System Image Recovery
How to Do a System Image Recovery in Windows 7
This will show you how to restore your Windows 7 hard disk back to exactly how it was when you created a system image backup.
   Warning
  • You can only do a system image recovery to a HDD that is the same size or larger than the one the system image was created from. You will not be able to do a system image recovery to a smaller HDD.
  • When you restore your computer from a image backup, it is a complete restoration. You can't choose individual items to restore, and all of your current programs, system settings, and files are replaced.
  • If your backup image is on a external device (ex: USB drive), then make sure it is connected before starting. If USB drive, then also make sure that you have your BIOS settings (ex: Legacy USB) set to allow USB devices at boot.
  • A system image recovery will format everything on each hard drive that was included in a system image, and will only restore what is included (see steps 7-9 in STEP TWO below) in the system image back. Be sure to backup anything that you do not want to lose that is not included in the system image backup first.
STEP ONE
Only if You Renamed the "WindowsImageBackup" Folder
To be able to have multiple versions of system images saved on the same drive or partition, you would need to rename the older WindowsImageBackup folder from the previously created system image as described in the NOTE box at the top of this tutorial.
If you renamed the WindowsImageBackup folder for the system image version that you wanted to restore, then you will need to do the steps below before you will be able to restore that system image.
1. If you are "Able to Boot" into Windows 7 A) In Windows Explorer, navigate to the renamed (drive letter)\WindowsImageBackup folder location of the system image that you want to restore.
B) If you already have a folder named WindowsImageBackup that is not the system image version that you want to restore, then you will need to right click on it, click on Rename, and type in say WindowsImageBackup-Copy-2 as an example.
C) Now, right click on the renamed system image version (ex: WindowsImageBackup-Copy-1) that you did want to restore, click on Rename, type in WindowsImageBackup an press enter.
D) Go to the STEP TWO section below to do the System Image Recovery.
2. If you are "Not Able to Boot" into Windows 7 A) If you have the system image backup save to an external device, be sure that it is connected now.
B) Open a command prompt at boot.
C) In the command prompt, type diskpart and press enter. (see screenshot below)
D) In the command prompt, type list volume and press enter. (see screenshot below)
E) Make note of the drive letter (ex: E: ) that you have the system image backup saved to.
F) In the command prompt, type exit and press enter. (see screenshot below)
G) In the command prompt, type the E: and press enter. (see screenshot below)
NOTE: Subsititute E: for your actual drive letter at step 2E instead.
H) If you already have a folder named "WindowsImageBackup"
NOTE: This is if you already have a folder named WindowsImageBackup that is not the system image version that you want to restore. If so, you would need to rename it to say WindowsImageBackup-Copy-2 as an example.
  • In the command prompt, type the command below and press enter. (see screenshot below)
    NOTE: Substitute WindowsImageBackup-Copy-2 in the command below with any name in quotes that you would like to rename it to instead.
[B]ren WindowsImageBackup "[COLOR=red]WindowsImageBackup-Copy-2[/COLOR]"[/B]
I) In the command prompt, type the command below and press enter. (see screenshot below)
NOTE: Substitute WindowsImageBackup-Copy-1 in the command below with the actual name of your renamed system image folder in quotes that you want to use to restore instead.
[B]ren "[COLOR=red]WindowsImageBackup-Copy-1[/COLOR]" WindowsImageBackup[/B]
J) Close the command prompt window. (see screenshot below)
K) Continue on to step 3B in the STEP TWO section below to do the System Image Recovery.
STEP TWO
To Do the System Image Recovery
1. If you have the system image backup save to an external device, be sure that it is connected and turned on (powered up) now.
A) Start with either step 2 or step 3 below first.
2. From "Backup and Restore" in the Control Panel while in Windows 7 A) Open the Control Panel (icons view), and click on Backup and Restore.
B) Click on the Recover system settings on your computer link. (see screenshot below) Step1.jpg
C) Click on the Advanced recovery methods link. (see screenshot below) Step2.jpg
D) Select the Use a system image you created earlier to recover your computer option. (see screenshot below) Step3.jpg
E) Select to either create a Back up now, or to Skip it and continue the system image recovery without backing up any of your current files.
