Windows 7: System Restore
04 Jul 2012   #90
Brink
64-bit Windows 10 Pro
Yeah, sometimes it may take a bit for a manual restore point to show up, but it'll be there.
Creating manual restore points is helpful because Windows 7 may not always create one for you automatically. For example, manually create a restore point before editing the registry since Windows 7 will not create one for this.
12 Apr 2013   #91
mickeyg2008
windows 7
restore on windows 7
Set up my laptop to do a restore. Computer went to restart and is timing out on the shutting down page. How do I stop it without disrupting the restore ? Thanks
12 Apr 2013   #92
Brink
Hello Mickey,
Do you have any 3rd party AV programs installed that may be interfering with it?
You could go ahead and hard restart the computer. It'll most likely give you a failed system restore message, but you might see if you may be able to do a system restore at boot instead.
12 Apr 2013   #93
mickeyg2008
windows 7
I bet I do.. how do I do a hard restart? Interrupt the power source ?
12 Apr 2013   #94
Brink
You should be able to press and hold the power button in until it hard shuts down (powers off), then press the power button again to power back up.
12 Apr 2013   #95
mickeyg2008
windows 7
It is allowing me to undo the restore I tried to do and set a new point for restore . What AV programs do I need to disable before I do the restart?
12 Apr 2013   #96
Brink
It depends on what AV program is installed.
Some common ones: Norton, McAfee, Kaspersky, etc....
12 Apr 2013   #97
mickeyg2008
windows 7
Brink, I know it is my diagnostic policy service is not working. Can you tell me how to get that working again please.
12 Apr 2013   #98
mickeyg2008
windows 7
OK. I was able to undo the restore. My computer was working before I uninstalled some programs yesterday. I see in the list if events in the restore that there were numerous critical updates I was not aware of. Should I take the restore to the first windows update on the 8th or to the time I uninstalled the first program?
12 Apr 2013   #99
Brink
I'd try a restore point dated before this started to see if it may help. If not, then try an older restore point.
 System Restore
System restore doesn't show any restore points - but they exist
After Tuesday's Windows update I couldn't boot into Windows and loaded my system repair disk planning to roll back to a restore point from the day before. But, the restore wizard couldn't find any restore points. I know my system does it daily and I did a manual one a week prior just to see if it...
Backup and Restore
Allocated System Restore space holds far fewer restore points now
I have 8gb of space allocated to System Restore, all monitoring my C partition only. This space is always at least 85-90% used according to the System Protection screen. In the past I have had at least 15 restore points to choose from after ticking "show more restore points." But today I went to...
Backup and Restore
System Restore Has Stopped Automatically Creating Restore Points
My last automatically System Restore Point automatically created by the passage of time was created 2013-01-23. No further automatic system restore points are being created (that means not ever, not daily, not weekly, simply no longer created automatically by the passage of time since last...
Backup and Restore
System Restore - Restore system settings and previous versions of file
estore system settings and previous versions of file is greyed out on my system, I may have disabled a required service for this, can anyone point me to the right direction for this? As I'm about to try the X-Fi MB2 mod again as the last time I tried it my system was messed up that it wont even...
Backup and Restore
Black screen with pointer after System Restore and no Restore Tools
Hi, this looks like the right place but apologies if not, first time posting and all. I've been trying all day to resolve a networking issue and eventually decided to do a system restore. After doing so, the PC boots but then leaves a black screen with only the mouse pointer visible. If I go...
BSOD Help and Support
Can I Pause/Turn off System Restore WITHOUT losing restore points?
I work with a large software suite. The installer for this suite is really just a collection of many stand-alone installers. If SR is on when I run the installation, it takes a very long time. Additionally, since this is a collection of other installers, SR is somewhat useless to use as a...
Backup and Restore
