Windows 7: System Restore Point : Create at System Startup
24 Jun 2016   #140
MadDemon64
Quote   Quote: Originally Posted by Brink View Post
Since they're working, I'd let them be if you like.
Well, according to zemana, the tasks were trojans that exist in the RAM. Could that explain it?
24 Jun 2016   #141
Brink
64-bit Windows 10 Pro
It wouldn't hurt to do a full scan of your system to be safe in case it may be from something else.
Doing an offline scan at boot with Windows Defender Offline or an AV of your choice would be a good option.
24 Jun 2016   #142
MadDemon64
It wouldn't hurt to do a full scan of your system to be safe.
I'm doing that right now.
02 Aug 2016   #143
delmonte
win 10 64bit
Auto Restore point not working
Hello All,
great tutorial, many thanks.
I have followed method 2 and task history shows the task ran, however there are no restore points associated. I am running windows 10 64bit, any ideas?
Many thanks
02 Aug 2016   #144
Brink
Quote   Quote: Originally Posted by delmonte View Post
Hello All,
Many thanks
Hello delmonte, and welcome to Seven Forums.
Sometimes it may take a few minutes for the restore point to show up in System Restore.
For now, you might see if either tutorial below may work for you instead.
Restore Point Context Menu - Add in Windows 10 - Windows 10 Forums
System Restore Point shortcut - Create in Windows 10 - Windows 10 Forums
27 Aug 2016   #145
kitpzyxmsir
Windows 10 Pro
Scripts work great.
I have the machine setup to create a restore point at startup, but two more things Id like to do.
1) Bypass the User Account Control. I've tried 3 methods: Task Scheduler, Winaero Elevated Shortcut.exe, and UAC Trust Shortcut.
The first two dont work at all (because they dont work with vbs scripts?).
In the case of UAC Trust Shortcut, when you are fully loaded in windows, it work fine. The problem is that UAC Trust Shortcut must be running to affect the shortcuts it has created. Thus, I have it set to open at startup.
The dilemma here is that when the startup folder shortcuts take effect, the system restore script initializes before the UAC Trust Shortcut program
2) I want to eliminate the "system restore point created successfully" message
thanks
27 Aug 2016   #146
Brink
Hello kitpzyxmsir, and welcome to Seven Forums.
You should be able to use Method 2 as is in the tutorial on the first page here to create an instant restore point without a UAC prompt or success message.
28 Aug 2016   #147
kitpzyxmsir
Windows 10 Pro
Hi Brink,
The main reason I have been using a combination of methods for eliminating the UAC during startup of specific items is that, for me, none of the methods work on all file types.
I would prefer to always use the "scheduled task" method for this purpose, but I have never been able to initialize any VBS file in that environment
The Method 2 scenario wasnt exactly what I was looking for, but the Instant_Restore_Point.vbs would be ideal for working silently in the background whenever windows boots up.
However, I did set up Method 2 as-is (well, not exactly as-is....I made a few changes I hoped would no matter) to see if i could finally get a VBS script to work in there
I tried the daily setting and the one time setting.
It still didnt work.
I never get a password prompt when trying to setup a task because my intent is to eliminate the UAC, not setup a schedule, so the "trigger" in not a factor. I really dont want to have to setup a login password.
Is this the step that is stopping me? Is there something unique about VBS scripts in re passwords or otherwise?
In the screenshots you will see what I did, including "configure for Windows 10"
System Restore Point : Create at System Startup-point_creator_1.png   System Restore Point : Create at System Startup-point_creator_2.png   System Restore Point : Create at System Startup-point_creator_3.png
28 Aug 2016   #148
Brink
What changes did you make?
Luckily, you're not prompted for a password in W10.
28 Aug 2016   #149
kitpzyxmsir
Windows 10 Pro
Yeh, I dont know if it is still this way, but I learned my lesson the hard way when I first got Win 10, created a microsoft user account from the start menu, and got stuck with an unsolicited and unwanted computer password login
System Restore Point : Create at System Startup-point_creator_5.png
System Restore Point - Create
How to Create a System Restore Point in Windows 7 By default in Windows 7 for all drives that System Protection is turned on for, System Protection creates a scheduled restore point only if no other restore points have been created in the last 7 days, and before significant system events such...
Tutorials
Windows 7 Cannot create System Restore Point
I just got done making a clean install on Windows 7 Ultimate 64-bit on a SSD drive. Then I noticed that whenever I was doing a System Update, it would try to create a restore point for many minutes and then give up and proceed with the update. Well, the bottom line is, I can't create a system...
Backup and Restore
Cannot create system restore point (0x80042302)
Been trying for about 3 days to create a restore point but the same message keeps popping up. "A volume shadow copy service component encountered an unexpected error. Check the application even log for more information." I currently have no access to Internet on my laptop and Windows 7...
Backup and Restore
How manually create a system restore point
Can't find how to manually create a system restore point
Backup and Restore
Windows 7 system restore point. Can't create / restore .
Hi Ok I borke world recored for formating windows 7 , the last 2 months . The problem is ; Windows System restore keep freezing , I'm not trying to do system restore , but when I try to install/remove a software , windows try to create restore point , making the installation/removing...
Backup and Restore
How to create a system restore point automatically?
I want to create system restore points everyday or every times the computer start...Does anybody know how to do it?
Backup and Restore