NOTE: If you select Back up now, it will take you to step 6 in this tutorial link to create a User and System File back up of your current files first before continuing to step 1F. (see screenshot below) Step4A.jpg
G) Select a languange to be used for your keyboard input and click on Next. (see screenshot below) Step6.jpg
H) Go to step 4.
3. From the System Recovery Options Screen at Boot A) Boot to the System Recovery Options screen from your Windows 7 installation DVD/USB, or System Repair Disc.
B) Select the System Image Recovery option. (see screenshot below) System_Recovery_Options.jpg
4. If you saved the system image backup to a set of DVDs, then insert the last DVD from the set when prompted. If not, go to step 5 for a system image backup on a hard drive. A) Go to step 7 below.
5. To Use the Latest System Image A) Select (dot) Use the latest available system image and click on Next. (see screenshot below) Step7.jpg
B) Go to step 7.
6. To Select a System Image A) Select (dot) Select a system image, and click on Next. (see screenshot above)
NOTE: This is if the system image that you want to use is not listed here and is at another location that you wish to choose from instead.
B) Select the location of the backup image for the computer you want to restore from the list, and click on Next. (see screenshot below)
To add a image from a network location, click on the Advanced button, and on the Search for a system image on the network option.
If the drive cannot be seen to select a system image from, then you may need to use the tutorial below to load your SATA or RAID drivers before it will be seen. You would click on the Advanced button, and on the Install a driver option.
SATA Drivers - Load in Windows 8 System Image Recovery
C) Select the date and time of the system image to restore, and click on Next. (see screenshot below) Step8B.jpg
7. To Do a Full System Image Recovery
NOTE: This option will format everything on each hard disk drive that was included in the system image, then restore them as they were when the system image was created.
Format and repartition disks box:
NOTE: Special thanks to MJF for this addition. 1) Grayed out and selected
You are forced to have the whole disk formatted and repartitioned to match the partition structure of the disk the image was made from. This can occur when restoring an image to a new disk or the original disk with a modified partition structure. Data on other partitions on the disk you are restoring to will be lost.
2) Grayed out and unselected
You are not given the option to format and repartition the disk. This will occur if you are restoring Windows from a partition on the same disk.
3) Not grayed out and unselected
Here you have the option to select format the whole disk and repartition or not. In this case the disk the image was taken from has a matching partition structure to the disk you are restoring the image to. By not selecting the format and repartition option your image will be restored and other partitions untouched such as valuable data partitions.
A) Check the Format and repartition disks box (if not grayed out) and uncheck Only restore system drives box (if available), and click on Next. (see screenshots below) Exclude_Disks.jpg
B) Go to step 10.
8. To Only Restore System Drives in System Image Recovery
NOTE: When restoring to the same disk containing data partitions, the Format and repartition disks option may format the data partitions as well. If this is the case and you have the option to leave the Format and repartition disks box unchecked, then initially attempt your image recovery with the Format and repartition disks box unchecked. If recovery is unsuccessful, repeat the process with the format box ticked. A) If available, check the Only restore system drives box, and click on Next. (see screenshot below) System_Drives.jpg
B) Go to step 10.
9. To Exclude Restoring Specific Drives in System Image Recovery
NOTE: Since a system image recovery will format everything on each hard disk drive that was included in a system image, this will allow you to exclude specific disks so that specific disk will not be formated or restored. A) Check the Format and repartition disks box , and click on the Exclude disks button (if not grayed out). (see screenshot below)
NOTE: If the Exclude disks button is grayed out, then the HDD that you are restoring to is empty, or you do not have any disks in the system image that are able to be excluded from being restored. Exclude 001.JPG
B) Unselect the drives that you want to exclude from being restored.
C) Click on Next.
12. You will now see this screenshot below.
NOTE: If you have the backup image on DVDs, have them ready. See step 4 above. Step12.jpg
13. When it is through, click on Restart Now to finish. (see screenshot below)
NOTE: Your computer will restart and the backup image restoration will be done. Step13.jpg
14. If you created a backup in step 1E, then you will now see this option to Restore my files after the computer restarts. (see screenshot below) Step14.jpg
Well I'd figured as much, but I had already taken the HDDs out and couldn't be bothered having to go through it all again just to get the restore to work. I will remember next time. I was able to get my files out of the incremental backups.
