Windows 7: System Restore Point : Create at System Startup
20 Mar 2012   #40
futuristic6
Win 6 Ultimate 64 bit
I donot get an option to unblock the vbs file.
I get the open with option when I right click on the filw.
Hope this helps.
20 Mar 2012   #41
Brink
64-bit Windows 10 Pro
Futuristic,
Download and merge the listed VBS option in the tutorial below to restore it's default associations. Afterwards, see if you will be able to so the tutorial on the first page.
20 Mar 2012   #42
futuristic6
Hi Brink,
Your sugesstion does not help.
My probkem is a little different.
Whenever I shutdown and reboot my laptop, Everytime, I need to remerge the default VBS file. Is there a way I can solve the problem permanently?
I also noticed that when I go "Open with"and go to "other programs" the option stating "always use this program to open this kind of file is greyed out"and I cannot check thsi option.
I use win 7 64 bit OS.
20 Mar 2012   #43
Brink
Futuristic,
Running the VBS file only creates the restore point for just that one time. If you want it to create a restore point at every startup, then you will need to do METHOD TWO in the tutorial instead.
20 Mar 2012   #44
futuristic6
Hi Brink
Yes I understand. My problem is that I follow the tutorial and by use of task scheduler make an auto restore point creation.
This works perfectly well. But only tillmy laptop is running.
If at the end of the days shutdown my laptop the next day the restore point is not created attached upped time.
I need to once again run the vbs default file by choosing the regedit program from win 7 program file.
This will then work fine till the time I shutdown my laptop.
In short the VBS file is loosing its default program connection to regedit whenever I shutdown the laptop.
Thus I was asking if there is a way wherein the vbs file remains permanently associated with regedit.
20 Mar 2012   #45
Brink
I'm not sure why or where you got that you need to have VBS files to be associated to open with regedit. If you do, the VBS file will no longer work since it needs to be associated with C:\Windows\System32\wscript.exe (Microsoft Windows Based Scipt Host) instead.
Are you changing it to open with regedit? If so, then do what I posted above to restore the default associations of VBS files, and stop that.
15 Oct 2012   #46
ixodid
Windows 7 Professional x64
I tried method two (Task Scheduler) and upon clicking OK at the Actions tab, I got:
"An error has occurred for task auto_restore_point. Error message: User account restriction error. The possible reasons are that blank passwords not allowed, or that a policy restriction has been enforced."
I carefully followed the instructions twice and I did not get in step 4 an 'Access Denied' dialog box or a UAC prompt.
What am I missing?
15 Oct 2012   #47
Brink
Hello ixodid,
Is this a home computer, or are you in a domain?
Are you logged in as an administrator?
Does it have a password created for your administrator account? If not, you will need one.
Do you have UAC turned on?
Hope this helps for now,
16 Mar 2013   #48
Bad213Boy
This is one of my favorite apps to use for Windows 7. Now that everything is switching towards Windows 8, someone needs create one for Windows 8. I can't seem to get it working working with Windows 8 with either methods.
08 Apr 2013   #49
xdya
Windows 7 Professional 64 bit (German)
many thanks for this!!! after last time my windows mysteriously crashed without any system restore points, i have the feeling that this post will save my life one day
System Restore Point - Create
How to Create a System Restore Point in Windows 7 By default in Windows 7 for all drives that System Protection is turned on for, System Protection creates a scheduled restore point only if no other restore points have been created in the last 7 days, and before significant system events such...
Tutorials
Windows 7 Cannot create System Restore Point
I just got done making a clean install on Windows 7 Ultimate 64-bit on a SSD drive. Then I noticed that whenever I was doing a System Update, it would try to create a restore point for many minutes and then give up and proceed with the update. Well, the bottom line is, I can't create a system...
Backup and Restore
Cannot create system restore point (0x80042302)
Been trying for about 3 days to create a restore point but the same message keeps popping up. "A volume shadow copy service component encountered an unexpected error. Check the application even log for more information." I currently have no access to Internet on my laptop and Windows 7...
Backup and Restore
How manually create a system restore point
Can't find how to manually create a system restore point
Backup and Restore
Windows 7 system restore point. Can't create / restore .
Hi Ok I borke world recored for formating windows 7 , the last 2 months . The problem is ; Windows System restore keep freezing , I'm not trying to do system restore , but when I try to install/remove a software , windows try to create restore point , making the installation/removing...
Backup and Restore
How to create a system restore point automatically?
I want to create system restore points everyday or every times the computer start...Does anybody know how to do it?
Backup and Restore
