Windows 7: System Restore Point : Create at System Startup
23 Jun 2016   #110
Brink
64-bit Windows 10 Pro
Quote   Quote: Originally Posted by MadDemon64 View Post
Quote   Quote: Originally Posted by Brink View Post
I must admit that I'm not sure why it's not working for you.
If you like as a test, create an elevated shortcut of the .vbs using the tutorial below first. Afterwards, set the task to run the elevated shortcut to see if it may run via the task.
The elevated shortcut worked. So how do I use this knowledge to make the task scheduler automatically create a weekly system restore point?
Good news so far.
You would use the same original "System Restore" task, but edit it to have it run the elevated shortcut instead.
23 Jun 2016   #111
MadDemon64
You would use the same task, but edit it to have it run the elevated shortcut instead.
So you want me to create an automatic task that is scheduled to run an elevated shortcut that runs a task?
Isn't there a way to just create an elevated task? Can't I just write a new task that is a copy of the elevated one and give it a trigger to run once a week?
23 Jun 2016   #112
Brink
Basically yes.
It's the only workaround that I know of to have a task run an elevated task/shortcut when the method on the first page doesn't work.
23 Jun 2016   #113
MadDemon64
Basically yes.
Can I place the shortcut in a separate folder or does it need to stay on the desktop?
23 Jun 2016   #114
Brink
Yes, you can move the shortcut to anywhere you like. You'll just need to specify that location in the task.
23 Jun 2016   #115
MadDemon64
Ok. So: do I just create a regular scheduled task that uses the elevated shortcut, or do I have to write it like I wrote the task for the elevated shortcut so it's elevated itself?
23 Jun 2016   #116
Brink
You'd basically just repeat the tutorial on the first page here, but use the elevated shortcut instead of the .vbs file.
23 Jun 2016   #117
MadDemon64
Can I just edit the original task that failed to use the elevated shortcut, or do I have to make a new one from scratch?
23 Jun 2016   #118
Brink
You could edit the task to run the elevated shortcut, but you don't want to edit the task used to create the shortcut.
23 Jun 2016   #119
MadDemon64
Ok I will try that.
System Restore Point - Create
How to Create a System Restore Point in Windows 7 By default in Windows 7 for all drives that System Protection is turned on for, System Protection creates a scheduled restore point only if no other restore points have been created in the last 7 days, and before significant system events such...
Tutorials
Windows 7 Cannot create System Restore Point
I just got done making a clean install on Windows 7 Ultimate 64-bit on a SSD drive. Then I noticed that whenever I was doing a System Update, it would try to create a restore point for many minutes and then give up and proceed with the update. Well, the bottom line is, I can't create a system...
Backup and Restore
Cannot create system restore point (0x80042302)
Been trying for about 3 days to create a restore point but the same message keeps popping up. "A volume shadow copy service component encountered an unexpected error. Check the application even log for more information." I currently have no access to Internet on my laptop and Windows 7...
Backup and Restore
How manually create a system restore point
Can't find how to manually create a system restore point
Backup and Restore
Windows 7 system restore point. Can't create / restore .
Hi Ok I borke world recored for formating windows 7 , the last 2 months . The problem is ; Windows System restore keep freezing , I'm not trying to do system restore , but when I try to install/remove a software , windows try to create restore point , making the installation/removing...
Backup and Restore
How to create a system restore point automatically?
I want to create system restore points everyday or every times the computer start...Does anybody know how to do it?
Backup and Restore
