System Restore Point : Create at System Startup
How to Automatically Create System Restore Points in Windows 7 and 8
The two (2) separate methods outlined herein make it very easy to have fresh, reliable System Restore points available for use whenever needed; whether created by a system startup/restart or created by the Windows Task Scheduler; once it's setup you never have to be concerned with it again, it's all completely automatic.​
System Restore isn't available for Windows RT.
Credit for this goes to our own Microsoft MVP and all around good guy Brink who wrote these "Restore Point" scripts, without whose dedication and hard work with the Windows Operating Systems none of this would even be possible. Thanks Shawn! :)
Please view his original tutorial for pertinent Windows 7 information .
Windows 7 System Restore Point Shortcut
This will also work with Windows Vista.
Please view the relevant tutorial at Vista Forums at the link below.
Vista System Restore Point Shortcut
For those of you that would like to have the option to create restore points without restarting the system have a look at step #4 A below to add a shortcut to the desktop or the taskbar that can be used whenever needed without a system restart.
Be sure to have a look at Method Two below to see the steps to use the Windows Task Scheduler to automatically create System Restore points, once the task is created there is nothing further to do, there will always be daily, fresh System Restore points available for use if needed, even if the PC is never restarted at all.
Let's get started!
Method One
System Startup / Restart
1) The first thing that needs done is to download the file you want to use; to create a restore point with a description click the button below and select to save the file to the desktop.
Restore_Point_Shortcut.zip file (with description)
Download
2) To create a restore point without a description click the button below and save the file to the desktop.
Instant_Restore_Point.zip file (without description)
Download
3) Open the downloaded zip file, extract (drag and drop) the VBS file to the desktop, and unblock the VBS file.
4) Navigate to "C:\Program Files" in Windows Explorer (not "Program Files (x86)" if you have 64-bit Windows), move the extracted and unblocked VBS file into the "C:\Program Files" folder, then close the "Program Files" window.
click any image to enlarge
5) Now in the start menu navigate to and r click the "Startup File" to open the "Startup" file window; now back at the "Restore_Point Shortcut" window r click the "Create System Restore Point" shortcut and click cut, then in the "Startup" window at an empty spot click paste. A) Now if you want a shortcut on the desktop to create a restore point whenever needed (without restarting the PC) r click the "Instant Restore Point" shortcut in the "Startup" window and select "Send to, Desktop (create shortcut)" to place a shortcut on the desktop.
6) You're done, now close all the windows and if you want, the zip and the restore point files that you downloaded can be deleted from the desktop.
To use the shortcut you just created.
7) Whenever the PC boots to the desktop the first prompt you'll get is "Do you want to open this file?" click open then enter your user credentials for the UAC prompt and click yes.
8) If you have chosen to use the restore point creator with a description this last snip is the last step in the process, enter the description you want to use and click ok to finish up, that's all there is to it. I use the one with no description and with 2 clicks at bootup it's done.
Method Two
1) Start by downloading this zip file to the Windows desktop.
Scheduled_Instant_Restore_Point.zip
Download
2) Open the downloaded zip file, extract (drag and drop) the VBS file to the desktop, and unblock the VBS file.
3) Navigate to "C:\Program Files" in Windows Explorer (not "Program Files (x86)" if you have 64-bit Windows), move the extracted and unblocked VBS file into the "C:\Program Files" folder, then close the "Program Files" window.
4) In the "Access Denied" dialog box that opens click Continue, if you get a UAC prompt, enter your user credentials and click Yes; then just close the Program Files window that opens.
You can now delete the downloaded Zip file from the desktop if you like.
Now in the Windows start menu search box type taskschd.msc and hit the <enter> key. In the Task Scheduler window that opens at the right pane Actions column, click Create Task.
5) In the "Create Task" window that opens at the General tab, give the new task a Name, a description is optional, dot "Run whether user ... " put a check/tic at "Run with highest ... " and "Configure for ... " your flavor Windows.
6) Now still in the "Create Task" window click the Triggers tab, at the bottom left click the New button, in the New Trigger dialog box that opens be sure to select when you want the task to run and the daily time you want it to run and click OK.
7) Now back at the "Create Task" window click the Actions tab, at the bottom left click the New button, in the New Action dialog box that opens click Browse (see #8 below), now browse to C:\Program Files and click the Instant_Restore_Point file you extracted there in step #2 above and click Open, then click the Instant_Restore_Point script and click Open again.
