System Restore Point - Create
Page 4 of 6 FirstFirst ... 23456 LastLast
  1. GWT
    Windows 7 Professional x64
       #30
    What I plan to do is this. I want to clone my Win7 HD with a bigger HD and I want to install Acronis on it in order to facilitate the transfer.
    And the end of the cloning process and after I physically install the new HD, I want to revert to that cloned restore point to back before I installed Acronis so it won't be on my new machine. That way I don't have to do an un-install of it and a registry clean up.
    Does that make sense?
  2. Posts : 72,049
       #31
    GWT,
    As long as the clone backup includes the restore point, you should still be able to do a system restore using that restore point in that manner.
  3. Posts : 6,879
    Win 7 Ultimate x64
       #32
    Shawn you might want to update the bit at the beginning about how often a restore pint is created. It is once every 7 days if one hasn't been created by another means,
    Restore Points (Windows)
    Scheduled restore points
    System Restore can be configured to create restore points at regular intervals. Users can also manually create and name a restore point at any time from within the System Restore user interface. These restore points are saved and compressed, and these choices are available to the user through the System Restore user interface. System Restore in Windows 7 creates a scheduled restore point only if no other restore points have been created in the last 7 days. System Restore in Windows Vista creates a checkpoint every 24 hours if no other restore points were created that day. System Restore in Windows XP creates a checkpoint every 24 hours of absolute time.
  4. Posts : 72,049
       #33
    Thank you Storm. Updated. :)
  5. Posts : 6,879
    Win 7 Ultimate x64
       #34
    You're welcome. Only posted it due to a thread about SR and remembered seeing that it was 7 days, so went looking and one of the things found in addition to the above Technet link was this tutorial. :)
  6. Posts : 4,280
       #35
    Nice to know since I normaly only create one myself before I install new software just in case I don't want to keep it I can remove it and then use my restore point to go back also.Fabe
  7. Posts : 4
    windows 7
       #36
    great thanx ive tryed it and works
  8. Posts : 340
    windows 7
       #37
    Brink said:
    Hello Smoaky,
    You can adjust or disable the System Restore tasks to create automatic restore points as you like. If you disable them, then Windows 7 will not create any automatic restor points. Either way. you are always free to manually create a restore point when you like.
    Hi Brink in the link above on the jpeg 6 i don't have the option of 365 days I was wondering if I have done something wrong. I want to do daily restore points on start up. It says 23 hours in mine also in the general tab should I tick run with highest privileges
  9. Posts : 72,049
       #38
    Hello Hollyoaks,
    This may work better for you for this instead.
    System Restore Point : Create at System Startup
  10. Posts : 340
    windows 7
       #39
    Brink said:
    Hello Hollyoaks,
    I will try that way later mate thank you. Just another question in the triggers window I have 2 triggers to run at start up and they are both at the same time 10am. Should I have 2 or 1?
