System Restore Point : Create at System Startup
How to Automatically Create System Restore Points in Windows 7 and 8
The two (2) separate methods outlined herein make it very easy to have fresh, reliable System Restore points available for use whenever needed; whether created by a system startup/restart or created by the Windows Task Scheduler; once it's setup you never have to be concerned with it again, it's all completely automatic.​
System Restore isn't available for Windows RT.
Credit for this goes to our own Microsoft MVP and all around good guy Brink who wrote these "Restore Point" scripts, without whose dedication and hard work with the Windows Operating Systems none of this would even be possible. Thanks Shawn! :)
Please view his original tutorial for pertinent Windows 7 information .
Windows 7 System Restore Point Shortcut
This will also work with Windows Vista.
Please view the relevant tutorial at Vista Forums at the link below.
Vista System Restore Point Shortcut
For those of you that would like to have the option to create restore points without restarting the system have a look at step #4 A below to add a shortcut to the desktop or the taskbar that can be used whenever needed without a system restart.
Be sure to have a look at Method Two below to see the steps to use the Windows Task Scheduler to automatically create System Restore points, once the task is created there is nothing further to do, there will always be daily, fresh System Restore points available for use if needed, even if the PC is never restarted at all.
Let's get started!
Method One
System Startup / Restart
1) The first thing that needs done is to download the file you want to use; to create a restore point with a description click the button below and select to save the file to the desktop.
Restore_Point_Shortcut.zip file (with description)
Download
2) To create a restore point without a description click the button below and save the file to the desktop.
Instant_Restore_Point.zip file (without description)
Download
3) Open the downloaded zip file, extract (drag and drop) the VBS file to the desktop, and unblock the VBS file.
4) Navigate to "C:\Program Files" in Windows Explorer (not "Program Files (x86)" if you have 64-bit Windows), move the extracted and unblocked VBS file into the "C:\Program Files" folder, then close the "Program Files" window.
click any image to enlarge
5) Now in the start menu navigate to and r click the "Startup File" to open the "Startup" file window; now back at the "Restore_Point Shortcut" window r click the "Create System Restore Point" shortcut and click cut, then in the "Startup" window at an empty spot click paste. A) Now if you want a shortcut on the desktop to create a restore point whenever needed (without restarting the PC) r click the "Instant Restore Point" shortcut in the "Startup" window and select "Send to, Desktop (create shortcut)" to place a shortcut on the desktop.
6) You're done, now close all the windows and if you want, the zip and the restore point files that you downloaded can be deleted from the desktop.
To use the shortcut you just created.
7) Whenever the PC boots to the desktop the first prompt you'll get is "Do you want to open this file?" click open then enter your user credentials for the UAC prompt and click yes.
8) If you have chosen to use the restore point creator with a description this last snip is the last step in the process, enter the description you want to use and click ok to finish up, that's all there is to it. I use the one with no description and with 2 clicks at bootup it's done.
Method Two
1) Start by downloading this zip file to the Windows desktop.
Scheduled_Instant_Restore_Point.zip
Download
2) Open the downloaded zip file, extract (drag and drop) the VBS file to the desktop, and unblock the VBS file.
3) Navigate to "C:\Program Files" in Windows Explorer (not "Program Files (x86)" if you have 64-bit Windows), move the extracted and unblocked VBS file into the "C:\Program Files" folder, then close the "Program Files" window.
4) In the "Access Denied" dialog box that opens click Continue, if you get a UAC prompt, enter your user credentials and click Yes; then just close the Program Files window that opens.
You can now delete the downloaded Zip file from the desktop if you like.
Now in the Windows start menu search box type taskschd.msc and hit the <enter> key. In the Task Scheduler window that opens at the right pane Actions column, click Create Task.
5) In the "Create Task" window that opens at the General tab, give the new task a Name, a description is optional, dot "Run whether user ... " put a check/tic at "Run with highest ... " and "Configure for ... " your flavor Windows.
6) Now still in the "Create Task" window click the Triggers tab, at the bottom left click the New button, in the New Trigger dialog box that opens be sure to select when you want the task to run and the daily time you want it to run and click OK.
7) Now back at the "Create Task" window click the Actions tab, at the bottom left click the New button, in the New Action dialog box that opens click Browse (see #8 below), now browse to C:\Program Files and click the Instant_Restore_Point file you extracted there in step #2 above and click Open, then click the Instant_Restore_Point script and click Open again.
8) Now at the New Action dialog box that's still open click OK.
