Windows Virtual PC - Connect Virtual Machine to Network
    How to Connect Windows Virtual PC to the Network
    This will show you how to connect Windows Virtual PC to your network so that your created virtual machine or XP Mode will be able to access the internet.
    For more information, see: Networking in Windows Virtual PC - Windows Virtual PC - Site Home - TechNet Blogs
       Warning
    You will need to be logged in as an administrator to be able to do this tutorial.
    Here's How:
    1. Open the created or XP Mode virtual machine in Windows Virtual PC that you want to connect to the network.
    2. On the virtual machine's menu bar, click on Tools.
    A) If you see Disable Integration Features, then go to step 5. (see screenshot below)
    B) If you see Install Integration Features, then go to step 3. (see screenshot below)
    C) If you see Enable Integration Features, then go to step 4. (see screenshot below)
    3. To Install Integration Features in Windows Virtual PC
    A) Click on Install Integration Components. (see screenshot below step 2B)
    B) Follow steps 15 to 20 here (click on link) to finish installing.
    C) When finished, continue on to step 4.
    4. To Enable Integration Features in Windows Virtual PC
    A) Click on Enable Integration Components. (see screenshot below step 2C)
    B) Log on using the user name and password for the virtual machine. (see screenshots below)
    NOTE: If you do not see the user name for you virtual machine, then click on Use another account to enter the user name and password and click on OK.
    C) When finished, continue on to step 5.
    5. To Enable "Virtual PC Network Filter Driver" in Windows 7
    NOTE: This step is to be done in your host Windows 7 computer and not in the virtual machine in Windows Virtual PC.
    A) Open the Control Panel (icons view), then click on the Network and Sharing Center icon.
    B) In the Network and Sharing Center, click on the Change adapter settings link on the left side. (see screenshot below)
    Windows Virtual PC - Connect Virtual Machine to Network-network_sharing_center.jpg
    C) Right click on your internet network connection, and click on Properties. (see screenshot below)
    NOTE: Make note of the network adapter name (ex: Marvel Yukon....). You will need to know this in step 7B below.
    Windows Virtual PC - Connect Virtual Machine to Network-network_connections_uac.jpg
    D) If prompted by UAC, then click on Yes.
    E) If not already, check the Virtual PC Network Filter Driver box, and click on OK. (see screenshot below)
    Windows Virtual PC - Connect Virtual Machine to Network-connection_properties.jpg
    F) Close the Network Connections window. (see screenshot below step 5C)
    6. If you Use a Router with "MAC Address Filtering" Enabled
    If you do not, then skip this step and go to step 7 instead.
    If you do, then this step will show you how to get the MAC address of the virtual machine in Windows Virtual PC so you can add it to the MAC Filtering Rules of your router to allow the virtual machine access through the router.
    A) In the virtual machine, open a command prompt and type ipconfig /all (space after g) and press enter.
    B) In the command prompt, look for the MAC address (ex: 00:03:ff:1e:03:57) to the right of Physical Address. Write this MAC address number down. (see screenshot below)
    C) In your Windows 7 computer (not virtual machine), open your web browser (ex: Internet Explorer) and log in to your router.
    NOTE: You would usually do this by typing in your router's IP address in the web browser's address bar and pressing enter. Consult your router's manual to see what it's default IP address is.
    D) Go to your router's Network Filter settings, and add the virtual machine's MAC address (step 6B) to the MAC Filtering Rules and save it. (see screenshot below)
    NOTE: This is for a D-Link router, but this will vary depending on what brand and model of router you have. Consult your router's manual on how to enter the MAC address.
    E) You can now close the web browser in your Windows 7 computer (not virtual machine).
    F) Close the command prompt in the virtual machine. (see screenshot below step 6B)
    G) Continue on to step 7.
    7. To Set the Virtual Machine Network Settings
    A) On the virtual machine's menu bar, click on Tools and Settings.
    B) In the left pane, select Networking, then select your network adapter name (step 5C above) from the drop down box and click on OK. (see screenshot below)
    NOTE: If you have more than one network adapter available and you do not know which one to select, then test using each one until you have a connection.
    C) Continue on to step 8.
    8. Select the Network location type you want for the virtual machine to have the settings for that location automatically applied. (see screenshot below)
    9. The virtual machine in Windows Virtual PC should now be able to connect to your network and access the internet from it.
  1. Posts : 17,545
    Windows 10 Pro x64 EN-GB
    Very good tutorial. Thanks for taking the time to make it.
    Kari
  2. Posts : 72,051
    Thank you Kari. :)
  3. Posts : 3
    Windows 7 Premium Home 64bit
    still coming in useful to this day! Thank you.
  4. Posts : 72,051
    You're most welcome mawds. I'm glad to hear it was helpful to you. :)
  5. Posts : 1,962
    Windows 7 x64 (Ultimate)
    Brink, awesome tutorial as always... more so at this moment that I am going through such a nightmare with my vhd.
  6. Posts : 72,051
    Glad it could help Daniel. :)
  7. Posts : 132
    Dual boot - Win 7 Pro 64-bit and Win 10 Pro 64-bit
    Brink - Today, for the first time, the Shared Networking (NAT) setting did NOT permit my XP Mode to connect to the internet.
    So I increased the number of network adapters to 2 and added the Intel 82579LM NIC in my hardware that contains the Win 7 Pro host. XP Mode now also connects to the internet.
    But ... what happened?
    What happened to block the original Shared Networking (NAT)?
    My gateway router does NOT do MAC address filtering for wired PCs (including this 7 + XP Mode machine) - only for WiFi.
    Now, with only the Shared Networking (NAT) on (with the #2 NIC temporarily turned off), ipconfig /all in XP Mode shows that the Gateway is 192.168.131.254. However, when I point the XP Mode browser at that IP, I get nothing.
    By the way, my external Gatweay is 192.168.1.1, and its DHCP range does not include 192.168.131 anything, so I am concluding that 192.168.131.254 is generated inside my Win 7 host.
    Anyway, Shared Networking (NAT) is no longer working, but it used to.
    Thoughts? Thanks.
  8. Posts : 72,051
    Hello glnz, :)
    Did you make any changes to anything before this happened?
    You might see if adjusting the DHCP range of the router to include the IP address of the VM may let it connect with the NIC #1 again.
  9. Posts : 132
    Brink - thanks for fast response
    No changes that I can think of today. As soon as I turned on XP Mode, the NAT connection didn't work and I couldn't do much.
    When I increased the number of network cards to 2 and added the Intel NIC, then the XP Mode connected to the outside world and I ran a bunch of updates in XP Mode - XP itself and Avast AV.
    I don't particularly want to add 192.168.131.xx to my actual outside router as a new DHCP range. (Not sure that I can.) Anyway, that should not be relevant to connecting in Shared Networking (NAT), right?
    Might something in my Win 7 Pro host no longer accept connections from the XP Mode's Shared Networking (NAT)? I think - not sure - that the Win 7 is supposed to "be" that 192.168.131.254 "Gateway", right? Any particular reason why it might stop? Is there any way for me to check on the Win 7 side?
