Windows 7: System Restore
System Restore
How to Do a System Restore in Windows 7
Published by Brink
26 Nov 2008
information   Information
This will show you how to do a System Restore to restore your Windows 7 system files to an earlier point in time. It's a way to undo system changes to your computer without affecting your personal user files, such as e‑mail, documents, or photos.
Note   Note
System Restore uses a feature called System Protection to regularly create and save restore points of selected hard disks in your computer. These restore points contain information about registry settings and other system information that Windows 7 uses. You can also create restore points manually.
warning   Warning
A System Restore will uninstall programs and drivers (step 8 in Option One below) that were installed after the date of the selected restore point.
A System Restore will replace the password of all local user accounts to what they were at the time of the selected restore point.
If you do a System Restore when the computer is in safe mode or Windows Recovery Environment (WinRE), then you will not be able to undo the restore operation. However, you are able to still run System Restore again and choose a different restore point if available.
CONTENTS:
  • Option One: To Do a System Restore in Windows 7 using System Protection
  • Option Two: To Do a System Restore at Boot using System Recovery Options
System Restore OPTION ONE System Restore
NOTE: Be sure to temporarily disable your antivirus program first to prevent it from possibly preventing you from doing a system restore.
1. Do step 2, step 3, step 4, or step 5 below for how you would like to open System Restore.
2. Open the Start Menu, type rstrui.exe in the search box, press Enter, and go to step 6 below.
3. Open the Start Menu.
A) Click on All Programs, Accessories, System Tools, and System Restore, and go to step 6 below. (see screenshot below)
4. Open the Control Panel (icons view).
A) Click on the Recovery icon.
B) Click on the Open System Restore button. (see screenshot below)
C) Go to step 7 or step 8 below.
5. Open the Start Menu.
A) Right click on the Computer button and click on Properties.
B) Click on the System Protection link. (see screenshot below)
C) Close the System window, and go to step 6 below. (see screenshot above)
6. Click on the System Restore button. (see screenshot below)
7. If You Have Not Done a System Restore Before
A) Click on the Next button, and go to step 9 below. (see screenshot below)
8. If You Have Done a System Restore Before
A) Select (dot) Choose a different restore point, click on the Next button, and go to step 9 below. (see screenshot below)
9. Select (click on) a listed restore point that you want to restore the drives that were included in the restore point back to how they were when the restore point was created. (see screenshot below)
NOTE: Check the Show other restore points box to see any restore points (older) that may not be listed here.
10. To Show Affected Programs and Drivers
NOTE: This will show you a list of programs and drivers that will be deleted and restored by the selected restore point.
A) Click on the Show affected programs and drivers button. (See screenshot above)
B) When done reviewing, click on the Close button. (see screenshot below)
11. Click on the Next button. (see screenshot below step 8)
NOTE: Make sure that the restore point you want is still selected (highlighted).
12. Click on the Finish button. (see screenshot below)
NOTE: The listed drives here will be restored back to how they were for the selected restore point.
13. Click on Yes to confirm. (see screenshot below)
WARNING: This will immediately restart your computer to finish the system restore.
14. After the computer has restarted, click on the Close button. (see screenshot below)
System Restore OPTION TWO System Restore
NOTE: This will allow you to restore Windows 7 to a earlier restore point with a Windows 7 installation disc or System Repair Disc from the System Recovery Options screen at bootup. This can be handy if you cannot startup Windows 7.
1. Using your retail Windows 7 installation disc or System Repair Disc, boot to the System Recovery Options screen.
2. Select the System Restore option. (see screenshot below)
3. Continue starting with step 7 or step 8 in Option One above.
Related Tutorials
12 Jun 2010   #1
joevelyn
windows 7 home premium
triede the solution. Hope it workded
12 Jun 2010   #2
Brink
64-bit Windows 10 Pro
Hello Joe, and welcome to Seven Forums.
I'm not sure what solution you mean, but I hope it worked for you as well.
27 Jun 2010   #3
Suranjit
Windows 7 64 bit
I am unable to do 'System Restore' in my laptop. I tried but after restarting I got a message like not successfully completed. I have attached a screenshot for that. I tried with different restoring point but not working !!!!!!!!!!
Please let me know if there is any other way to do that.
