Unidentified Networks - Set as Private or Public
Page 7 of 7 FirstFirst ... 567
  1. Posts : 759
       #60
    Hi, Brink,
    I have found out what made the change of home work group. It is a router attack, that has changed my gateway to 169.254.90.67, which ip address i could not found on the web. It has changed my private to public. When deeply getting in to details, i found s3amazonws.com is trying to download a version 3 from somewhere else. I got my internet access thro typing static address in the ipv4 settings. But , how to stop this attack.
    I tried port forwarding http 80 port to some other ips. Still avast scan found vulnerability of rom 0 vulnerability of which i only know that it attacked router.
    I scanned with avast again, the vulnerability was shown again and my router is teracom , and it showed port 80, and ftp port 21 vulnerable and liable to attack.
    I just clicked update router in simple port forward tool , which captured my router , but shown in different name onda.... I took the risk of updating , it updated . and i tested again with avast. I was shown complete protection of router also. It showed no vulnerability, but my router name changed to some other name, some MediaTek, and i was happy that the problem is resolved.
    But one more scan, revealed the old vulnerability screen, by the same avast.
    I do not know how the modem name changed and i was given green signal in the scan and another renamed my router as teracom and posted the vulnerability picture.
    Attached Thumbnails Attached Thumbnails Unidentified Networks - Set as Private or Public-secured-router.png   Unidentified Networks - Set as Private or Public-rom-0attack.png   Unidentified Networks - Set as Private or Public-rom-0-attack2.png   Unidentified Networks - Set as Private or Public-rom-0-attack3.png
  2. Posts : 72,051
       #61
    jraju,
    I'm glad you found the cause, but it would be best to post that issue in the Network & Sharing forum area instead to get help with.
  3. Posts : 1
    Win 10 Home
       #62
    Hi
    I've stumbled across this thread as I am trying to do this on Win 10 Home
    Using these reg files seems to have no effect so perhaps the keys have moved ?
    I have been able to use the powershell technique but this is only temporary and the network becomes Public again on cable reconnection or restart
    I'm really hoping to find a permanent solution to this
    Thanks in advance
  4. Posts : 72,051
       #63
    Hello minieggs, and welcome to Seven Forums. :)
    I have just checked, and the registry keys are the same in Windows 10 as well. If you haven't already, you might see if restarting the computer after merging the .reg file may help.
  5. jmm
    Microsoft Windows 7 Professionnel 64 bits 7601 Multiprocessor Free Service Pack 1
       #64
    unidentified ad hoc
    Hi, I have an ad hoc network to which I gave a name (Brother), but it shows as unidentified in network and sharing center - is that normal?
    In Network List Manager Policies, unidentified networks are set as private...
    Attached Thumbnails Attached Thumbnails Unidentified Networks - Set as Private or Public-image1.png   Unidentified Networks - Set as Private or Public-capture.png
  6. Posts : 72,051
       #65
    Hello jmm,
    It's normal for it to be an "unidentified network" whenever Windows is unable to ID the network.
    As long as the network connection works and you are able to set its network location to what you want, it's fine.
  7. jmm
       #66
    ok thanks
    and happy new year btw...
