System Recovery Options
How to Boot to the System Recovery Options in Windows 7
This will show you how to boot to the System Recovery Options screen to select the Startup Repair, System Restore, Complete PC Restore, Memory Diagnostic Tool, or Command Prompt option to use on Windows 7.
The System Recovery Options menu is on the Windows 7 installation disc. If your computer manufacturer (OEM) has preinstalled recovery options, the menu might also be installed on your hard disk as a recovery partition. If your computer does not include the System Recovery Options menu, your computer manufacturer (OEM) might have customized or replaced the tool. Check the information that came with your computer or go to the manufacturer's website.
OPTION ONE
Using an OEM Recovery Partition
NOTE: This is if your computer did not come with a Windows 7 installation DVD, and has pre-installed recovery options (recovery partition) instead.
1. Start or Restart the computer.
2. Boot into the Advanced Boot Options screen.
A) Select Repair your computer and press Enter.
3. Select your keyboard language preferences and click on Next. (See screeshot below).
4. Select your user name and type in the password, and then click on OK.
5. Go to step 6 in OPTION TWO below.
OPTION TWO
Using a Windows 7 Installation or System Repair Disc
1. Insert the Windows 7 installation disc, slipstream Windows 7 SP1 installation disc, or System Repair Disc into the CD/DVD drive and restart the computer.
WARNING: Check to make sure that you set the BIOS to have the CD or DVD drive listed first in the boot order.
2. If prompted, press any key to boot from the Windows 7 installation DVD. (See screenshot below)
NOTE: You will only have about 8 seconds to press this key.
3. Select your language preferences and click on Next. (See screeshot below).
4. Click on Repair your computer. (See screenshot below)
5. Select which operating system you want to restore and the click on Next. (See screenshot below)
NOTE: If Windows 7 is not listed here, or it is blank, then it is ok. Click on Next anyway.
6. Select the system recovery option you want to do. (See screenshot below)
lol shawn
nice +1
" This is if your computer did not come with a Windows 7 installation DVD, and has pre-installed recovery options (recovery partition) instead."
Windows 7 Ult x64(x2), HomePrem x32(x4), Serv...Turion X2 ultra (oh well came with laptop)/P4...OCZ Dual Channel 4GB kit/ 1gb Dual ChannelHD 3200 graphics /GMA x3100 (yay for intergra...
1280x800 /1440x900
All Air Cooled
LOL, now they just have to release Windows 7 for a OEM recovery partition. ;)
Windows 7Intel Core 2 Duo E6300 Conroe 1.86GHzG.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2...GeForce 9600 GSO (768MB)
BIOSTAR TForce965PT
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800
Onboard
Dell e773c
1024x768
Seagate Barracuda ST3320620AS 320GB 7200RPM SATA 3.0Gb/s
OCZ GameXStream 600W
Cooler Master Centurion 532
Logitech Media Elite
Kensington PilotMouse Optical
3Mbps x 864Kbps DSL
Hello Demono,
I do not know, but it wouldn't be very helpful if your computer doesn't boot though.
Brink, Another option, which I use, is to put WinRE.Wim on a bootable PE memory stick. The procedure is highly similar to making a minimum PE USB stick. If it willl be of interest, I'll send a couple of .docx files giving a detailed, step-by-step. I've not read up on how to attach a file for upload to this forum and whether such is even permitted. Karl
Brink, Here goes an attempt at including two .docx attachments.
Brink,
Looks like that didn't work. Have saved as .doc files and will try to attach them.
Karl
MS Windows 7 Ultimate SP1 64-bitAMD A10-4600M6.00 GB Dual-Channel DDR3 @ 798MHz (11-11-12-28)AMD Radeon HD 7660G
AMD A10-4600M
AMD Pumori (Socket FT1)
AMD Radeon HD 7660G
High Definition Audio Device
1600x900@60Hz
Standard PS/2 Keyboard
Hello Karl,
Thank you. I'll take a look at it. :)
Boot into Windows 7 to retrieve docs before reinstall
Okay, here's my issue, my install went south about 4 days after install, don't know why. Spent all day yesterday going through the various system recovery options described in this site and available via booting up using my windows 7 install disk. No luck. Fairly convinced the boot mgr became corrupt and no matter what I do none of the fixes work. So, I'm pretty much resigned to the fact that I will have to reinstall. But before I do that I'd like to pull some data off the HD that I had not yet had a chance to back up before the computer crashed. What method would best allow me to simply boot into Windows 7 just to recover the information (documents, file folders, etc.)? Help!
Windows 7LE 17004 GB
Motion Computing Tablet
LE 1700
SSD KingSpec 128 GB
Hello Lindsay, and welcome to Seven Forums.
