How to Create a Text to Speech Shortcut in Windows 7
This will show you how to create or download a
Text to Speech shortcut that opens to this tab in the
Speech Properties window. You can also
Pin to Taskbar or
Pin to Start Menu this shortcut, or move where you like in Windows 7 for easy use.
The following table describes the text-to-speech options on the Text to Speech tab.
EXAMPLE: Text to Speech
OPTION ONE
Download the Shortcut
1. Click on the download button below to download the file below.
Text_to_Speech.zip
2. Click on Save, and save the .zip file to the desktop.
3. Open the .zip file and extract the Text to Speech shortcut to the desktop
4. Right click on the
Text to Speech shortcut, and click on
Properties,
General tab, and on the
Unblock button. (See screenshot below)
5. Move the shortcut to where you like for easy use.
6. When done, you can delete the downloaded .zip file on the desktop if you like, or save it to use again.
OPTION TWO
Manually Create the Shortcut
1. Right click on a empty area on desktop, and click on
New and
Shortcut.
2. Type the location below into the location area, and click on the
Next button. (See screenshot below)
%WinDir%\explorer.exe shell:::{D17D1D6D-CC3F-4815-8FE3-607E7D5D10B3}
OR
%WinDir%\System32\rundll32.exe shell32.dll,Control_RunDLL %SystemRoot%\System32\Speech\SpeechUX\sapi.cpl,,1
3. Type
Text to Speech for the name, and click on the
Finish button. (See screenshot below)
4. Right click on the new
Text to Speech shortcut on the Desktop and click on
Properties.
5. Click on the
Shortcut tab, then click on the
Change Icon button. (See screenshot below)
6. In the line under "Look for icons in this file", type the location below and press
Enter. (See screenshot below)
7. Select the icon highlighted in blue above and click on
OK. (See screenshot above)
NOTE: You can use any icon that you would like instead though.
8. Click on
OK. (See screenshot below)
9. Move the shortcut to where you like for easy use.
