 | | Welcome to Windows 7 Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows 7. The Windows 7 forum also covers news and updates and has an extensive Windows 7 tutorial section that covers a wide range of tips and tricks. | Windows 7 - System Restore Point : Create at System Startup
System Restore Point : Create at System Startup How to Automatically Create System Restore Points
Published by Bare Foot Kid
02-27-2010
| System Restore Point : Create at System Startup How to Create System Restore Points with a Restart or Windows Task Scheduler The two (2) separate methods outlined herein make it very easy to have fresh, reliable System Restore points available for use whenever needed; whether created by a system startup/restart or created by the Windows Task Scheduler; once it's setup you never have to be concerned with it again, it's all completely automatic.  Note Credit for this goes to our own Microsoft MVP and all around good guy Brink who wrote these "Restore Point" scripts, without whose dedication and hard work with the Windows Operating Systems none of this would even be possible. Thanks Shawn!
Please view his original tutorial for pertinent Windows 7 information . Windows 7 System Restore Point Shortcut
This will also work with Windows Vista.
Please view the relevant tutorial at Vista Forums at the link below. Vista System Restore Point Shortcut  Information For those of you that would like to have the option to create restore points without restarting the system have a look at step #4 A below to add a shortcut to the desktop or the taskbar that can be used whenever needed without a system restart.
Be sure to have a look at Method Two below to see the steps to use the Windows Task Scheduler to automatically create System Restore points, once the task is created there is nothing further to do, there will always be daily, fresh System Restore points available for use if needed, even if the PC is never restarted at all. Let's get started!
Method One System Startup / Restart 1) The first thing that needs done is to download the file you want to use; to create a restore point with a description click the button below and select to save the file to the desktop. Restore_Point_Shortcut.zip file (with description)
2) To create a restore point without a description click the button below and save the file to the desktop. Instant_Restore_Point.zip file (without description)  3) Now r click the zip file on the desktop, and select "Extract All" and you'll get a window like this below, leave that window open and navigate to "C:\Program Files" in Windows Explorer (not "Program Files (x86)" if you have 64-bit Windows). At the "Restore_Point Shortcut" file window r click the "Restore Point Shortcut" file and click cut, now in the "Program Files" window click an empty spot and click paste. Then close the "Program Files" window.click any image to enlarge   4) Now in the start menu navigate to and r click the "Startup File" to open the "Startup" file window; now back at the "Restore_Point Shortcut" window r click the "Create System Restore Point" shortcut and click cut, then in the "Startup" window at an empty spot click paste. A) Now if you want a shortcut on the desktop to create a restore point whenever needed (without restarting the PC) r click the "Instant Restore Point" shortcut in the "Startup" window and select "Send to, Desktop (create shortcut)" to place a shortcut on the desktop.  5) You're done, now close all the windows and if you want, the zip and the restore point files that you downloaded can be deleted from the desktop. To use the shortcut you just created. 6) Whenever the PC boots to the desktop the first prompt you'll get is "Do you want to open this file?" click open then enter your user credentials for the UAC prompt and click yes.click any image to enlarge   7) If you have chosen to use the restore point creator with a description this last snip is the last step in the process, enter the description you want to use and click ok to finish up, that's all there is to it. I use the one with no description and with 2 clicks at bootup it's done.
Method Two Windows Task Scheduler
Start by downloading this zip file to the Windows desktop.
Brink_Task.zip
 1) Right click the zip file and click Extract All, in the window that opens click the Browse button.click any image to enlarge  2) In the dialog box that opens browse to and click to highlight/select C:\Program Files and click OK, not Program Files (x86) if you are using 64-bit Windows; then click Extract in the window that's still open. 3) In the "Access Denied" dialog box that opens click Continue, if you get a UAC prompt, enter your user credentials and click Yes; then just close the Program Files window that opens.
You can now delete the downloaded Zip file from the desktop if you like. Now in the Windows start menu search box type taskschd.msc and hit the <enter> key. In the Task Scheduler window that opens at the right pane Actions column, click Create Task. 4) In the "Create Task" window that opens at the General tab, give the new task a Name, a description is optional, dot "Run whether user ... " put a check/tic at "Run with highest ... " and "Configure for ... " your flavor Windows.click any image to enlarge  5) Now still in the "Create Task" window click the Triggers tab, at the bottom left click the New button, in the New Trigger dialog box that opens be sure to select when you want the task to run and the daily time you want it to run and click OK. 6) Now back at the "Create Task" window click the Actions tab, at the bottom left click the New button, in the New Action dialog box that opens click Browse (see #7 below), now browse to C:\Program Files and click the Instant_Restore_Point file you extracted there in step #2 above and click Open, then click the Instant_Restore_Point script and click Open again.click any image to enlarge   7) Now at the New Action dialog box that's still open click OK. 8) In the Create Task window that's still open click OK, in the Account Information dialog box that opens add your user credentials and click OK.