9) In the Create Task window that's still open click OK, in the Account Information dialog box that opens add your user credentials and click OK.
That's all, you are now finished and you can close the Task Scheduler.
Enjoy! :)
I donot get an option to unblock the vbs file.
I get the open with option when I right click on the filw.
Hope this helps.
Win 6 Ultimate 64 bit
Dell 6420
Hi Brink,
Your sugesstion does not help.
My probkem is a little different.
Whenever I shutdown and reboot my laptop, Everytime, I need to remerge the default VBS file. Is there a way I can solve the problem permanently?
I also noticed that when I go "Open with"and go to "other programs" the option stating "always use this program to open this kind of file is greyed out"and I cannot check thsi option.
I use win 7 64 bit OS.
Dell 6420
Futuristic,
Running the VBS file only creates the restore point for just that one time. If you want it to create a restore point at every startup, then you will need to do METHOD TWO in the tutorial instead.
Hi Brink
Yes I understand. My problem is that I follow the tutorial and by use of task scheduler make an auto restore point creation.
This works perfectly well. But only tillmy laptop is running.
If at the end of the days shutdown my laptop the next day the restore point is not created attached upped time.
I need to once again run the vbs default file by choosing the regedit program from win 7 program file.
This will then work fine till the time I shutdown my laptop.
In short the VBS file is loosing its default program connection to regedit whenever I shutdown the laptop.
Thus I was asking if there is a way wherein the vbs file remains permanently associated with regedit.
Dell 6420
I'm not sure why or where you got that you need to have VBS files to be associated to open with regedit. If you do, the VBS file will no longer work since it needs to be associated with C:\Windows\System32\wscript.exe (Microsoft Windows Based Scipt Host) instead.
Are you changing it to open with regedit? If so, then do what I posted above to restore the default associations of VBS files, and stop that. ;)
I tried method two (Task Scheduler) and upon clicking OK at the Actions tab, I got:
"An error has occurred for task auto_restore_point. Error message: User account restriction error. The possible reasons are that blank passwords not allowed, or that a policy restriction has been enforced."
I carefully followed the instructions twice and I did not get in step 4 an 'Access Denied' dialog box or a UAC prompt.
What am I missing?
Windows 7 Professional x648 GB
HP p6350z
8 GB
2 x Dell 2007WFPb
Hello ixodid,
Is this a home computer, or are you in a domain?
Are you logged in as an administrator?
Does it have a password created for your administrator account? If not, you will need one.
Do you have UAC turned on?
Hope this helps for now, :)
This is one of my favorite apps to use for Windows 7. Now that everything is switching towards Windows 8, someone needs create one for Windows 8. I can't seem to get it working working with Windows 8 with either methods.
Windows 7Intel Core 2 Quad CPU Q6700 @ 3.50 GHzOCZ SLI 2048MB PC16000 DDR3 2000MHz MemoryEVGA Geforce GTX 260 Core 216
Nvidia
Nvidia 790i Ultra SLI
ASUS Xonar HDAV1.3 Deluxe
LG Flatron W2453V
Seagate Barracuda 1.5TB Serial ATA/300, 32MB Buffer
Hard Drive.-ST315005N4A1AS-RK
Swiftech Storm Universal Waterblock Rev 2
CM Stacker 830
Microsoft Wireless Comfort Keyboard 1.0A
Gaming Mouse G500
20 MB
many thanks for this!!! after last time my windows mysteriously crashed without any system restore points, i have the feeling that this post will save my life one day :D
Windows 7 Professional 64 bit (German)Intel® Core™ i3-2350M Prozessor6 GBIntel® HD Graphics 3000 AMD Radeon® HD 6470M
Sony Vaio VPCSB4M9E
Avast! Free
Torch
Glad I could be a help mate
* BFK Customs *
W 7 64-bit Ultimate
Intel Q9550 Yorkfield
ASUS P5Q Pro
8GB Dominator 8500C5D
ATI : XFX 5870
Realtek HD Audio 7-1
1920x1080P & 1920x1200
Corsair 620HX
Cooler Master RC-690
Microsoft 500
Razer Diamondback 3G
14 Mb/s
Can't get to work on Win 8.1
I followed the instructions to the letter in this thread to have a restore point created using the task scheduler in Windows 8.1 Professional. I set the trigger to be a certain time every two days. The task does not work on the schedule or if I tell task scheduler to run it by clicking "Run" with the task highlighted in Task Scheduler.