You should be able to do a repair install to fix Windows 7 without losing anything.
Brink's answers are always excellent. Here are a couple of other things which I have tried and which worked. 1. Get hold of a Win7 system that works and via the Backup and Restore option of control panel, Create a Recovery CD, boot from the recovery CD, choose applicable option. 2. Boot from a Knoppix CD and copy off your important files before doing a normal Win 7 restore. Knoppix is a Linux-variant which will allow you to access your NTFS win7 partition and files. Just google Knoppix to find latest version. You will find Knoppix easy to use if you have a Linux user with you when you use Knoppix. I strongly advise (I learned the hard way.) that after you're back to a stable system, then do a full and complete backup t9 an external USB drive using the Control Panel Backup and Restore applet. This will create a VHD-format file on the external USB. Using DiskMgmt.msc you can even mount and copy off whatever you want if you only need cetain files. Good luck, Karl
AMD A10-4600M
AMD Radeon HD 7660G
1600x900@60Hz
hello guys, i've got problem with win7 build 7600,
i think, some the system get crash because unknown think, but if turn on my computer, while he load into the welcome screen, and the he got blue screen, and restart,
it is possible to fix my problem? where i should do? where i can get download the repair kit?
win 7 build 7600AMD phenom II 9552x2 GSKILL gbpi 800Mhzait radeon His 4890 Turbo
win 7 build 7600
AMD phenom II 955
MSI DKA 790GX Platinum
onboard
dell 2309 @ 1080
320 GB
corsair vx 550
custom
default
Hello Thoger,
You can use your Windows 7 installation disc to get to the "System Recovery Options". If you do not have a installation disc, then you can create a repair disc (download option) to use instead. Afterwards, you might see if doing a system restore using a restore point dated before this problem may be able to fix it.
Brink,
Karl
Hi, thank you verry much for the tutorial BUT I'm stuck at Step 4.
"Copy Install.Wim from your product DVD. M: represents your DVD drive.
COPY M:\Sources\install.wim C:\OSimage"
Because there is no "Sources" folder in the DVD, and no .Wim files ...
Please help me.
I've downloaded and run the Windows 7 AIK (it's about 1700mb, and it's in French).
Cheers.
Windows 7 Home Premium (in French)Inter Core 2 Quad Q6600 @ 2.40GHz (Kentsfield...3.0GB Dual-Channel DDR2 @ 333MHz 5-5-5-15GeForce 8600 GT 512MB
Inter Core 2 Quad Q6600 @ 2.40GHz (Kentsfield 65nm Techno.)
PEGATRON CORPORATION Benicia (CPU 1)
ASUS VK266H
1920x1200 (Native)
Seagate ST3500630AS (SATA) 488.39GB
Microsoft® Wired Keyboard 500
HP 5189URF (M)
ADSL Down : 5.66Mb/s - Up: 0.62Mb/s
Hello Ryan,
I'm sorry, but which tutorial are you referring to? That step is not in or related to the one on the first page. :confused:
Hello Ryan,
I'm talking about the .doc posted on the first page (not the first message), where it talks about installing it on USB. Cause I have a windows 7 starter netbook, and can't use my dvd.
ASUS VK266H
1920x1200 (Native)
HP 5189URF (M)
Finally all the steps worked, but when I run it, I just got the CMD.
I don't know how to fix the boot, I tried the nt60 ... it seemed to work but it didn't, when I restart the computer it doesn't work. :confused:
I'm sure Windows 7 is still ok, the problem is the boot.
It says : Reboot and Select proper Boot device or Insert Boot Media in selected Boot device and press a key.
ASUS VK266H
1920x1200 (Native)
HP 5189URF (M)
Hi, the problem is that I had to put all this on a USB, cause my netbook doesn't have a DVD Player.
Finally I found the solution here -> YouTube - Windows 7 - Create a System Repair Disc on a Bootable USB Flash Drive
And it's very easy, I just used my home PC and went to Control Panel -> System & Security -> Backup & Restore -> Create a System Repair Disc
Then I created the CD, and finally made a Copy -> Paste from my CD to my USB.
And to let my USB be bootable I did what is told on the video, it's very easy and it worked :)
ASUS VK266H
1920x1200 (Native)
HP 5189URF (M)
That's great news Ryan. Thank you for posting back with your solution. :)
I tried booting from my win7 INstallation disk but there is no option for "repair computer or system recovery " :cry:
any other way to solve this? thank you
win7i7 930ddr3 1600ati radeon 5870
Alienware Aurora ALX
win7
i7 930
microATX
ddr3 1600
ati radeon 5870
water cooled