That's all, you are now finished and you can close the Task Scheduler. Enjoy!
|  Published by | | Original Team Member Join Date: Jun 2008 Location: The Lowcountry Posts: 23,809 | |
 Tutorial Tools | | | | | | | | | |
02-27-2010
#1 | | Windows 7 Ultimate x64 SP1 |
Another GREAT tutorial BFK! | My System Specs | | System Manufacturer/Model Number "WartHog Wonder" OS Windows 7 Ultimate x64 SP1 CPU AMD Phenom II X4, 945, Quad Core, 3.0 GHz Motherboard Gigabyte MA785GM-US2H Memory 8GB G.Skill PI Black PC2 6400 * 4-4-4-12 @1.9v Graphics Card NVIDIA 512MB 9600GT Sound Card Realtek ALC889A Chipset (onboard) Monitor(s) Displays 2 x 22" Hans-G LCD Screen Resolution 1680x1050 Keyboard Dell SK-8115 Mouse Microsoft Comfort Optical Mouse 3000 PSU OCZ 700w GameXstream Case Cooler Master CM 690 Midtower Cooling Xigmatek Gaia SD1283 CPU Cooler, Assorted 120mm case fans Hard Drives 1 500GB & 1 650GB 7200RPM WD Caviar Black Other Info Liteon iHAS 424-98B 24x DVD/CD Writer |
02-27-2010
#2 | | |
Quote: Originally Posted by WartHog Another GREAT tutorial BFK!
Thanks Beau! | My System Specs | | System Manufacturer/Model Number * BFK Customs * OS W 7 64-bit Ultimate CPU Intel Q9550 Yorkfield Motherboard ASUS P5Q Pro Memory 8GB Dominator 8500C5D Graphics Card ATI : XFX 5870 Sound Card Realtek HD Audio 7-1 Monitor(s) Displays 1x 47" LCD HDMI & 3x 26" LCD HDMI Screen Resolution 1920x1080P & 1920x1200 Keyboard Microsoft 500 Mouse Razer Diamondback 3G PSU Corsair 620HX Case Cooler Master RC-690 Cooling Tuniq Tower 120, 2x 140mm and 3x 120mm case fans Hard Drives 1x 80GB Intel X25-M G2 SSD : 1x 500GB & 1x 640GB WD Caviar Black(s) Internet Speed 14 Mb/s Other Info 1x Koutech 3Gb/s SATA HDD Hot Swap Rack |
03-01-2010
#3 | | Windows 7 Ult x64 - SP1/ Windows 8 Dev Build x64 |
Nice tutorial, good work | My System Specs | | System Manufacturer/Model Number 76~1.4 OS Windows 7 Ult x64 - SP1/ Windows 8 Dev Build x64 CPU Intel Core i5-750 3.84GHz Motherboard Gigabyte GA-P55A-UD4P, SATA 6Gb/s USB 3, f14 Memory 8GB (2X4GB) DDR3 1600 Corsair Vengeance CL8 1.5v Graphics Card XFX HD 5770 1GB DDR5 Sound Card Realtek HD Audio ALC889 Integrated Chip Monitor(s) Displays 22" LCD Dell Screen Resolution 1680x1050 Keyboard Logitech Wave Mouse CM Sentinel PSU Corsair HX650W Case Cooler Master Storm Scout Cooling Corsair H80 2x12cm Noctua NF P12 , 2x14cm case fans Hard Drives Intel X25 M 120GB SSD,
Seagate Barracuda 500GB SATA2 7200rpm 32MB cache, Seagate Barracuda 1TB SATA2 7200rpm 32MB cache, Internet Speed Dismal Other Info eSATA ports,
External USB WD 500GB |
03-01-2010
#4 | | |
Quote: Originally Posted by Dave76 Nice tutorial, good work
Thanks Dave! | My System Specs | | System Manufacturer/Model Number * BFK Customs * OS W 7 64-bit Ultimate CPU Intel Q9550 Yorkfield Motherboard ASUS P5Q Pro Memory 8GB Dominator 8500C5D Graphics Card ATI : XFX 5870 Sound Card Realtek HD Audio 7-1 Monitor(s) Displays 1x 47" LCD HDMI & 3x 26" LCD HDMI Screen Resolution 1920x1080P & 1920x1200 Keyboard Microsoft 500 Mouse Razer Diamondback 3G PSU Corsair 620HX Case Cooler Master RC-690 Cooling Tuniq Tower 120, 2x 140mm and 3x 120mm case fans Hard Drives 1x 80GB Intel X25-M G2 SSD : 1x 500GB & 1x 640GB WD Caviar Black(s) Internet Speed 14 Mb/s Other Info 1x Koutech 3Gb/s SATA HDD Hot Swap Rack |
03-01-2010
#5 | | Windows 7 Ultimate, Ubuntu 10.04 LTS - the Lucid Lynx |