If I do that, the task says "Running", but it stays running forever and nothing happens, no restore point created. After I tried running it manually I went to system restore and the last restore point I had was one I created manually several days ago. However, is it possible that if the last normal restore point from the computer is identical, no new restore point will be created?
If I run the task manually as I said above, it stays "Running" for more than a half hour and never goes to the Ready state. So, I've had to manually end the task. Besides using the "Brink_Task" vbs file, I also tried the Instant_Restore_Point.zip from http://www.sevenforums.com/tutorials/494-system-restore-point-shortcut.html
Neither works. In the "Conditions" tab, only "Wake the computer to run this task" is checked. All other boxes are unchecked.
Information    2/2/2014 12:40:32 AM    330    Task stopping due to user request    Info    fa01ad9d-0480-42e3-babf-753e322d86ec
Information    2/2/2014 12:40:32 AM    102    Task completed    (2)    fa01ad9d-0480-42e3-babf-753e322d86ec
Information    2/2/2014 12:40:32 AM    201    Action completed    (2)    fa01ad9d-0480-42e3-babf-753e322d86ec
Information    2/2/2014 12:40:32 AM    111    Task terminated    Termination    fa01ad9d-0480-42e3-babf-753e322d86ec
Information    2/2/2014 12:46:35 AM    140    Task registration updated    Info
Information    2/2/2014 12:46:44 AM    200    Action started    (1)    2a6e153f-3122-4b9a-a3f1-6003bd292a68
Information    2/2/2014 12:46:44 AM    100    Task Started    (1)    2a6e153f-3122-4b9a-a3f1-6003bd292a68
Information    2/2/2014 12:46:44 AM    129    Created Task Process    Info
Information    2/2/2014 12:46:44 AM    110    Task triggered by user    Info    2a6e153f-3122-4b9a-a3f1-6003bd292a68
Information    2/2/2014 12:49:01 AM    200    Action started    (1)    c32e2e77-4d68-4410-b97a-2388a3eb6952
Information    2/2/2014 12:49:01 AM    100    Task Started    (1)    c32e2e77-4d68-4410-b97a-2388a3eb6952
Information    2/2/2014 12:49:01 AM    129    Created Task Process    Info    6cdb137a-1595-0002-7c13-db6c9515cf01
Information    2/2/2014 12:49:01 AM    110    Task triggered by user    Info    c32e2e77-4d68-4410-b97a-2388a3eb6952
Information    2/2/2014 12:49:09 AM    200    Action started    (1)    4ac807e9-94e8-4a81-9f6f-0260a5a14fad
Information    2/2/2014 12:49:09 AM    100    Task Started    (1)    4ac807e9-94e8-4a81-9f6f-0260a5a14fad
Information    2/2/2014 12:49:09 AM    129    Created Task Process    Info
Information    2/2/2014 12:49:09 AM    110    Task triggered by user    Info    4ac807e9-94e8-4a81-9f6f-0260a5a14fad
Information    2/2/2014 12:49:10 AM    200    Action started    (1)    46309e20-1b47-49c5-aee3-d52ac932c700
Information    2/2/2014 12:49:10 AM    100    Task Started    (1)    46309e20-1b47-49c5-aee3-d52ac932c700
Information    2/2/2014 12:49:10 AM    129    Created Task Process    Info
Information    2/2/2014 12:49:10 AM    110    Task triggered by user    Info    46309e20-1b47-49c5-aee3-d52ac932c700
Information    2/2/2014 12:49:10 AM    200    Action started    (1)    530bb36d-597d-4113-9c40-108443e2b880
Information    2/2/2014 12:49:10 AM    100    Task Started    (1)    530bb36d-597d-4113-9c40-108443e2b880
Information    2/2/2014 12:49:10 AM    110    Task triggered by user    Info    530bb36d-597d-4113-9c40-108443e2b880
Information    2/2/2014 12:49:36 AM    200    Action started    (1)    ff12244e-1b99-4827-8799-fed295170c95
Information    2/2/2014 12:49:36 AM    100    Task Started    (1)    ff12244e-1b99-4827-8799-fed295170c95
Information    2/2/2014 12:49:36 AM    129    Created Task Process    Info
Information    2/2/2014 12:49:36 AM    110    Task triggered by user    Info    ff12244e-1b99-4827-8799-fed295170c95
Information    2/2/2014 1:08:52 AM    330    Task stopping due to user request    Info    2a6e153f-3122-4b9a-a3f1-6003bd292a68
Information    2/2/2014 1:08:52 AM    102    Task completed    (2)    2a6e153f-3122-4b9a-a3f1-6003bd292a68
Information    2/2/2014 1:08:52 AM    201    Action completed    (2)    2a6e153f-3122-4b9a-a3f1-6003bd292a68
Information    2/2/2014 1:08:52 AM    201    Action completed    (2)    c32e2e77-4d68-4410-b97a-2388a3eb6952
