Windows 7: Advanced Boot Options
How to Boot to the Advanced Boot Options in Windows 7
Published by Brink
23 Nov 2008
information   Information
This will show you how to boot into the Advanced Boot Options screen to select options to start Windows 7 in advanced troubleshooting modes.
Note   Note
Some options, such as safe mode, start Windows in a limited state, where only the bare essentials are started. If a problem does not reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes. Other options start Windows with advanced features intended for use by system administrators and IT professionals.
Here's How:
1. Turn on or restart the computer.
2. If you Multi Boot with more than One Operating System
A) At the Windows Boot Manager screen, select the OS you want to use the Advanced Boot Options for, then press F8. (see screenshot below)
NOTE: On some systems, pressing F5 may also work.
3. If you Only Boot with One Operating System (ex: Windows 7)
A) Press and keep tapping the F8 key about every second until you see the screenshot below.
NOTE: If the Windows startup logo appears, you will need to repeat steps 1 and 3 again. If you dual boot, then you will need to select the OS you want to use the Advanced Boot Option for and then press F8. On some systems, tapping F5 may also work.
4. Use the arrow keys to select an advanced option to start Windows 7 into and press Enter. (See screenshot above)
NOTE: See the table below for a description of each option.
Advanced Option Description
Repair Your Computer
Shows a list of system recovery options that you can use to repair startup problems, run diagnostics, or restore your system. If Repair your computer isn't listed as an option, then your computer doesn't include preinstalled recovery options, or your network administrator has turned them off. You could also boot from a retail Windows 7 installation disc to see the System Recovery Options.
Safe Mode
This starts Windows 7 with a minimal set of drivers and services.
Safe Mode with Networking
This starts Windows 7 in safe mode and includes the network drivers and services needed to access the Internet or other computers on your network.
Safe Mode with Command Prompt
This starts Windows 7 in safe mode with a command prompt window instead of the usual Windows interface. To exit from here, press Ctrl+Alt+Delete or type Exit and press Enter.
Enable Boot Logging
Creates a file named ntbtlog.txt, that lists all the drivers that are installed during startup and that might be useful for advanced troubleshooting.
Enable Low Resolution Video (640 X 480)
Starts Windows 7 using your current video driver and using low resolution and refresh rate settings. You can use this mode to reset your display settings, or to use a television monitor with your computer if needed.
Last Know Good Configuration (advanced)
Starts Windows 7 with the most recent registry and driver configurations that worked successfully. Every time you turn your computer off and Windows 7 shuts down successfully, important system settings are saved in the registry. You can use those settings to start your computer if a problem occurs. For example, if a new driver for your video card is causing problems, or an incorrect registry setting is preventing Windows 7 from starting correctly, you can restart your computer using Last Known Good Configuration.
Directory Services Restore Mode
Starts Windows 7 domain controller running Active Directory so that the directory service can be restored. This option is intended for IT professionals and administrators.
Debugging Mode
Starts Windows 7 in an advanced troubleshooting mode intended for IT professionals and system administrators.
Disable Automatic Restart on System Failure
Prevents Windows 7 from automatically restarting if an error causes Windows 7 to fail. Choose this option only if Windows 7 is stuck in a loop where Windows 7 fails, attempts to restart, and fails again repeatedly.
Disable Driver Signature Enforcement
Allows drivers containing improper signatures to be temporarily installed.
Start Windows Normally
Starts Windows 7 in its normal mode to the logon screen or user desktop. This can be helpful after a improper shutdown.
28 Dec 2009   #1
marsmimar
I'm familiar with F8 option to get into Advanced Boot Options. My previous laptop was running XP Pro 32-bit and I used ABO often. Purchased new laptop running Win 7 Pro 32-bit but F8 option doesn't seem to work. When clicking F8 a black screen quickly flashes and comp continues to welcome screen. The black screen has nothing to do with ABOs. It seems to have info regarding kernels and other obscure (to me) system info. Unable to get screen shot or even take picture with digital camera. Screen flashes by much too fast. :-( Does this sound like an OS problem or a computer problem?