Wow Ted great work !!! Its very useful | My System Specs | | System Manufacturer/Model Number Custom Build OS Windows 7 Ultimate, Ubuntu 10.04 LTS - the Lucid Lynx Motherboard Asus A8N-VM Memory 2 GB Graphics Card Nvidia GeForce 6150 Sound Card Sound Blaster Audigy 24-Bit Monitor(s) Displays Samsung SyncMaster 2253LW 21.6" Widescreen LCD Monitor Hard Drives 320 GB - Internal
1 TB WD External |
03-01-2010
#6 | | |
Quote: Originally Posted by Capt.Jack Sparrow Wow Ted great work !!! Its very useful
Thank you very much Cap'n! | My System Specs | | System Manufacturer/Model Number * BFK Customs * OS W 7 64-bit Ultimate CPU Intel Q9550 Yorkfield Motherboard ASUS P5Q Pro Memory 8GB Dominator 8500C5D Graphics Card ATI : XFX 5870 Sound Card Realtek HD Audio 7-1 Monitor(s) Displays 1x 47" LCD HDMI & 3x 26" LCD HDMI Screen Resolution 1920x1080P & 1920x1200 Keyboard Microsoft 500 Mouse Razer Diamondback 3G PSU Corsair 620HX Case Cooler Master RC-690 Cooling Tuniq Tower 120, 2x 140mm and 3x 120mm case fans Hard Drives 1x 80GB Intel X25-M G2 SSD : 1x 500GB & 1x 640GB WD Caviar Black(s) Internet Speed 14 Mb/s Other Info 1x Koutech 3Gb/s SATA HDD Hot Swap Rack |
03-01-2010
#7 | | |
Good one! I like the idea of automatically creating one. Thanks Ted. | My System Specs | | System Manufacturer/Model Number compaq sr5410f case OS Windows 7 Pro 64 SP1 CPU AMD X2 4450E @ 2.3 ghz Motherboard Biostar MCP6P M2+ Memory 4.0 g Graphics Card Nvidia GeForce 9600 GT , 512mb Sound Card onboard Monitor(s) Displays auria eq2367 Screen Resolution 1920 x 1080 Keyboard logitech wave cordless Mouse logitech LX8 cordless laser mouse PSU 250 watts Case compaq Cooling couple fans Hard Drives 1 tb Hitachi HDT721010SLA scsi, 500 gb external Internet Speed comcast hi speed 19 dn 8 up Other Info hauppauge win tv hvr 1600 tv card, media center remote |
03-01-2010
#8 | | |
Quote: Originally Posted by derekimo Good one! I like the idea of automatically creating one. Thanks Ted.
Thanks mate, glad you find it useful! | My System Specs | | System Manufacturer/Model Number * BFK Customs * OS W 7 64-bit Ultimate CPU Intel Q9550 Yorkfield Motherboard ASUS P5Q Pro Memory 8GB Dominator 8500C5D Graphics Card ATI : XFX 5870 Sound Card Realtek HD Audio 7-1 Monitor(s) Displays 1x 47" LCD HDMI & 3x 26" LCD HDMI Screen Resolution 1920x1080P & 1920x1200 Keyboard Microsoft 500 Mouse Razer Diamondback 3G PSU Corsair 620HX Case Cooler Master RC-690 Cooling Tuniq Tower 120, 2x 140mm and 3x 120mm case fans Hard Drives 1x 80GB Intel X25-M G2 SSD : 1x 500GB & 1x 640GB WD Caviar Black(s) Internet Speed 14 Mb/s Other Info 1x Koutech 3Gb/s SATA HDD Hot Swap Rack |
07-04-2010
#9 | | |
System Restore Point | My System Specs | | OS Windows 7 Pro 32Bit SP1 CPU Intel Core 2 Duo E8600 3.33 GHZ Motherboard ASUS P5Q-E Memory Corsair Dominator Twin CM2X2048 DDR2 1066 MHZ 4GB Graphics Card MSI N275GTX Twin Frozr OC 896 Sound Card Creative Sound Blaster X-Fi Titanium Fatal1ty Pro Monitor(s) Displays LG Flatron W2353V LCD HDMI Monitor Screen Resolution 1920x1080 Keyboard Logitech Cordless Desktop® MX™ 5500 Revolution Mouse Logitech® Bluetooth® MX™ Revolution Laser Mouse PSU Cooler Master Extreme 700 Watt (RS700-PCAAE3-US) Case Thermaltake Soprano DX Cooling Zalman CNPS9500A LED Hard Drives Seagate ST3500320NS 500GB SATAII (2) Internet Speed Cable Modem 15MB System Restore Point : Create at System Startup problems? All times are GMT -5. The time now is 02:30 AM. |  |
