System Restore Point : Create at System Startup
How to Automatically Create System Restore Points in Windows 7 and 8
The two (2) separate methods outlined herein make it very easy to have fresh, reliable System Restore points available for use whenever needed; whether created by a system startup/restart or created by the Windows Task Scheduler; once it's setup you never have to be concerned with it again, it's all completely automatic.​
System Restore isn't available for Windows RT.
Credit for this goes to our own Microsoft MVP and all around good guy Brink who wrote these "Restore Point" scripts, without whose dedication and hard work with the Windows Operating Systems none of this would even be possible. Thanks Shawn! :)
Please view his original tutorial for pertinent Windows 7 information .
Windows 7 System Restore Point Shortcut
This will also work with Windows Vista.
Please view the relevant tutorial at Vista Forums at the link below.
Vista System Restore Point Shortcut
For those of you that would like to have the option to create restore points without restarting the system have a look at step #4 A below to add a shortcut to the desktop or the taskbar that can be used whenever needed without a system restart.
Be sure to have a look at Method Two below to see the steps to use the Windows Task Scheduler to automatically create System Restore points, once the task is created there is nothing further to do, there will always be daily, fresh System Restore points available for use if needed, even if the PC is never restarted at all.
Let's get started!
Method One
System Startup / Restart
1) The first thing that needs done is to download the file you want to use; to create a restore point with a description click the button below and select to save the file to the desktop.
Restore_Point_Shortcut.zip file (with description)
Download
2) To create a restore point without a description click the button below and save the file to the desktop.
Instant_Restore_Point.zip file (without description)
Download
3) Open the downloaded zip file, extract (drag and drop) the VBS file to the desktop, and unblock the VBS file.
4) Navigate to "C:\Program Files" in Windows Explorer (not "Program Files (x86)" if you have 64-bit Windows), move the extracted and unblocked VBS file into the "C:\Program Files" folder, then close the "Program Files" window.
click any image to enlarge
5) Now in the start menu navigate to and r click the "Startup File" to open the "Startup" file window; now back at the "Restore_Point Shortcut" window r click the "Create System Restore Point" shortcut and click cut, then in the "Startup" window at an empty spot click paste. A) Now if you want a shortcut on the desktop to create a restore point whenever needed (without restarting the PC) r click the "Instant Restore Point" shortcut in the "Startup" window and select "Send to, Desktop (create shortcut)" to place a shortcut on the desktop.
6) You're done, now close all the windows and if you want, the zip and the restore point files that you downloaded can be deleted from the desktop.
To use the shortcut you just created.
7) Whenever the PC boots to the desktop the first prompt you'll get is "Do you want to open this file?" click open then enter your user credentials for the UAC prompt and click yes.
8) If you have chosen to use the restore point creator with a description this last snip is the last step in the process, enter the description you want to use and click ok to finish up, that's all there is to it. I use the one with no description and with 2 clicks at bootup it's done.
Method Two
1) Start by downloading this zip file to the Windows desktop.
Scheduled_Instant_Restore_Point.zip
Download
2) Open the downloaded zip file, extract (drag and drop) the VBS file to the desktop, and unblock the VBS file.
3) Navigate to "C:\Program Files" in Windows Explorer (not "Program Files (x86)" if you have 64-bit Windows), move the extracted and unblocked VBS file into the "C:\Program Files" folder, then close the "Program Files" window.
4) In the "Access Denied" dialog box that opens click Continue, if you get a UAC prompt, enter your user credentials and click Yes; then just close the Program Files window that opens.
You can now delete the downloaded Zip file from the desktop if you like.
Now in the Windows start menu search box type taskschd.msc and hit the <enter> key. In the Task Scheduler window that opens at the right pane Actions column, click Create Task.
5) In the "Create Task" window that opens at the General tab, give the new task a Name, a description is optional, dot "Run whether user ... " put a check/tic at "Run with highest ... " and "Configure for ... " your flavor Windows.
