'Task - Create to Run a Program at Startup and Log On'
'Elevated Program Shortcut without UAC Prompt - Create'
Thanks guys, but I can't get either of those two methods to prevent the UAC prompt from asking permission to run "create_srp.vbs" at startup.
If other people here have been able to use the method to run an exe on startup, maybe it's an issue with the vbs file.
I think I'll just turn off UAC and be done with it.
Cheers :-)