Thanks,
Suranjit
27 Jun 2010   #4
Product FRED
Windows 7 Enterprise 64-bit
Quote   Quote: Originally Posted by Suranjit View Post
Thanks,
Suranjit
According to this website (which is actually for Vista, but should apply to 7):
Error message created by System Restore, file backup and Defrag in Windows Vista:
Quote:
1. This can be do to the System Volume Information Folder attributes being set to Read-only.
The System Volume Information Folder is where Vista holds restore points or shadow copies.
For Windows Vista using the NTFS File System.
Click Start then My Computer.
On the Tools menu Then Folder Options.
On the View tab, click “Show hidden files and folders”.
Clear the Hide protected operating system files (Recommended) check box. Click Yes when you are prompted to confirm the change.
Click OK.
Right-click the System Volume Information folder in the root folder, and then click Properties.
If the Read-only attibutes is checked, uncheck it and click, OK
Now try creating a restore point.
Warning: Remember to hide the hidden System Files when done.
2. This error occurs because the recovery partition is enabled for File Backup or System Restore and is almost full. To work around this, do not select D:\ as a backup source. Also, go to System Protection in Control Panel and make sure that D:\ is not enabled for restore points.
27 Jun 2010   #5
Suranjit
Windows 7 64 bit
Thanks for that link.
I read that but it seems that if I create a system restore point following the rules mentioned then I can use this system restore point later.
That means I will not be able to do any System Restore to any point before that. Is that correct??
Thank you again.
27 Jun 2010   #6
bludgard69
MS Windows 7 Home Premium 64-bit
Hi,Suranjit.I don't know if this is at all helpful,but I used to use Zone Alarm security suite and something in the AV\AM locked some files to where I couldn't use sysyem restore.
I had to Recover to get rid of ZA.Use MSE now and haven't had the first problem.
21 Jul 2010   #7
Hollow012
Windows XP/Wndows 7
When i go to my startup, i have two options to pick.
1: Launch Startup repair
2: Start Windows.
I pick 1 and i dont have a disk or something. so i picked 2 and it goes to the same page where i got to pick two options. pls help fast n reply asap or i will get scolding by my parents. thanks
21 Jul 2010   #8
Brink
Hello Hollow, and welcome to Seven Forums.
Are you unable to do a system restore from within Windows 7?
If so, you can also create a System Repair Disc to be able to use to do METHOD TWO in the tutorial with. Of course, you will still have to have an available restore point to select to go back to.
12 Oct 2010   #9
trent3111
Windows 7 Home Premium 64 bit
Lost here
umm i'm lost here. I looked around and this seems are close system restore as it gets and seems it only restores back to certain points. Or atleast thats what i think. But isn't there a option to completely restore your computer back to the original condition ( in other and exact words it deletes everything from your computer and only re installed windows 7? )
 System Restore
System restore doesn't show any restore points - but they exist
After Tuesday's Windows update I couldn't boot into Windows and loaded my system repair disk planning to roll back to a restore point from the day before. But, the restore wizard couldn't find any restore points. I know my system does it daily and I did a manual one a week prior just to see if it...
Backup and Restore
Allocated System Restore space holds far fewer restore points now
I have 8gb of space allocated to System Restore, all monitoring my C partition only. This space is always at least 85-90% used according to the System Protection screen. In the past I have had at least 15 restore points to choose from after ticking "show more restore points." But today I went to...
Backup and Restore
System Restore Has Stopped Automatically Creating Restore Points
My last automatically System Restore Point automatically created by the passage of time was created 2013-01-23. No further automatic system restore points are being created (that means not ever, not daily, not weekly, simply no longer created automatically by the passage of time since last...
Backup and Restore
System Restore - Restore system settings and previous versions of file
estore system settings and previous versions of file is greyed out on my system, I may have disabled a required service for this, can anyone point me to the right direction for this? As I'm about to try the X-Fi MB2 mod again as the last time I tried it my system was messed up that it wont even...
Backup and Restore
Black screen with pointer after System Restore and no Restore Tools
Hi, this looks like the right place but apologies if not, first time posting and all. I've been trying all day to resolve a networking issue and eventually decided to do a system restore. After doing so, the PC boots but then leaves a black screen with only the mouse pointer visible. If I go...
BSOD Help and Support
Can I Pause/Turn off System Restore WITHOUT losing restore points?
I work with a large software suite. The installer for this suite is really just a collection of many stand-alone installers. If SR is on when I run the installation, it takes a very long time. Additionally, since this is a collection of other installers, SR is somewhat useless to use as a...
Backup and Restore