8) Now at the New Action dialog box that's still open click OK.
9) In the Create Task window that's still open click OK, in the Account Information dialog box that opens add your user credentials and click OK.
That's all, you are now finished and you can close the Task Scheduler.
Enjoy! :)
Another GREAT tutorial BFK! :D
Windows 7 Ultimate x64 SP1AMD Phenom II X4, 945, Quad Core, 3.0 GHz8GB G.Skill PI Black PC2 6400 * 4-4-4-12 @1.9vNVIDIA 512MB 9600GT
"WartHog Wonder"
Gigabyte MA785GM-US2H
NVIDIA 512MB 9600GT
Realtek ALC889A Chipset (onboard)
2 x 22" Hans-G LCD
650GB 7200RPM WD Caviar Black
OCZ 700w GameXstream
Cooler Master CM 690 Midtower
Xigmatek Gaia SD1283 CPU Cooler, Assorted 120mm case fans
Dell SK-8115
Microsoft Comfort Optical Mouse 3000
Liteon iHAS 424-98B 24x DVD/CD Writer
* BFK Customs *
W 7 64-bit Ultimate
Intel Q9550 Yorkfield
ASUS P5Q Pro
8GB Dominator 8500C5D
ATI : XFX 5870
Realtek HD Audio 7-1
1920x1080P & 1920x1200
Corsair 620HX
Cooler Master RC-690
Microsoft 500
Razer Diamondback 3G
14 Mb/s
Nice tutorial, good work :D
Windows 7 Ult x64 - SP1/ Windows 8 Pro x64Intel Core i5-3570K 4.6GHz8GB (2X4GB) DDR3 1600 Corsair Vengeance CL8 1.5vSapphire HD 7770 Vapor-X OC 1GB DDR5
76~2.0
Gigabyte GA-Z77X UD3H, f18
Onboard VIA VT2021
22" LCD Dell
Samsung 840Pro 128GB SSD,
Corsair HX650W
Cooler Master Storm Scout
Logitech Wave
CM Sentinel
Dismal
Opera Next
Desktop: eSATA ports,
External WD USB 500GB
* BFK Customs *
W 7 64-bit Ultimate
ASUS P5Q Pro
ATI : XFX 5870
Corsair 620HX
Microsoft 500
14 Mb/s
Wow Ted great work !!! Its very useful :thumbsup:
Windows 7 Ultimate - 64-bit | Windows 8 Pro -...Intel® Core™ i7 Processor 3,610QM (2.30Hz, 6M...8 GBNVIDIA® GeForce® GT 650M 2GB Graphics, Optimu...
Samsung NP550P5C-S02IN
Intel® Core™ i7 Processor 3,610QM (2.30Hz, 6MB L3 Cach
8 GB
NVIDIA® GeForce® GT 650M 2GB Graphics, Optimus™ techno
SoundAlive™ JBL 3 Speakers (With sub-Woofer)
39.62cm (15.6) SuperBright 300nit HD+ LED Display
1,600 x 900, Anti-Reflective
1TB S-ATA II Hard Drive (5,400RPM)
* BFK Customs *
W 7 64-bit Ultimate
ASUS P5Q Pro
ATI : XFX 5870
Corsair 620HX
Microsoft 500
14 Mb/s
Good one! I like the idea of automatically creating one. Thanks Ted.
