Windows 7: System Restore Point : Create at System Startup
23 Jun 2016   #120
MadDemon64
Quote   Quote: Originally Posted by Brink View Post
You could edit the task to run the elevated shortcut, but you don't want to edit the task used to create the shortcut.
On the bright side, the task scheduler completed successfully.
On the not-so bright side, no system restore point was created. Is it because the program in the new task is "C:\Windows\System32\schtasks.exe" and the target in the shortcut is "C:\Windows\System32\schtasks.exe /run /tn "System Restore Test"?
23 Jun 2016   #121
Brink
64-bit Windows 10 Pro
Yep. You want to enter the full path of the elevated shortcut at step 8 in the tutorial on the first page here.
Just to clarify and verify, you will have two separate tasks that you're working with. One is the task that the elevated shortcut runs. The second is the task from the first page here to run the elevated shortcut to create the restore point with.
23 Jun 2016   #122
MadDemon64
So in this case what would the full path be? Is it "C:\Windows\System32\schtasks.exe /run /tn "System Restore Test", "C:\Program Files\System Restore Test", or something else entirely?
23 Jun 2016   #123
Brink
The full path would be for where the actual shortcut file is saved at.
23 Jun 2016   #124
MadDemon64
Yea that's what I did. I clicked "browse" next to "program/script", highlighted the elevated prompt, pressed "open" and it gave me "C:\Windows\System32\schtasks.exe" as the path.
Isn't that what I'm supposed to do?
23 Jun 2016   #125
Brink
Nope.
The path will need to be the location of the .lnk (elevated shortcut) file you created from below, and not the target of the shortcut.
23 Jun 2016   #126
MadDemon64
Nope.
So if I understand this correctly, given that I titled the shortcut "System Restore Test" and placed it in "Program Files", I should type "C:\Program Files\System_Restore_Test.lnk" in the "Program/Script" part of the scheduled task? If not, what should I type?
23 Jun 2016   #127
Brink
That's correct.
23 Jun 2016   #128
MadDemon64
That's correct.
Looks like I'm back to square one: it is stuck on "This program is running".
I can still make the elevated one work though. I'm thinking my best chance is to edit it to automatically make the system restore points.
23 Jun 2016   #129
MadDemon64
Ok so I think I actually managed to get it to work with a bit of tweaking. I had to make a new task that copied the elevated task and gave it a schedule. I'll have to wait to see if it works as scheduled, but at least if I manually run it it functions properly.
System Restore Point - Create
How to Create a System Restore Point in Windows 7 By default in Windows 7 for all drives that System Protection is turned on for, System Protection creates a scheduled restore point only if no other restore points have been created in the last 7 days, and before significant system events such...
Tutorials
Windows 7 Cannot create System Restore Point
I just got done making a clean install on Windows 7 Ultimate 64-bit on a SSD drive. Then I noticed that whenever I was doing a System Update, it would try to create a restore point for many minutes and then give up and proceed with the update. Well, the bottom line is, I can't create a system...
Backup and Restore
Cannot create system restore point (0x80042302)
Been trying for about 3 days to create a restore point but the same message keeps popping up. "A volume shadow copy service component encountered an unexpected error. Check the application even log for more information." I currently have no access to Internet on my laptop and Windows 7...
Backup and Restore
How manually create a system restore point
Can't find how to manually create a system restore point
Backup and Restore
Windows 7 system restore point. Can't create / restore .
Hi Ok I borke world recored for formating windows 7 , the last 2 months . The problem is ; Windows System restore keep freezing , I'm not trying to do system restore , but when I try to install/remove a software , windows try to create restore point , making the installation/removing...
Backup and Restore
How to create a system restore point automatically?
I want to create system restore points everyday or every times the computer start...Does anybody know how to do it?
Backup and Restore
