Windows 7: System Restore Point - Create
How to Create a System Restore Point in Windows 7
Published by Brink
26 Nov 2008
information   Information
By default in Windows 7 for all drives that System Protection is turned on for, System Protection creates a scheduled restore point only if no other restore points have been created in the last 7 days, and before significant system events such as a program or driver installation.
For more information about restore points, see: This tutorial will show you how to manually create a restore point whenever you want one.
Note   Note
These restore points contain information about registry settings and other system information that Windows 7 uses. System Restore points do not include the personal user files.
You will not be able to create a restore point in safe mode since it is not supported.
If you do a System Restore when the computer is in safe mode, then you cannot undo the restore operation. However, you can run System Restore again and choose a different restore point if one exists.
warning   Warning
System Protection will need to be turned on for the select drive that you wish to create a restore point for.
It has been reported that some 3rd party disk defragmentation programs could also delete your restore points when used.
System Restore Point - Create OPTION ONE System Restore Point - Create
Using a Shortcut
1. For how, see: How to Make a "Create System Restore Point" Shortcut in Windows 7
System Restore Point - Create OPTION TWO System Restore Point - Create
Through System Protection
1. Open the Control Panel (icons view).
A) Click on the System icon.
B) Go to step 3.
OR
2. Open the Start Menu.
A) Right click on the Computer button and click on Properties.
3. Click on the System Protection link. (See screenshot below step 4)
4. Close the System window. (See screenshot below)
5. Check to make sure that you have System Protection turned on for a listed disk that you want to create a restore point for, then select it. (See screenshot below step 6)
6. Click on the Create button. (See screenshot below)
7. Type in a description for the restore point to help recognize it when doing a System Restore, and click on the Create button.. (See screenshot below)
8. You will now see this while the restore point is being created. (See screenshot below)
9. When the restore point has finished being created, click on the Close button. (See screenshot below)
10. Click on OK. (See screenshot below step 6)
22 May 2009   #1
Charles Kane
Windows 7 Ultimate, Ubuntu
Noticed that I'm not getting the 12am System restore point, nor the significant driver update restore point (I installed the Win7 Nvidia drivers today, no restore created) - seem to have a few generated by installing programs - again not Nvidia.
Is there a simple way to get the dailies or should I use Task Scheduler?
22 May 2009   #2
Brink
64-bit Windows 10 Pro
Hello Charles,
I'm not sure why Windows 7 would not have created a restore point automatically for that. You can use this though to easily create one automatically whenever you wanted to though.
System Restore Point Shortcut
23 May 2009   #3
Charles Kane
Appreciate that tutorial - i did go in and do it manually and I'll probably grab the shortcut and put it in my documents or somewhere - don't need the desktop clutter.
Guess I'll have to learn how to make a new task!............
Well, I made a new task using your vbs script as the program!
Had a bit of an issue with permissions but finally it accepted my task.
Set to run in half an hour. We'll see.
Thanks again for the script
UPDATE: all worked fine
23 May 2009   #4
Brink
You're welcome Charles.
09 Jun 2009   #5
smoaky
Ubuntu,Mandriva,PCLOS,XP and,Windows 7
All this seems to be very unnecessary.
Why cant W7 just auto create restore points similar to XP instead of all of us go thru all this modification?
I am dual booting XP and W7 and was confused as to why restore points kept disappearing. Now I know.
My question is : does anyone know if this creation of a restore point only if none has been made in 7 days will be included in the GA of W7?
I hope not. I think an option to turn off this feature so that you would be able to automatically create regular/daily restore points would be more sensible.
Am I the only one that feels this way??
09 Jun 2009   #6
Brink
Hello Smoaky,
You can adjust or disable the System Restore tasks to create automatic restore points as you like. If you disable them, then Windows 7 will not create any automatic restor points. Either way. you are always free to manually create a restore point when you like.
09 Jun 2009   #7
smoaky
Quote   Quote: Originally Posted by Brink View Post
Hello Smoaky,
I have read the how-to on this a while ago but I am running a dual boot of XP and every time I boot to XP all my previously saved restore points in W7 get deleted. Each time I boot to W7 I would have to start all over again creating restore points. Kinda makes having system restore useless...yes? Seems as though MS doesn't want anyone to run no other OS but W7.
09 Jun 2009   #8
Brink
Not a problem Smoaky. You can use the tutorial below to hide Windows 7 from XP to stop XP from wiping out W7's restore points.
System Restore Points - Stop XP Dual Boot Delete - Vista Forums
09 Jun 2009   #9
smoaky
update
Just found the How-to on stopping XP from deleting Vista/W7 restore points.
I guess my point is seems like alot of work. MS is trying to make W7 as compatible as possible sure would have been nice for them to have thought about the people wanting to dual boot and keep us all from having to mess with the registry to accomplish this.
Unable to create system image or restore point
I currently can't make a system image or restore point. The error I receive for the system image attempt is: The backup failed. Windows Backup timed-out before the shared protection point was created. (0x80780021) Additional Information: The creation of a shadow copy has timed out. ...
Backup and Restore
Windows 7 Cannot create System Restore Point
I just got done making a clean install on Windows 7 Ultimate 64-bit on a SSD drive. Then I noticed that whenever I was doing a System Update, it would try to create a restore point for many minutes and then give up and proceed with the update. Well, the bottom line is, I can't create a system...
Backup and Restore
Cannot create system restore point (0x80042302)
Been trying for about 3 days to create a restore point but the same message keeps popping up. "A volume shadow copy service component encountered an unexpected error. Check the application even log for more information." I currently have no access to Internet on my laptop and Windows 7...
Backup and Restore
How manually create a system restore point
Can't find how to manually create a system restore point
Backup and Restore
Windows 7 system restore point. Can't create / restore .
Hi Ok I borke world recored for formating windows 7 , the last 2 months . The problem is ; Windows System restore keep freezing , I'm not trying to do system restore , but when I try to install/remove a software , windows try to create restore point , making the installation/removing...
Backup and Restore
How to create a system restore point automatically?
I want to create system restore points everyday or every times the computer start...Does anybody know how to do it?
Backup and Restore