28 Dec 2009   #2
Brink
64-bit Windows 10 Pro
Hello Marsmimar, and welcome to Seven Forums.
Not sure why you are not seeing it. According to the "STEP 3" section in the link below at Dell, you should be able to keep tapping F8 during boot to enter the ABO screen.
Dell - Technical Support
29 Dec 2009   #3
marsmimar
Thank you for the quick reply. I feel a little foolish.
Accessing the Advanced Boot Options in Windows 7 is slightly different than what I was used to in XP. On my old machine all I had to do was click F8 once and the ABO menu would eventually appear. The secret to accessing ABO with Win 7 (at least on my new machine) is to continue clicking F8 until the clicking produces a beeping sound. Each beep seems to equal about one second that the mysterious black screen will remain visible. When that black screen disappears the ABO menu appears.
I also found out through trial and error (mostly error) that clicking the F5 key during startup also allows access to the ABO as well as a couple of other options.
Thanks for all the great info on this site!
29 Dec 2009   #4
Brink
You're welcome Marsmimar. I'm happy to hear that you got it sorted out. Thanks for the F5 tip.
29 Jan 2010   #5
RJ12
How come this guide references Vista instead of 7 a lot
Try searching in your browser (ctrl+f) and type vista to see what Im talking about
Great Guide though!!
29 Jan 2010   #6
Brink
Hello RJ,
Whatever do you mean?
30 Jan 2010   #7
RJ12
I think I saw misprints. Maybe it was my brain thinking that vista should have these but here is one thats real
Quote:
3. Use the arrow keys to select an advanced option to start Vista into and press Enter.
30 Jan 2010   #8
Brink
LOL, no you weren't imaging things. It was copied over from our Vista Forums and updated for Windows 7, but I missed a few Vistas in there. Thank you for letting me know about them.
28 Jun 2010   #9
Crump
Microsoft Windows
Hi no matter what option i choose, it will not boot or progress to anything, the 'repair your computer' goes to a blank screen and does nothing. safe mode starts loading files, stops then restarts, so i am now back to square 1. what can i possibly do to get it to boot. it is really new and i dont have any files on it so i wouldnt mind if i lost them. can i somehow re-install windows 7? it didnt come with the installation CD though and it was pre-installed.
f8 advanced boot options freezes
Hi everyone , I am a new member of this forum and this is my 1st post so please bear with me on this one i bought new desktop computer with windows 7 professional sp1 64bit HP elite 8200 sff - i5- 2400 ghz 4 gb ram 500 hdd intel hd graphic everything works oky except ( f8 advanced boot...
Installation & Setup
Advanced Boot Options not showing up
Hello forum. I am having some problems with my PC. First off, I'm having a problem with the new ATI catalyst drivers and games. I get a lot of artifacts in the games such as MW3 and I've tried everything from uninstalling to searching the registry for entries about ATI and AMD. Thats not why...
BOOT Advanced Options
So does altering anything in the BOOT Advanced Options allow for quicker boot times? In terms of Porcessors used and RAM allocated? Just wondering.
Performance & Maintenance
After looking at this thread, I went to the options and noticed that the Number of Processes checkbox was unchecked and the drop down list was grayed out. I have an E6750 CPU, so it's a Duo Core 2, thus has 2 processors. What effect on my computer/booting would checking this box have and...
Edit Advanced Boot Options
Hello everyone, This is my first post on this forum, so forgive me if this is not the correct board or I do something incorrectly. Now then, I have a computer that was on vista that I just upgraded to Windows 7 Ultimate 32 bit. When it was on vista and you went to the advance boot options...
Advanced Boot Options has been coming up on its own everytime I have started my computer up. It first started doing this when I was running Vista 32bit then 64bit and has followed me onto Windows 7 64bit. How do I go about disabling it? Thanks in advance.
General Discussion