6) Now still in the "Create Task" window click the Triggers tab, at the bottom left click the New button, in the New Trigger dialog box that opens be sure to select when you want the task to run and the daily time you want it to run and click OK.
7) Now back at the "Create Task" window click the Actions tab, at the bottom left click the New button, in the New Action dialog box that opens click Browse (see #8 below), now browse to C:\Program Files and click the Instant_Restore_Point file you extracted there in step #2 above and click Open, then click the Instant_Restore_Point script and click Open again.
8) Now at the New Action dialog box that's still open click OK.
9) In the Create Task window that's still open click OK, in the Account Information dialog box that opens add your user credentials and click OK.
That's all, you are now finished and you can close the Task Scheduler.
Enjoy! :)
Using the Windows Task Scheduler
OK here's how to do it.
Just add the "Instant Restore Point" file to the "Program Files" folder, do not add the shortcut to the "Startup" file in the start menu.
Then type taskschd.msc in windows start menu search box and click the entry.
At the far right click "Create Task" in the first dialog box at the "General" tab.
click to enlarge
Then at the "Triggers" tab click the "New" button.
Now click the "Action" tab, in the "New Action" dialog box that opens browse to the Instant Restore Point file you placed in the Program Files folder and click ok.
Now click OK.
The last step is to enter your password to complete the process.
Please remember to post back to let me know if this works for you too. ;)
* BFK Customs *
W 7 64-bit Ultimate
Intel Q9550 Yorkfield
ASUS P5Q Pro
8GB Dominator 8500C5D
ATI : XFX 5870
Realtek HD Audio 7-1
1920x1080P & 1920x1200
Corsair 620HX
Cooler Master RC-690
Microsoft 500
Razer Diamondback 3G
14 Mb/s
Thanks anyway, but my method works just fine.
* BFK Customs *
W 7 64-bit Ultimate
ASUS P5Q Pro
ATI : XFX 5870
Corsair 620HX
Microsoft 500
14 Mb/s
Thanks for the modified instructions. Got a wee glitch, however. When I get to your fourth screen, (the 'Create Task' window, which shows the path to the vbs file) and click OK, I don't get the fifth screen, the Password box in which you've entered your username and password. All I get is a message that says:
"An error has occurred for task Instant Restore Point. Error message: User account restriction error. The possible reasons are that blank passwords are not allowed, or that a policy restriction has been enforced.
I'm unable to proceed further.
This PC has only one user (except for the hidden admin account, which isn't enabled) and I haven't made it necessary to enter a logon password. UAC is in effect, but at level 1, ie, not the bottom 'Never Notify' bar, but the first one up, the 'Notify me only when......(don't dim desktop). Win7 is Ultimate.
Any suggestions? :-)
Win7 Ultimate SP1Intel Core i5 9400 Coffee Lake 14nm16G DDR4NVidia GeForce GTX 960
My build
Win7 Ultimate SP1
Asus Prime H310M-E R2.0 (LGA1151)
16G DDR4
Realtek High Definition Audio (mobo)
Asus PA248 24" 16:10 format
1920x1200@59Hz
1863GB Seagate ST2000DM
3726GB Seagate ST4000DM
6TB Seagate
465GB NVMe Samsung SSD 970
750G2
Tower
Standard
USB
USB
920Mbs/480Mbs
Malwarebytes
I'm afraid the task won't be created if a password is not entered.
* BFK Customs *
W 7 64-bit Ultimate
ASUS P5Q Pro
ATI : XFX 5870
Corsair 620HX
Microsoft 500
14 Mb/s
Well, yes, I'm sure you're correct. But why am I not getting a password requester, as you evidently did?
My build
Win7 Ultimate SP1
16G DDR4
1920x1200@59Hz
6TB Seagate
750G2
Tower
Standard
USB
USB
920Mbs/480Mbs
Malwarebytes
Maybe you didn't do one of the steps correctly or if the user doesn't have a registered password it knows and won't complete; I don't have a definitive answer for you.