Information    2/2/2014 1:08:52 AM    102    Task completed    (2)    c32e2e77-4d68-4410-b97a-2388a3eb6952
Information    2/2/2014 1:08:52 AM    111    Task terminated    Termination    2a6e153f-3122-4b9a-a3f1-6003bd292a68
Information    2/2/2014 1:08:52 AM    330    Task stopping due to user request    Info    c32e2e77-4d68-4410-b97a-2388a3eb6952
Information    2/2/2014 1:08:52 AM    111    Task terminated    Termination    c32e2e77-4d68-4410-b97a-2388a3eb6952
Information    2/2/2014 1:08:52 AM    102    Task completed    (2)    4ac807e9-94e8-4a81-9f6f-0260a5a14fad
Information    2/2/2014 1:08:52 AM    201    Action completed    (2)    4ac807e9-94e8-4a81-9f6f-0260a5a14fad
Information    2/2/2014 1:08:52 AM    330    Task stopping due to user request    Info    4ac807e9-94e8-4a81-9f6f-0260a5a14fad
Information    2/2/2014 1:08:52 AM    111    Task terminated    Termination    4ac807e9-94e8-4a81-9f6f-0260a5a14fad
Information    2/2/2014 1:08:52 AM    102    Task completed    (2)    46309e20-1b47-49c5-aee3-d52ac932c700
Information    2/2/2014 1:08:52 AM    201    Action completed    (2)    46309e20-1b47-49c5-aee3-d52ac932c700
Information    2/2/2014 1:08:52 AM    330    Task stopping due to user request    Info    46309e20-1b47-49c5-aee3-d52ac932c700
Information    2/2/2014 1:08:52 AM    201    Action completed    (2)    530bb36d-597d-4113-9c40-108443e2b880
Information    2/2/2014 1:08:52 AM    102    Task completed    (2)    530bb36d-597d-4113-9c40-108443e2b880
Information    2/2/2014 1:08:52 AM    111    Task terminated    Termination    46309e20-1b47-49c5-aee3-d52ac932c700
Information    2/2/2014 1:08:52 AM    330    Task stopping due to user request    Info    530bb36d-597d-4113-9c40-108443e2b880
Information    2/2/2014 1:08:52 AM    201    Action completed    (2)    ff12244e-1b99-4827-8799-fed295170c95
Information    2/2/2014 1:08:52 AM    102    Task completed    (2)    ff12244e-1b99-4827-8799-fed295170c95
Information    2/2/2014 1:08:52 AM    111    Task terminated    Termination    530bb36d-597d-4113-9c40-108443e2b880
Information    2/2/2014 1:08:52 AM    330    Task stopping due to user request    Info    ff12244e-1b99-4827-8799-fed295170c95
Information    2/2/2014 1:08:52 AM    111    Task terminated    Termination    ff12244e-1b99-4827-8799-fed295170c95
Information    2/2/2014 1:09:26 AM    142    Task disabled    Info
Information    2/2/2014 1:15:20 AM    140    Task registration updated    Info
Information    2/2/2014 1:15:21 AM    129    Created Task Process    Info
Information    2/2/2014 1:15:21 AM    200    Action started    (1)    2a77e8ac-b054-4d13-8b5b-523b7364f963
Information    2/2/2014 1:15:21 AM    100    Task Started    (1)    2a77e8ac-b054-4d13-8b5b-523b7364f963
Information    2/2/2014 1:15:21 AM    110    Task triggered by user    Info    2a77e8ac-b054-4d13-8b5b-523b7364f963
Information    2/2/2014 1:24:12 AM    330    Task stopping due to user request    Info    2a77e8ac-b054-4d13-8b5b-523b7364f963
Information    2/2/2014 1:24:12 AM    102    Task completed    (2)    2a77e8ac-b054-4d13-8b5b-523b7364f963
Information    2/2/2014 1:24:12 AM    201    Action completed    (2)    2a77e8ac-b054-4d13-8b5b-523b7364f963
Information    2/2/2014 1:24:12 AM    111    Task terminated    Termination    2a77e8ac-b054-4d13-8b5b-523b7364f963
Information    2/2/2014 1:55:19 AM    200    Action started    (1)    22c1b76c-bcd2-42c5-b866-9302df41a539
Information    2/2/2014 1:55:19 AM    100    Task Started    (1)    22c1b76c-bcd2-42c5-b866-9302df41a539
Information    2/2/2014 1:55:19 AM    129    Created Task Process    Info
Information    2/2/2014 1:55:19 AM    110    Task triggered by user    Info    22c1b76c-bcd2-42c5-b866-9302df41a539
Information    2/2/2014 1:57:54 AM    330    Task stopping due to user request    Info    22c1b76c-bcd2-42c5-b866-9302df41a539
Information    2/2/2014 1:57:54 AM    201    Action completed    (2)    22c1b76c-bcd2-42c5-b866-9302df41a539
Information    2/2/2014 1:57:54 AM    102    Task completed    (2)    22c1b76c-bcd2-42c5-b866-9302df41a539
Information    2/2/2014 1:57:54 AM    111    Task terminated    Termination    22c1b76c-bcd2-42c5-b866-9302df41a539
Information    2/2/2014 1:57:59 AM    142    Task disabled    Info
Win 8.1 Professional 64 bit, Win 7 Ultimate 6...
