System Restore Point - Create
How to Create a System Restore Point in Windows 7
By default in Windows 7 for all drives that System Protection is turned on for, System Protection creates a scheduled restore point only if no other restore points have been created in the last 7 days, and before significant system events such as a program or driver installation.
For more information about restore points, see:
This tutorial will show you how to manually create a restore point whenever you want one.
These restore points contain information about registry settings and other system information that Windows 7 uses. System Restore points do not include the personal user files.
You will not be able to create a restore point in safe mode since it is not supported.
If you do a System Restore when the computer is in safe mode, then you cannot undo the restore operation. However, you can run System Restore again and choose a different restore point if one exists.
   Warning
System Protection will need to be turned on for the select drive that you wish to create a restore point for.
It has been reported that some 3rd party disk defragmentation programs could also delete your restore points when used.
OPTION ONE
Using a Shortcut
1. For how, see: How to Make a "Create System Restore Point" Shortcut in Windows 7
OPTION TWO
Through System Protection
1. Open the Control Panel (icons view).
A) Click on the System icon.
B) Go to step 3.
OR
2. Open the Start Menu.
A) Right click on the Computer button and click on Properties.
3. Click on the System Protection link. (See screenshot below step 4)
4. Close the System window. (See screenshot below)
5. Check to make sure that you have System Protection turned on for a listed disk that you want to create a restore point for, then select it. (See screenshot below step 6)
6. Click on the Create button. (See screenshot below)
7. Type in a description for the restore point to help recognize it when doing a System Restore, and click on the Create button.. (See screenshot below)
8. You will now see this while the restore point is being created. (See screenshot below)
9. When the restore point has finished being created, click on the Close button. (See screenshot below)
10. Click on OK. (See screenshot below step 6)
Ubuntu,Mandriva,PCLOS,XP and,Windows 7AMD Athlon 64 X2 Dual Core 42004 GBNVIDIA GeForce
Custom Low Rider !!
NVIDIA GeForce
Onboard
22" Acer Wide Screen
1280x1024
WD 1 TB Caviar Black 7200 RPM
F-12 cooled
Saitek Eclipse
Logitech invisible optic wireless
Broadband
Smoaky,
Well you can adjust the existing System Restore task for this, but it will only create one if it detects a change to the system.
If you want each time no matter what, then you could create a task to run the instanst create restore point shortcut instead. Option One in METHOD TWO of the tutorial below can help show you how to if needed. :)
Startup Programs - Enable or Disable - Vista Forums
Cool,
I will give that a try.:D
Wondering why MS cant just create a restore point every calendar day when boot-up occurs no matter what? Sure that will take up some disk space but we all could adjust that according to our needs as an option. :confused:
Custom Low Rider !!
NVIDIA GeForce
Onboard
1280x1024
F-12 cooled
Saitek Eclipse
Broadband
Yep, creating one everyday no matter what would use up the maximum disk storage space set and cause the older restore points to be automatically deleted faster. Normally you would only want to create one before making a change to your system to preserve the older restore points as long as possible in case you needed to go back that far.
Thanks!!!!
Your an admin...what do you think should be the best solution to restore points IYHO ??
Does Vista/W7 has the best answer or what?:huh:
Custom Low Rider !!
NVIDIA GeForce
Onboard
1280x1024
F-12 cooled
Saitek Eclipse
Broadband
It really depends on your specific needs, but I would recommend to leave the default restore point task as is and only manually create a restore point right before you make changes to your system to be safe. For example, before installing Windows Updates, drivers, programs, etc.....
Of course, creating good backups of any files that you do not want to lose is always best as well. ;)
System Restore could not start
recently I instated a cracked version of Win7 ultimate 32bit. letter I discovered that no system protection at all as you see at the attached photos.
I tray to do my best to do something can fix this problem but no result at all, so could you please help me to find a solution?
thanks in advance
Windows7 Ultimate 32bit-version 6.1.7600 Bult
Toshiba satellite A200 1MB
intel(R) core(TM)cpu T5300 @ 1.73GHz
Hello Freiheit, and welcome to Seven Forums.
Sorry, but the only thing that can fix this is to uninstall (format) the cracked version and install a legal copy that has not been broken by a hack. :(
Cool, now after I create the restore point, how do I access it again?
Thanks.
Windows 7 Professional x64
Hello GWT,
If needed, you can do a system restore to select a restore point to go back to.
What I plan to do is this. I want to clone my Win7 HD with a bigger HD and I want to install Acronis on it in order to facilitate the transfer.
And the end of the cloning process and after I physically install the new HD, I want to revert to that cloned restore point to back before I installed Acronis so it won't be on my new machine. That way I don't have to do an un-install of it and a registry clean up.
Does that make sense?
GWT,
As long as the clone backup includes the restore point, you should still be able to do a system restore using that restore point in that manner.
Shawn you might want to update the bit at the beginning about how often a restore pint is created. It is once every 7 days if one hasn't been created by another means,
Restore Points (Windows)
Scheduled restore points
System Restore can be configured to create restore points at regular intervals. Users can also manually create and name a restore point at any time from within the System Restore user interface. These restore points are saved and compressed, and these choices are available to the user through the System Restore user interface. System Restore in Windows 7 creates a scheduled restore point only if no other restore points have been created in the last 7 days. System Restore in Windows Vista creates a checkpoint every 24 hours if no other restore points were created that day. System Restore in Windows XP creates a checkpoint every 24 hours of absolute time.
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
Thank you Storm. Updated. :)
You're welcome. Only posted it due to a thread about SR and remembered seeing that it was 7 days, so went looking and one of the things found in addition to the above Technet link was this tutorial. :)
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
Nice to know since I normaly only create one myself before I install new software just in case I don't want to keep it I can remove it and then use my restore point to go back also.Fabe
Windows 7 ultimate 64 bit / XP Home sp3intel Core 2 Duo E8400 3.0ghz8 gigs 1066 OCZ Fata1tyEVGA GTX 580 Call of Duty Black Ops Edition
Asus P5ND bios 1401
Asus 24in LCD's 2MS X2
1920x1080p @60Hz
OCZ 700W GameXtreme
NZXT Apollo
Download 19.83 Upload 0.97
great thanx ive tryed it and works
windows 7
windows 7
Hello Smoaky,
You can adjust or disable the System Restore tasks to create automatic restore points as you like. If you disable them, then Windows 7 will not create any automatic restor points. Either way. you are always free to manually create a restore point when you like.
Hi Brink in the link above on the jpeg 6 i don't have the option of 365 days I was wondering if I have done something wrong. I want to do daily restore points on start up. It says 23 hours in mine also in the general tab should I tick run with highest privileges
windows 7
windows 7
windows 7
windows 7