I have same problem, and tried moving before googling and finding this site.:cry:
But I preserved previous HDD partition, so trying to shrink the original boot partition.
Main HDD : 300GB, 56 Used
reserved new HDD : 160GB
Unfortunately, disk manager says 'You can save only 110GB for fragmentation of disk' so I treat it first.
So boring...
Finally, I failed.
Thought I tried to shrink my boot volume under 120GB, it has limitation in 170GB.
Some reasons i don't know make it impossible to shrink.
I'm reinstalling all systems.
Is it possible to restore the image to a completely different hard drive? Right now my 7 Ultimate is running on a 200GB WD drive. I think the drive is starting to fail and ordered a 640gb WD. Will I be able to create an image on a store drive and restore it to the new hard drive?
Seven Ultimate x64Intel Core2Duo E6550 2.9Ghz4gb Corsair XMS2 DDR1000PNY 8800GT 512mb SLI
Custome
Seven Ultimate x64
eVGA 680i SLI
Creative X-Fi Gamer
Viewsonic VX2235WM
Seasonic s12 650w
Antec Nine Hundred
Logitech G5
Hello R3G,
Yes you sure can. :)
Do I need to reinstall windows 7 on the new drive before restoring it or can I load the image after the drive has been formatted?
Custome
Seven Ultimate x64
eVGA 680i SLI
Creative X-Fi Gamer
Viewsonic VX2235WM
Seasonic s12 650w
Antec Nine Hundred
Logitech G5
As long as the saved system image backup is located in the original location, you can restore Windows 7 on the new drive without having to install Windows 7 first by using the tutorial on the first page.
Sweet just wanted to verify that. Thanks!
Custome
Seven Ultimate x64
eVGA 680i SLI
Creative X-Fi Gamer
Viewsonic VX2235WM
Seasonic s12 650w
Antec Nine Hundred
Logitech G5
You're welcome. :)
Hi Shawn,
Does that mean if the image is moved - it might not be recognized?
Or, if there is a change to partitions - so the image location appears different - it also may not be picked up ?
    7 X64i5 84002x8gb 3200mhz
    7 X64
    i5 8400
    gigabyte b365m ds3h
    2x8gb 3200mhz
    various
    pure power 11 400w cm
    Coolermaster
    cryorig m9i
    7x64g54008gb ddr4 2400
    7x64
    g5400
    ga b365m ds3h
    8gb ddr4 2400
    xfx pro 450w
Hi Shawn,
As long as the backup itself is not moved or copied to another location, it should work just fine. When the image backup folder is manually moved or copied to say another hard drive, then it may not be recognized when trying to restore it from the new location.
Thought that may be the case. Could be a problem there.
It was also like that with Vista Backup - a lot of people in all kinds of trouble.
    7 X64
    i5 8400
    gigabyte b365m ds3h
    2x8gb 3200mhz
    various
    Coolermaster
    cryorig m9i
    7x64
    g5400
    ga b365m ds3h
    8gb ddr4 2400
    xfx pro 450w
What kind?
Custome
Seven Ultimate x64
eVGA 680i SLI
Creative X-Fi Gamer
Viewsonic VX2235WM
Seasonic s12 650w
Antec Nine Hundred
Logitech G5
There are a lot - I mean a lot of posts about the image not being recognised - even when it is clearly visible to the operator. Restore is then not possible.
I suspect it happens if the location of the image appears to be in a different location - perhaps due to repartitioning, or adding another Hd, etc.
I haven't really used Windows System Image - except just quickly - apart from the reliability question - it is just not flexible enough for me.
Some people may find it does all they need. I think it's a good idea MS included it.
It seems to be there so the average Joe - who has never heard of making an image - will do so when prompted. They won't need any fancy functions - and are unlikely to start making changes to their systems that will confuse it.
I don't imagine for a second MS are trying to outdo Paragon and Acronis.
They are providing basic functionality.
Good for them.
MS also provide a very nice app. called Paint. Many will be happy with that. Anyone who takes that kind of thing seriously- or as an interest - is clearly going to use something more capable.