* BFK Customs *
W 7 64-bit Ultimate
ASUS P5Q Pro
ATI : XFX 5870
Corsair 620HX
Microsoft 500
14 Mb/s
I have now added a Method Two to this showing how to do this with the Windows Task Scheduler, I like that method better than Method One TBH; I hope some find it useful.
* BFK Customs *
W 7 64-bit Ultimate
ASUS P5Q Pro
ATI : XFX 5870
Corsair 620HX
Microsoft 500
14 Mb/s
Hi Ted just tried method two again on both 32-bit and 64-bit and worked perfectly! Thank you again.
Jerry
Sager NP9170
Win 7 Pro x64 / Win 10 Pro
CLEVO P170EM
12 GB
Backlite
MSE, Malwarebytes Pro
DESKTOP: Custom-built.
OS: Win 10 Pro x64.
CASE: Rosewill R5.
MOTHERBOARD: Asus Z87-A.
GPU: Nvidia Geforce 650 TI.
PSU: Corsair TX750.
Hello Jerry.
I'm pleased it worked for you; to me, Method Two is a better way than Method One. ;)
* BFK Customs *
W 7 64-bit Ultimate
ASUS P5Q Pro
ATI : XFX 5870
Corsair 620HX
Microsoft 500
14 Mb/s
Hello Jerry.
I agree sometimes I leave my computer on for days and wish I would have had a restore point now I will.
Jerry
Sager NP9170
CLEVO P170EM
12 GB
Backlite
OS: Win 10 Pro x64.
CASE: Rosewill R5.
PSU: Corsair TX750.
Brilliant tutotrial thank you
windows 7
windows 7
* BFK Customs *
W 7 64-bit Ultimate
ASUS P5Q Pro
ATI : XFX 5870
Corsair 620HX
Microsoft 500
14 Mb/s
Wunderbar!
Many thanks for this one. :thumbsup:
* BFK Customs *
W 7 64-bit Ultimate
ASUS P5Q Pro
ATI : XFX 5870
Corsair 620HX
Microsoft 500
14 Mb/s
VBS opens in Notepad
Hi, I followed the instructions wrt Instant restore point. But when I click on the desktop shortcut it opens in a notepad.
Pl. halp/advice me how to correct the anamoly.
Also, i am a novice and have just started using Win 7 Ultimate 64 bit OS. My sytem is an Dell laptop 6420. Thank.
Win 6 Ultimate 64 bit
Dell 6420
Hello futuristic6, welcome to Seven Forums!
When you open the Start Menu / Startup File like in the snip below, what do you see?
Is the "Create System Restore Point" shortcut there, like in Step #4 of the tutorial?
click to enlarge
* BFK Customs *
W 7 64-bit Ultimate
ASUS P5Q Pro
ATI : XFX 5870
Corsair 620HX
Microsoft 500
14 Mb/s
Hello Futuristic, and welcome to Seven Forums.
It sounds like your VBS file extension association may be messed up. Download and merge the VBS option in the tutorial below to see if the Instant restore point works afterwards. :)
http://www.sevenforums.com/tutorials/19449-default-file-type-associations-restore.html
Issues with System restore
I can now create automatic system restore. But I have an irritating problem.
Whenever I shutdown and reboot my laptop, Everytime, I need to remerge the default VBS file. Is there a way I can solve the problem permanently?
I also noticed that when I go "Open with"and go to "other programs" the option stating "always use this program to open this kind of file is greyed out"and I cannot check thsi option.
I use win 7 64 bit OS.
Thanks for all the help.
Dell 6420
Hello Futuristic,
Unless you really have a need to create a restore point at every startup, I wouldn't recommend doing this since it will use up all of your max restore space faster and delete older restore points faster.
Did you unblock the VBS file?
What are you using "Open with" on, and where are you using it at (ex: in Default Programs or right clicking on file)?
