Windows 7: System Restore Point : Create at System Startup
20 May 2016   #90
Brink
64-bit Windows 10 Pro
A system image is an exact copy of a drive, so it should include restore points at the time the image was created.
What is a system image?
21 May 2016   #91
betaupsilon
Windows 7 Home Prem 32 bit
Quote   Quote: Originally Posted by Brink View Post
OK, I will conduct an experiment. Are there any crucial settings I should be sure are correct to increase the likelihood of success?
I should add that this is a multi-boot system with 3 separate system partitions on the same drive. So when I created the image I am only booted into 1 of the 3 OS's. Moreover, I know to select the other 2 partitions to be included in the image.
Another note SYS PROTECTION is enabled in each of the 3 OS's, but only for that partition; not the others. I hope you follow what I am trying to say.
21 May 2016   #92
Brink
Shouldn't be any. I'll be interested in hearing your results.
22 May 2016   #93
betaupsilon
Shawn,
My experiment failed even with a single boot system. All of my previous RESTORE PTS were wiped out. What was left was a single RESTORE PT with the description "System Image Restore Point".
If this can be done do you have itemized instructions? I am not able to get this right!!!!!
If I can do a single boot system then maybe I can extend the procedure for the triple boot system. Attached are screenshots of my RESTORE PTS & SYS PRPTECTION settings prior to imaging & after image restoration. You can see the differences.
System Restore Point : Create at System Startup-capture2.png   System Restore Point : Create at System Startup-capture3.png
22 May 2016   #94
Brink
It appears that restore points don't carry over then.
22 May 2016   #95
betaupsilon
So are you uncertain on this? As I said you replied to me before that RESTORE PTS are not preserved in WindowsImageBackup & then you seemed to think they were.
I could be doing something wrong. Can you give it an attempt to see what you get?
22 May 2016   #96
Brink
Nope. If you don't have them, then they aren't included.
22 Jun 2016   #97
MadDemon64
I tried using this guide with Windows 10 but it did not work. The "Last Run Result" is stuck on "The Task is currently running. (0x41301)" and does not continue past it. It is set to run whether or not I am logged on, it runs with highest privileges, it does not have any specific conditions set, and so on.
What am I missing? The script works if I just click it, but it doesn't work when I use the task scheduler.
23 Jun 2016   #98
Brink
Hello MadDemon64, and welcome to Seven Forums.
There may be something wrong with your task. You might see if deleting the current task, and creating a new one to see if it may work afterwards.
If it still won't work, then post back with screenshots showing all your task settings to see if anything may stand out.
23 Jun 2016   #99
MadDemon64
I tried that already and it didn't work. The screenshots are below:
System Restore Point : Create at System Startup-general.png   System Restore Point : Create at System Startup-triggers.png   System Restore Point : Create at System Startup-actions.png   System Restore Point : Create at System Startup-conditions.png   System Restore Point : Create at System Startup-settings.png
System Restore Point - Create
How to Create a System Restore Point in Windows 7 By default in Windows 7 for all drives that System Protection is turned on for, System Protection creates a scheduled restore point only if no other restore points have been created in the last 7 days, and before significant system events such...
Tutorials
Windows 7 Cannot create System Restore Point
I just got done making a clean install on Windows 7 Ultimate 64-bit on a SSD drive. Then I noticed that whenever I was doing a System Update, it would try to create a restore point for many minutes and then give up and proceed with the update. Well, the bottom line is, I can't create a system...
Backup and Restore
Cannot create system restore point (0x80042302)
Been trying for about 3 days to create a restore point but the same message keeps popping up. "A volume shadow copy service component encountered an unexpected error. Check the application even log for more information." I currently have no access to Internet on my laptop and Windows 7...
Backup and Restore
How manually create a system restore point
Can't find how to manually create a system restore point
Backup and Restore
Windows 7 system restore point. Can't create / restore .
Hi Ok I borke world recored for formating windows 7 , the last 2 months . The problem is ; Windows System restore keep freezing , I'm not trying to do system restore , but when I try to install/remove a software , windows try to create restore point , making the installation/removing...
Backup and Restore
How to create a system restore point automatically?
I want to create system restore points everyday or every times the computer start...Does anybody know how to do it?
Backup and Restore
