Windows 7: System Restore Point : Create at System Startup
23 Jun 2016   #130
Layback Bear
Windows 7 Pro. 64/SP-1
Just a thought.
I believe it would be a fine time to reboot and then see if things work as you desire.
I would wait and see if Brink agrees with me. He is the expert.
23 Jun 2016   #131
Brink
64-bit Windows 10 Pro
It can't hurt to try, but I don't think it'll make any difference.
23 Jun 2016   #132
MadDemon64
Quote   Quote: Originally Posted by Brink View Post
For some odd reason Zemana thinks that the tasks that I created with the script are Win32Poweliks trojans. Nothing else labels them as trojans. Is that normal?
Other than that though it seems to be working for now.
23 Jun 2016   #133
Brink
I'm not sure why it would think the tasks are Trojans.
24 Jun 2016   #134
MadDemon64
Well it did. And for some reason the task still works even though Zemana claims it deleted the "trojan".
24 Jun 2016   #135
Brink
Gotta love those false positives.
24 Jun 2016   #136
MadDemon64
Yea, but what concerns me is how the task scheduler still runs those tasks without them being located in the task folder. Zemana deleted them but I can still run the tasks.
How is that even possible?
24 Jun 2016   #137
Brink
I don't know. The task would need to be there for it to still run. Odd.
24 Jun 2016   #138
MadDemon64
Should I delete the current tasks and create a new one just to be safe?
24 Jun 2016   #139
Brink
Since they're working, I'd let them be if you like.
System Restore Point - Create
How to Create a System Restore Point in Windows 7 By default in Windows 7 for all drives that System Protection is turned on for, System Protection creates a scheduled restore point only if no other restore points have been created in the last 7 days, and before significant system events such...
Tutorials
Windows 7 Cannot create System Restore Point
I just got done making a clean install on Windows 7 Ultimate 64-bit on a SSD drive. Then I noticed that whenever I was doing a System Update, it would try to create a restore point for many minutes and then give up and proceed with the update. Well, the bottom line is, I can't create a system...
Backup and Restore
Cannot create system restore point (0x80042302)
Been trying for about 3 days to create a restore point but the same message keeps popping up. "A volume shadow copy service component encountered an unexpected error. Check the application even log for more information." I currently have no access to Internet on my laptop and Windows 7...
Backup and Restore
How manually create a system restore point
Can't find how to manually create a system restore point
Backup and Restore
Windows 7 system restore point. Can't create / restore .
Hi Ok I borke world recored for formating windows 7 , the last 2 months . The problem is ; Windows System restore keep freezing , I'm not trying to do system restore , but when I try to install/remove a software , windows try to create restore point , making the installation/removing...
Backup and Restore
How to create a system restore point automatically?
I want to create system restore points everyday or every times the computer start...Does anybody know how to do it?
Backup and Restore
