#230
Which method are you following?This tutorial does not work for me.
If I pick the " Select a System Image” rather than use the recommended latest one, I get an error message stating that the system image is on a hard disk but Windows need to format that disk to restore your computer.
Everything works fine when I select the select the recommended latest system image but not when I select one of the older system images.
The images were created in the Windows 7 Backup & Restore utility and I'm running the image restore from the System Recovery disk.
I have 2 internal hard drives. The system images of the primary drive were stored on the secondary drive. And now I'm trying to restore the primary drive system image.
Any suggestions?
Josh