    7 X64
    i5 8400
    gigabyte b365m ds3h
    2x8gb 3200mhz
    various
    Coolermaster
    cryorig m9i
    7x64
    g5400
    ga b365m ds3h
    8gb ddr4 2400
    xfx pro 450w
Hi Shawn ,
How do you get it to pick up a different Image?
Selecting Different image doesn't help here. It just shows the images you have made with it's own function.
I can't see a way to Browse to a vhd created by another app. e.g. Paragon, and restore that.
Also, how do you select a different Target to restore the image to?
I guess if you removed the original HD and put a new one in it's place - it would restore to the New one - thinking it was the old.
Also, I imaged only my second partition. Would it have restored to the second partition, or would it have restored to the HD - i.e. to the lower address spaces, overwriting the first partition?
Very unclear as to what it would do.
Thanks.
    7 X64
    i5 8400
    gigabyte b365m ds3h
    2x8gb 3200mhz
    various
    Coolermaster
    cryorig m9i
    7x64
    g5400
    ga b365m ds3h
    8gb ddr4 2400
    xfx pro 450w
Hi SIW,
Answers in-line. Hope this helps. :)
If you have more than one incremental system image saved to the same location, or have say a separate hard drive with a different system image attached before step 1, then you should be able to see them listed after selecting Restore a different backup.
You cannot use the normal restore method in Windows 7 to restore a different program's image backup. That program would have to be used instead to restore it's image backup. However, you might be able to use the same methods in these tutorials.
How to Extract Files from Windows 7 System Image using Virtual PC
How to Extract Windows 7 System Image Files Using Disk Management
By default, it will always restore the system image backup to the same drive and partition letters that were selected when the system image was created. (C: drive and System Reservered partitions by default + whatever else was selected)
When the system image is restored with that backed up, it will wipe out your current second partition and restore it as it was in the system image backup instead.
Hi Shawn ,
Thanks - Paragon is perfectly capable of restoring/extracting files from any vhd images.
Just curious if one could make Paragon vhd' s- then use the restore function of Windows Sys Img - obviously, it refuses to do that.
You can do it the other way - Paragon AR will pick up any vhd you browse to.
How do you get Win Sys Img to restore the image to a different HD?
    7 X64
    i5 8400
    gigabyte b365m ds3h
    2x8gb 3200mhz
    various
    Coolermaster
    cryorig m9i
    7x64
    g5400
    ga b365m ds3h
    8gb ddr4 2400
    xfx pro 450w
The only way that you could get a Windows System Image to restore to a different drive is to only have a hard drive that you want to restore it to connected with only the drive that contains the backup. Now if the backup is just located on different partition on the same C: hard disk, then it will still replace the current C: partition though.
Thanks.
That's a shame - it can't do most of the things I would want an image program to do.:(
There doesn't seem to be any way of just imaging a partition of choice, either.
It seems to always want to image the System and Boot partition - you can add others - but I can't see a way of doing them individually.
    7 X64
    i5 8400
    gigabyte b365m ds3h
    2x8gb 3200mhz
    various
    Coolermaster
    cryorig m9i
    7x64
    g5400
    ga b365m ds3h
    8gb ddr4 2400
    xfx pro 450w
No, unfortunately the C: (system) drive and System Reserved partition will be backup by default and cannot be changed. I guess they did it since these would have to be backed up for the restored image to work though.
If you need a basic image backup, then the included one in Windows 7 works fine for this. Only a 3rd party program will give you more advanced features and options. :(
Thanks Shawn,
The fact you can't select which partition to image - and you can't select where to restore it to - is really limiting.
    7 X64
    i5 8400
    gigabyte b365m ds3h
    2x8gb 3200mhz
    various
    Coolermaster
    cryorig m9i
    7x64
    g5400
    ga b365m ds3h
    8gb ddr4 2400
    xfx pro 450w
It's a good fist step from MS to include this feature, I hope they expand it's functionality. I'm having troubles like someone discribed here already. I want to make an image and put it on a different HDD, but if the new HDD is smaller then the original it won't work.
I don't want to make it smaller en create a new image etc. Trying a 3th party program for this.
