Windows 7: System Restore Point : Create at System Startup
15 Feb 2016   #70
Brink
64-bit Windows 10 Pro
It looks like the problem may be that you have it set to run at startup instead of on a schedule.
By default, Windows will not run anything elevated at startup for security purposes.
If you like, see if using the tutorial below to create an elevated shortcut to run the .vbs file from your Startup folder may work instead.
30 Apr 2016   #71
betaupsilon
Windows 7 Home Prem 32 bit
If I use the TASK SCHEDULER to disable AUTO SYS RESTORE is it possible that it can revert back to enabling AUTO SYS RESTORE? I swear that this occurred on one of my machines since I like to do MANUAL creation of RESTORE PTS. Nonetheless, a new AUTO RESTORE PT showed up today & I inspected the TASK SCHEDULER & sure enough it was on.
If it can revert back is it possible to ensure that it will not?
30 Apr 2016   #72
Brink
Hello betaupsilon,
It's not unusual for a Windows Update to sometimes reset Windows settings.
30 Apr 2016   #73
betaupsilon
Quote   Quote: Originally Posted by Brink View Post
Hello betaupsilon,
I have WINDOWS UPDATE off as well. I do those manually.
Any other possibility?
This time I deleted all of the TRIGGERS so as to reduce the likelihood of AUTO RESTORE, but I am not convinced.
30 Apr 2016   #74
Brink
Were these Windows Backup or System Image restore points?
You could disable the task in Task Scheduler to see if that may help though.
01 May 2016   #75
betaupsilon
The new AUTO RESTORE PT was created by the TASK SCHEDULER which I was pretty sure I had disabled. That is why I ask if this DISABLE can be reverted somehow?
01 May 2016   #76
Brink
It shouldn't automatically enable itself again since it's a task you added.
01 May 2016   #77
betaupsilon
OK I guess I will have to be vigilant. I was pretty sure I had disabled it.
01 May 2016   #78
betaupsilon
Quote   Quote: Originally Posted by betaupsilon View Post
Hi Shawn,
I think I figured out what happened. I ran your Enable System Restore.reg tool sometime back. That apparently overwrites what I specify in the TASK SCHEDULER prior to executing that tool. I should have been more cognizant of that. NOW I AM.
THANX
01 May 2016   #79
betaupsilon
Shawn,
I know you have addressed the issue of losing RESTORE PTS in WindowsImageBackup. What about cloning, do the RESTORE PTS get preserved or not? I ran across the following link where someone mentioned this issue, and it seems they did not successfully transfer the RESTORE PTS to the clone.
Safest Way to Clone Windows 7 Volume for Dual Booting
I posted a question about this, but no one has responded as of yet. The thread is pretty old so I am not sure my question will get looked at. Do you have any knowledge on this? I am not attempting to have both the CLONE & the ORIGINAL system in a dual boot capacity which I think they were attempting. The above thread was the only reference I found on discussing RESTORE PTS & cloning.
System Restore Point - Create
How to Create a System Restore Point in Windows 7 By default in Windows 7 for all drives that System Protection is turned on for, System Protection creates a scheduled restore point only if no other restore points have been created in the last 7 days, and before significant system events such...
Tutorials
Windows 7 Cannot create System Restore Point
I just got done making a clean install on Windows 7 Ultimate 64-bit on a SSD drive. Then I noticed that whenever I was doing a System Update, it would try to create a restore point for many minutes and then give up and proceed with the update. Well, the bottom line is, I can't create a system...
Backup and Restore
Cannot create system restore point (0x80042302)
Been trying for about 3 days to create a restore point but the same message keeps popping up. "A volume shadow copy service component encountered an unexpected error. Check the application even log for more information." I currently have no access to Internet on my laptop and Windows 7...
Backup and Restore
How manually create a system restore point
Can't find how to manually create a system restore point
Backup and Restore
Windows 7 system restore point. Can't create / restore .
Hi Ok I borke world recored for formating windows 7 , the last 2 months . The problem is ; Windows System restore keep freezing , I'm not trying to do system restore , but when I try to install/remove a software , windows try to create restore point , making the installation/removing...
Backup and Restore
How to create a system restore point automatically?
I want to create system restore points everyday or every times the computer start...Does anybody know how to do it?
Backup and Restore
