Windows 7: System Restore Point : Create at System Startup
17 Feb 2014   #60
Peter Holland
Zuid-Holland
A few years later, but I hope you can help me.
When I click on the file in Explorer I get a system resore point. But when I make a task in Windows 8.1, Windows ask me what program I like to use for opening the vbs-file. I don't know what to answer.
17 Feb 2014   #61
charlestek
Win 8.1 Professional 64 bit, Win 7 Ultimate 64 biut
Peter, you want to chose "Windows Script Host", WSH, or maybe it will be termed "Windows-Based Script Host" (Wscript.exe) However, the task manager should not be asking you that, it is baked into the OS. On my Win 8.1 task manager, I do not get that question.
Some possible related links:
Fix: Windows Script Host access is disabled on this machine
Overview of Windows Script Host in Windows
17 Feb 2014   #62
Peter Holland
Zuid-Holland
When I choose for wcript.exe I don't get the question anymore, bit I don't see a new system restore point.
07 Sep 2014   #63
adamf
8.1 Pro x64
The script for task scheduler does not work in Windows 8. Based on System Restore Point Shortcut you need to take account of the SystemRestorePointCreationFrequency registry setting. Updated vbs is enclosed.
07 Sep 2014   #64
charlestek
Thank you adamf
Adamf,
Thanks. I will try your new script
02 Jan 2015   #65
sfwul
How to have a restore point created:
a. automatically
b. ONCE a day, at pc start (i.e. not at each restart)
c. automatic naming e.g. RP-ddmmyyyy-hhmmss
Thanks!
30 Jun 2015   #66
timw128
Windows 7 Pro SP1 x64
Thanks, BFK... excellent presentation. Extremely easy to comprehend without raising any internal 'what to do' questions.
15 Feb 2016   #67
mike326
Windows 10 pro 64 bit
Does not work in windows 10 with the task scheduler but the all the shortcuts work
can I get the restore to work when shutting down?? I have lost the start button 5 or 6 times the last time had to use restore to get it back
15 Feb 2016   #68
Brink
64-bit Windows 10 Pro
Hello Mike, and welcome to Seven Forums.
Please post back with screenshots showing your settings from METHOD TWO to see if anything may stand out.
15 Feb 2016   #69
mike326
System Restore Point : Create at System Startup-restore-1.jpg
System Restore Point : Create at System Startup-restore-2.jpg
System Restore Point : Create at System Startup-restore-3.jpg
System Restore Point : Create at System Startup-restore-4.jpg
System Restore Point : Create at System Startup-restore-5.jpg
System Restore Point : Create at System Startup-restore-6.jpg
System Restore Point - Create
How to Create a System Restore Point in Windows 7 By default in Windows 7 for all drives that System Protection is turned on for, System Protection creates a scheduled restore point only if no other restore points have been created in the last 7 days, and before significant system events such...
Tutorials
Windows 7 Cannot create System Restore Point
I just got done making a clean install on Windows 7 Ultimate 64-bit on a SSD drive. Then I noticed that whenever I was doing a System Update, it would try to create a restore point for many minutes and then give up and proceed with the update. Well, the bottom line is, I can't create a system...
Backup and Restore
Cannot create system restore point (0x80042302)
Been trying for about 3 days to create a restore point but the same message keeps popping up. "A volume shadow copy service component encountered an unexpected error. Check the application even log for more information." I currently have no access to Internet on my laptop and Windows 7...
Backup and Restore
How manually create a system restore point
Can't find how to manually create a system restore point
Backup and Restore
Windows 7 system restore point. Can't create / restore .
Hi Ok I borke world recored for formating windows 7 , the last 2 months . The problem is ; Windows System restore keep freezing , I'm not trying to do system restore , but when I try to install/remove a software , windows try to create restore point , making the installation/removing...
Backup and Restore
How to create a system restore point automatically?
I want to create system restore points everyday or every times the computer start...Does anybody know how to do it?
Backup and Restore
