brink
64-bit Windows 10 Pro
Updated to add OPTION ONE to change the drive name with a autorun.inf file.
16 Sep 2011   #2
Britton30
Microsoft MVP
Windows 7 Ultimate X64 SP1
Quote:
NOTE: For Devices with Removable Storage, such as a DVD drive, that do not have a Rename option, you will need to use OPTION TWO below instead.
Hello Shawn, the above is written under Option Two, should be Option three?
16 Sep 2011   #3
Brink
Oops. Thank you Gary. Fixed.
24 Oct 2012   #4
TheDookie
Windows 7 Ultimate
Thanks for this. Does the name have to be in "" like the text suggests? The screen-cap suggests otherwise...
24 Oct 2012   #5
Brink
Hello TheDookie, and welcome to Seven Forums.
No, the name doesn't have to be in quotes. It's just something that I like to add to make the code look neater. That's all.
03 Nov 2012   #6
mirecek1965
Windows 8 Pro with MC x64
Thanks, registry method worked fine for me on Win 8 Pro x64.
03 Nov 2012   #7
Brink
You're welcome Mirecek, and welcome to Seven Forums.
12 Apr 2013   #8
oreo27
Windows 7 Ultimate x64 Service Pack 1
Neat trick. Helped me out when trying to distinguish my new LiteOn iHAS124 drive. My old Asus drive is starting to fail so I got it. Anyone know if LiteOn is any good?
12 Apr 2013   #9
Brink
Hello oreo27,
I've had a few LiteOn drives, and I never had an issue with them.
 Drive - Rename
Cannot rename USB thumb-drive
I have a 8GB thumb drive, age unknown. In WinExp, Name:= Removable Disk In drive Properties, Name:= <empty, no name, an empty string> When I try to rename the drive "PKT2012" in either or the new name refuses to "stick" The "Properties" dialog "Name" field is always empty. Is the...
Hardware & Devices
How to rename my USB flash Drive
My USB flash drive appears under the most boring of titles: REMOVABLE DISK. Clicking on 'rename' has no effect. What do I need to do to give it a name?
Hardware & Devices
Rename a ext drive
I had a usb ext drive that I had used to clone my desktop, well when I went to use drive for something else, of course it was full..... well somehow after formating, shrinking partions etc...not even sure what I did..finally got an empty drve BUT with no drive letter and compter did not see it for...
Hardware & Devices
Tip: Rename Hard Drive
This is a little tip I learned many moons ago... Right click on your "C" drive and select properties (you can select rename instead) In the Name box give it a name. (Example: Win7-64) The point of naming your "C" drive? If you dual boot you will always know what is on that drive so...
General Discussion
Can't clone a new drive; can copy and rename drive letter work?
I recently bought a faster 2TB hard drive to replace my old 1TB 'games' hard drive. Unfortunately, the software that came with the drive (Seagate Disc Wizard) will not clone my 'games' hard drive onto the new hard drive. Every time I try the clone, the software tries to reboot the PC, thinking that...
Hardware & Devices
C: Drive renamed, cant rename it to anything else.
I recently had a virus on my computer and decided to just reinstall the OS from top as I didnt have anything vitally important anymore. My C: drive was renamed to "Alcatel PC Suite" which is the name of the software I have for my cell phone. When I right click to rename it, I can type a new name...
General Discussion