Win 10 Pro x64
Intel I5-2500K @3.3GHz
Asrock P67 Extreme4
EVGA GeForce 750 Ti SC 2GB
auria eq2367
250GB Samsung 850 EVO SSD
1TB WD Blue
1TB Hitachi
SeaSonic X 650W 80 Plus Gold
Corsair Obsidian 750D
Logitech Wireless Mouse M310
Wave Broadband ~ 100 dn 5 up
Edge, IE11, Chrome
Laptop specs: HP g7-1365dx /
RAM: Crucial 8Gb (2x4Gb) /
GFX: AMD Radeon HD 6520G /
OS: Windows 10 Pro x64
* BFK Customs *
W 7 64-bit Ultimate
ASUS P5Q Pro
ATI : XFX 5870
Corsair 620HX
Microsoft 500
14 Mb/s
Thanks. worked perfect
Windows 7 Ultimate 64Bit SP1Intel Core 2 Quad Q9650 3GHZCorsair Dominator Twin CM2X2048 DDR2 1066 MHZ...Asus NVIDIA GTX 560 Ti DirectCU II
ASUS P5Q-E
Corsair Dominator Twin CM2X2048 DDR2 1066 MHZ 6GB
Creative Sound Blaster X-Fi Titanium Fatal1ty Pro
LG Flatron W2353V LCD HDMI Monitor
Seagate ST1000DM003-1ER162 (Z4Y6GDCA) 1TB SATAIII
Cooler Master Extreme 700 Watt (RS700-PCAAE3-US)
Thermaltake Soprano DX
Zalman CNPS9500A LED
Logitech Cordless Desktop® MX™ 5500 Revolution
Logitech® Bluetooth® MX™ Revolution Laser Mouse
Cable Modem 30MB
* BFK Customs *
W 7 64-bit Ultimate
ASUS P5Q Pro
ATI : XFX 5870
Corsair 620HX
Microsoft 500
14 Mb/s
Hello mate.
What happens if you click the shortcut in the "Startup" folder, does it create a restore point?
* BFK Customs *
W 7 64-bit Ultimate
ASUS P5Q Pro
ATI : XFX 5870
Corsair 620HX
Microsoft 500
14 Mb/s
Hello Carmine, at least you found the issue; thanks for posting back.
* BFK Customs *
W 7 64-bit Ultimate
ASUS P5Q Pro
ATI : XFX 5870
Corsair 620HX
Microsoft 500
14 Mb/s
* BFK Customs *
W 7 64-bit Ultimate
ASUS P5Q Pro
ATI : XFX 5870
Corsair 620HX
Microsoft 500
14 Mb/s
deleted !!!!!!!!!!!!!
thanks Ted !!!
windows 7 professional & ultimate 64bit laptops2.27 boost to 2.53 & 2.53 boost to 2.804GBIntel® Graphics Media Accelerator HD
Gateway/NV7923u & NV79C52u Laptops
Mobile Intel® HM55 Express Chipset ???
4GB
realtek High-definition audio support
17.3 " HD 1600 x 900
hatachi Travelstar 5400 500GB & west digital 500GB
35MB fios
* BFK Customs *
W 7 64-bit Ultimate
ASUS P5Q Pro
ATI : XFX 5870
Corsair 620HX
Microsoft 500
14 Mb/s
Thanks for that. Just one thing: Is it possible to assign permanent approval for the Startup script to be run, thus avoiding the ongoing need for permission? I have UAC set to "Ask me only when a prog wants to run.." and I'd rather keep it that way. Is there any way to set an individual permission for the file, so that it's independent of UAC control?
Win7 Ultimate SP1Intel Core i5 9400 Coffee Lake 14nm16G DDR4NVidia GeForce GTX 960
My build
Win7 Ultimate SP1
Asus Prime H310M-E R2.0 (LGA1151)
16G DDR4
Realtek High Definition Audio (mobo)
Asus PA248 24" 16:10 format
1920x1200@59Hz
1863GB Seagate ST2000DM
3726GB Seagate ST4000DM
6TB Seagate
465GB NVMe Samsung SSD 970
750G2
Tower
Standard
USB
USB
920Mbs/480Mbs
Malwarebytes
Hello and Welcome !
Check this article http://www.sevenforums.com/tutorial...ram-shortcut-without-uac-prompt-create-4.html
Captain
8 GB
Hello Teckneeculler,
See if using the tutorial below with the VBS shortcut that you want to use will allow it to run at startup without a UAC prompt.
http://www.sevenforums.com/tutorials/67503-task-create-run-program-startup-log.html
'Task - Create to Run a Program at Startup and Log On'
'Elevated Program Shortcut without UAC Prompt - Create'
Thanks guys, but I can't get either of those two methods to prevent the UAC prompt from asking permission to run "create_srp.vbs" at startup.
If other people here have been able to use the method to run an exe on startup, maybe it's an issue with the vbs file.
I think I'll just turn off UAC and be done with it.
Cheers :-)
http://www.sevenforums.com/11949-elevated-program-shortcut-without-uac-prompt-create-4.html
My build
Win7 Ultimate SP1
16G DDR4
1920x1200@59Hz
6TB Seagate
750G2
Tower
Standard
USB
USB
920Mbs/480Mbs
Malwarebytes
