System Restore Point - Create
Page 2 of 6 FirstFirst 1234 ... LastLast
  1. Posts : 72,050
    Yeah, it was the same with Vista since XP had a different way of doing things causing this.
  2. Posts : 75
    Ubuntu,Mandriva,PCLOS,XP and,Windows 7
    I will boot into XP in a few minutes and see how it goes
    Come to think of it I remember having that prob when I had a dual boot of Vista and XP. Always thought it was a glitch in Vista... Never really was happy with Vista and I guess I was always looking for an excuse to stop using it. I even got to the point that I removed Vista and was running a dual boot of XP and Linux Mandriva. Then.......the clouds disappearednd the sun came out and ...behold....Windows 7 ascended from the heavens and now I am happy again and I no longer have the need for Prozac....
  3. Posts : 72,050
       #12
    LOL.
  4. Posts : 75
    What do you suggest that I use as a default setting in "System Protection"?
    1.) Restore system settings and previous versions of files
    or
    2.) Only restore previous versions of files?
  5. Posts : 72,050
       #14
    Hello Smoaky,
    System settings would be for System Restore, and previous versions of files would be for the shadow copy Previous Versions feature.
    For the best protection, #1 would be best. :)
  6. Posts : 75
       #15
    Thanks Shawn
    I have mine set at #1 as per your suggestion.
    Just expanded my W7 partition size and lost all my restore points
    Oh well. time to create a manual restore point and go from there.
  7. Posts : 72,050
       #16
    You're welcome Smoaky.
    You might use this to make manually creating restore points easier to do. :)
    System Restore Point Shortcut
  8. Posts : 75
       #17
    Pretty cool and it works great
    Got it working on my laptop now I have to do this on my other two desktops.
    (off topic)
    Any word on your end about MS's "new" Anti- Virus named "Microsoft Security Essentials"?
    I heard it will be available Tue June, 23rd for beta testing.
    Sounds as though some people have already been testing it .
  9. Posts : 34
    Win 7, Home Premium
       #18
    Thanks for this tutorial. Essential for our security if something goes wrong.
    regards,
  10. Posts : 72,050
       #19
    You're welcome Bjs53. :)
    Smoaky, I have only heard the same thing about it. It does sound interesting though. :)