Win 8.1 Professional 64 bit, Win 7 Ultimate 64 biut
Hello Charles, and welcome to Seven Forums.
As a test to see if something may be wrong with your System Restore, see if you are able to create a restore point using the normal method below, then check to see if that restore point is listed afterwards. Sometimes it may take a bit before the created restore point shows up though.
Restore Point - Create in Windows 8
Restore works
Yes, I created a restore point with the System Properties/System Protection tab, it works fine.
Oddly some time last night one of the task scheduler restores worked. I just saw it when I created the restore point from the system tab above. I am showing the tab created restore point I called "Test" and another restore point titled Instant Restore Point at 2:00:56 am.
I may have double clicked the icon for the Restore Point shortcut from the Instant_Restore_Point.zip folder, or it may have been when I used the different script for the Instant_Restore_Point.vbs from the Instant_Restore_Point.zip in the Program Files folder triggered by me telling the task scheduler to run that vbs file. I do remember that anytime I told the task scheduler to run it would change status to running and even after 10 minutes, stay running and not revert ever to Ready. The Brink_Task.zip Instant_Restore_Point.vbs is different from the Instant_Restore_Point.zip Instant_Restore_Point.vbs.
I am a former .Net developer and electrical engineer, but never did any substantial VB script (thankfully).
Anyway, I have to do a ton of errands and stuff today, so I may not reply to you for a day or so.
Thanks.
Could be. Yeah, the .vbs file does the actual work.
For a task, I would recommend the Instant_Restore_Point.vbs to not have it wait on you to enter a description when you may not be there to do so.
No I used the zip file that does not require the description. However, I am not sure which vbs script worked, if it worked via the task scheduler, and in all cases, the task scheduler always said "running" and never ended to revert to the ready state.
I'm not sure why it would continue to show as running instead of ready in Task Scheduler though. Does it give you a "the operation compeleted successfully" message in the "Last Run Result" column for the task?
I ran the Instant_Restore_Point.vbs from the Brink_Task folder. It creates a restore point.
In the task scheduler, I had the task to run the same Brink Instant_Restore_Point.vbs every two days at a certain time, but in the Last Run Result column of the task scheduler it says: "The operator or administrator has refused the request."
If I tell the task scheduler to run the task immediately, I get a status of running, but 15 minutes later a restore point has not been created and the task still stays in the "Running" status state, so I have to end it manually.
So for some reason, the task scheduler can't execute the vbs file properly.
It sounds like something may be off with the task's settings. Triple check the steps using the instant.vbs to see if anything may not be the same as in the tutorial. :confused:
Of course, Windows needs to be running for the task to run at it's scheduled time.
Manual trigger of task does not work
I triple checked the task settings, they are fine. Indeed I may have had the laptop lid closed for a day or two so that the computer would not awaken I think if the lid is closed.
However, I am focusing more on the fact that when I manually tell the task to run, it does not create the restore point, and just sits there saying it is running with nothing happening at all.
I would think that if I had a vbs script that when runs creates a popup window message, I could verify if the vbs script gets executed by the manual running of the task, which I am pretty sure is not happening.
I will try a message box popup script per the instructions here:
How to: Make a message box using VBScript
