Windows 7: Unidentified Networks - Set as Private or Public
23 Jan 2013   #40
brianzion
thanks for your advice i have got it back to normal i un installed then re installed after a re boot the driver from the Intel(R) 82567V-2 Gigabit Network Connection and hey presto the unidentified network has gone
Unidentified Networks - Set as Private or Public-brys-snap-2013.01.23-001.png
23 Jan 2013   #41
Solarstarshines
Simple as that
Good job none the less Brink you are the man oops i mean Alien
23 Jan 2013   #42
brianzion
Quote   Quote: Originally Posted by Solarstarshines View Post
Simple as that
well i thought i would try it cant do no harm a fresh install of a driver
23 Jan 2013   #43
Solarstarshines
Quote   Quote: Originally Posted by brianzion View Post
Simple as that
Why is it we overlook the simple things and end up getting into some complicated deep rooted experimental solutions hahaha
I would have never of thought to refresh the driver but then again when i go to hardware and devices and you see a yellow some times it is always good to delete it and refresh it and it will reinstall perfectly fine
23 Jan 2013   #44
Brink
64-bit Windows 10 Pro
Perfect. I'll have to remember that.
LOL, yep it's always the simple things that get us.
10 Feb 2013   #45
brianzion
incase anyone gets stuck(like me!)HOW TO UNMERGE NETWORKS
1) At " Network and Sharing Center " click on the network icon, at the popped up window click on " Merge or delete network location" . There you should see your network's status as "in use". Leave that window opened.
2) Go to " Network and Sharing Center" -> "Change Adapter Settings". Disable all the network adapters that are joined into your network.
3) Switch back to the " Merge or delete network location" window. Now your network's status should be displayed as "Not in use" (and when selecting that network delete button is active). Delete the network.
4) Now you can enable the network adapters that you've disabled in step 2 and it should guide you through creating new networks for each network adapter.
01 May 2013   #46
numbnuts
Windows 7 Home Premium 32bit
I am using Windows 7 Home Premium and I am connecting back into my home network via VPN. I have used the registry hack at the start of this thread to turn unidentified networks into "Work networks". My network access type still shows "No Network Access" and I can't access anything on my local network. What I want to do is to be able to access my files and browse network shares as if I was at home. I have network discovery turned on.
Any ideas?
09 Dec 2013   #47
brianzion
just an update to a solution to unidentified network i used this fix 'ROUTE DELETE' method. as follows open cmd promt and
on the command prompt which you should run as under administrator login type the following:
route delete 0.0.0.0 and enter
and then
ipconfig /renew and enter
09 Dec 2013   #48
Brink
Thank you Brian.
09 Dec 2013   #49
brianzion
your welcome
All networks unidentified, except tethering
Problem: Can't identify networks (both WIFI & cable) except tethering from my phone Background: A few months back i started experiencing a couple of network issues after installing the VPN client from Private Internet Access & a DNSLeak fix. I could only connect to networks if I used that...
Network & Sharing
How Public and Private Encryption Key Works???
Hi guys, I need to understand how PGP or GPG keys works! 1) I need to send a email encrypted for a person. I have to send to her my public key and my secret password? 2) I encrypts and signs my message with my private key and my password? 3) My password is needed only to encrypted...
Software
Threats From Public Networks
Hi, Can somebody tell me what are the threats from public networks and exactly in what aspects should I be careful? Thanks in Advance!
Network & Sharing
Make a Public Network Private?
I need help doing this for windows 7 home ed. x32 I have my xbox 360 connected via cat 5. I cant access files unless the network is private
Network & Sharing
Public or private
Hi. I have a pc networked to a laptop, both running W7 ultimate. Pc is wired to the router and laptop is wireless. Everything was working OK until I installed samsung cell phone software and in trying to get it to work I followed some (bad) advice and deleted Teredo. I think this is something to...
Network & Sharing
Check this out.. Private and public network?
So this is my home pc that I run a private network on with my brothers computer and mine.. No idea now after a ran a tweak program I have public and private setup. http://i28.tinypic.com/16k96yx.jpg How do I just keep the private setting on rather then the public trash to? Also My jump...
Network & Sharing
