Windows 7: System Restore Point : Create at System Startup
23 Jun 2016   #100
Brink
64-bit Windows 10 Pro
MadDemon64,
It looks like you used the existing System Restore library for the task instead of creating a new one for the task under "Task Scheduler Library".
I don't see anything wrong with your settings for the task though.
As a test, create a completely new task for this to see if it may work.
23 Jun 2016   #101
MadDemon64
Quote   Quote: Originally Posted by Brink View Post
It looks like you used the existing System Restore library for the task instead of creating a new one for the task under "Task Scheduler Library". As a test, create a completely new task for this to see if it may work.
I'm sorry, but what? I have no idea what any of that means. What do you want me to do and how?
23 Jun 2016   #102
Brink
You created or used a task in the existing "SystemRestore" library/folder in the left pane of Task Scheduler.
Instead, see if creating a new task with "Task Scheduler Library" selected in the left pane may work better.
23 Jun 2016   #103
MadDemon64
It's still not working. I tried using the script alone and it worked fine.
Could the problem possibly be that it is blocked? When I click on the script it runs after giving me a "Do you want to run this?" popup. The properties doesn't show that it's blocked in the general tab, but when I go to the security tab SYSTEM, USERNAME and Administrators allow it full control, modify, read & execute, read, and write, but Users and ALL APPLICATION PACKAGES only give it read & execute and read only, no full control, modify, or write. Additionally nothing allows it special permissions.
Is that the problem?
23 Jun 2016   #104
Brink
Could be. Download the script again to your desktop, unblock it, then move it to Program Files to see if that may be it.
23 Jun 2016   #105
MadDemon64
Do I have to download a new version? Can't I just edit the existing one to give it full permissions?
23 Jun 2016   #106
Brink
You could move it back to your desktop instead, unblock it if not already, then move it back.
Open File - Security Warning : Unblock File
23 Jun 2016   #107
MadDemon64
I tried doing that but I did not see unblock in the general tab in properties, I did not see anything that asked me if I wanted my computer to ask me if I wanted to open the file every time it tried to open, and there was no smart screen.
I do not know how to unblock it or if it is even blocked.
23 Jun 2016   #108
Brink
I must admit that I'm not sure why it's not working for you.
If you like as a test, create an elevated shortcut of the .vbs using the tutorial below first. Afterwards, set the task to run the elevated shortcut to see if it may run via the task.
23 Jun 2016   #109
MadDemon64
The elevated shortcut worked. So how do I use this knowledge to make the task scheduler automatically create a weekly system restore point?
System Restore Point - Create
How to Create a System Restore Point in Windows 7 By default in Windows 7 for all drives that System Protection is turned on for, System Protection creates a scheduled restore point only if no other restore points have been created in the last 7 days, and before significant system events such...
Tutorials
Windows 7 Cannot create System Restore Point
I just got done making a clean install on Windows 7 Ultimate 64-bit on a SSD drive. Then I noticed that whenever I was doing a System Update, it would try to create a restore point for many minutes and then give up and proceed with the update. Well, the bottom line is, I can't create a system...
Backup and Restore
Cannot create system restore point (0x80042302)
Been trying for about 3 days to create a restore point but the same message keeps popping up. "A volume shadow copy service component encountered an unexpected error. Check the application even log for more information." I currently have no access to Internet on my laptop and Windows 7...
Backup and Restore
How manually create a system restore point
Can't find how to manually create a system restore point
Backup and Restore
Windows 7 system restore point. Can't create / restore .
Hi Ok I borke world recored for formating windows 7 , the last 2 months . The problem is ; Windows System restore keep freezing , I'm not trying to do system restore , but when I try to install/remove a software , windows try to create restore point , making the installation/removing...
Backup and Restore
How to create a system restore point automatically?
I want to create system restore points everyday or every times the computer start...Does anybody know how to do it?
Backup and Restore
