Windows 7: System Restore Point - Create
03 Apr 2011   #40
Brink
64-bit Windows 10 Pro
Quote   Quote: Originally Posted by hollyoaks777 View Post
Quote   Quote: Originally Posted by Brink View Post
Hello Hollyoaks,
This may work better for you for this instead.
System Restore Point : Create at System Startup
I will try that way later mate thank you. Just another question in the triggers window I have 2 triggers to run at start up and they are both at the same time 10am. Should I have 2 or 1?
You're welcome Holly.
It really just depends on if you wanted one created for each trigger or just one of the triggers. If just one, then you can just delete the other trigger. Please let us know how it went.
13 Jun 2011   #41
FredeGail
Microsoft Windows 7 Ultimate: x64 (SP1)
Thanks for this tutorial!
I noticed it's doing this automatically sometimes, and my computer will have a little delay on opening different types of Software (Windows Update took 5 sec for me to open), is it usual that the performance will slow a liiiiittle bit down while Windows is creating a restore point?
Best Regards,
FredeGail
13 Jun 2011   #42
Hopalong X
Quote   Quote: Originally Posted by FredeGail View Post
Best Regards,
FredeGail
You should let Windows create Restore points then do your other tasks.
Just let it finish Restore points and System Images before doing added tasks a lot less likely that an error will occur in the Image/Restore point.
Mike
Didn't realize you were on Brink.
13 Jun 2011   #43
Brink
Hello FredeGail,
Depending on how powerful your system is, it wouldn't be unusual to notice a bit of a performance drop while a restore point is being created.
14 Jun 2011   #44
FredeGail
Hello FredeGail,
It's probably a refer to my memory is DDR2, due to my board doesn't support the new technology, DDR3.
- Which I'm defiantly annoyed about
I'm making image backups of the system, and saving it on the D:/ drive (non-windows-disk).
Quote   Quote: Originally Posted by Hopalong X View Post
Best Regards,
FredeGail
Mike
Defiantly, but it's such a small things as.. let's say.. opening Windows Update. But it's a no problem
Best Regards,
FredeGail
EDIT; OH MY GOSH, I have a badge! This is soooo big! Thanks to aaaall supporters!!
01 Dec 2012   #45
georgescarlett
64
Schedule Daily Create Restore Point
I want to automatically create a restore point at 6 pm everyday. I managed to do it via help from this forum about 18 months ago. However my laptop was stolen last week and I have forgotten what I did - my new laptop is running Win7 Home Premium. Can someone please advise on what is now regarded as the easiest way to schedule the daily back up?
01 Dec 2012   #46
mitchell65
01 Dec 2012   #47
Brink
Hello George,
In addition, you might see if this may be able to help as well for a more customizable option.
28 May 2014   #48
SypherLocke
Windows 7 Professional 64 Bit
If you go to the search bar in the windows menu that pops up when you press the windows key and type, "create restore" a link will appear that will send you right to the "Create Restore Point" screen.
Just a tip to skip a few steps.
10 Oct 2015   #49
artinusa
Windows 7 64 bit
I have used elevated see if all shadow copies is working and its allocated space. I note that no matter what size I set the allocated amouint is zero..is this the problem..maybe or is this normal. see attached elevated results
System Restore Point - Create-shadow-coppy-availability.jpg System Restore Point - Create-restore-10-set-before-adjustment.jpg System Restore Point - Create-restore-resized.jpg
Unable to create system image or restore point
I currently can't make a system image or restore point. The error I receive for the system image attempt is: The backup failed. Windows Backup timed-out before the shared protection point was created. (0x80780021) Additional Information: The creation of a shadow copy has timed out. ...
Backup and Restore
Windows 7 Cannot create System Restore Point
I just got done making a clean install on Windows 7 Ultimate 64-bit on a SSD drive. Then I noticed that whenever I was doing a System Update, it would try to create a restore point for many minutes and then give up and proceed with the update. Well, the bottom line is, I can't create a system...
Backup and Restore
Cannot create system restore point (0x80042302)
Been trying for about 3 days to create a restore point but the same message keeps popping up. "A volume shadow copy service component encountered an unexpected error. Check the application even log for more information." I currently have no access to Internet on my laptop and Windows 7...
Backup and Restore
How manually create a system restore point
Can't find how to manually create a system restore point
Backup and Restore
Windows 7 system restore point. Can't create / restore .
Hi Ok I borke world recored for formating windows 7 , the last 2 months . The problem is ; Windows System restore keep freezing , I'm not trying to do system restore , but when I try to install/remove a software , windows try to create restore point , making the installation/removing...
Backup and Restore
How to create a system restore point automatically?
I want to create system restore points everyday or every times the computer start...Does anybody know how to do it?
Backup and Restore
