Windows 7: Unidentified Networks - Set as Private or Public
How to Set Unidentified Networks to be a Private or Public Network Location
Published by Brink
16 Mar 2010
information   Information
Sometimes Windows 7 is unable to identify the network it is connected to due to a network issue or lack of identifiable characteristics. This type of network is called a unidentified network.
A network location identifies the type of network that a computer is connected to and automatically sets the appropriate firewall settings for that location. This will show you how to set a unidentified network to always be set as a private (work) or public network location as displayed in the Network and Sharing Center.
Note   Note
  • Choose Private network (Work) for small office or other workplace networks. Network discovery, which allows you to see other computers and devices on a network and allows other network users to see your computer, is on by default, but you can't create or join a homegroup.
    • All computers are peers; no computer has control over another computer.
    • Each computer has a set of user accounts. To log on to any computer in the workgroup, you must have an account on that computer.
    • There are typically no more than twenty computers.
    • A workgroup is not protected by a password.
    • All computers must be on the same local network or subnet.
  • Choose Public network for networks in public places (such as coffee shops or airports). This location is designed to keep your computer from being visible to other computers around you and to help protect your computer from any malicious software from the Internet. HomeGroup is not available on public networks, and network discovery is turned off. You should also choose this option if you're connected directly to the Internet without using a router, or if you have a mobile broadband connection.
warning   Warning
You will only be able to do this while logged in as an administrator.
EXAMPLE: Unidentified Network set as Private or Public
Unidentified Networks - Set as Private or Public-unidentified_private-work.jpg
Unidentified Networks - Set as Private or Public OPTION ONE Unidentified Networks - Set as Private or Public
Through Network List Manager Policies
1. Open the Local Security Policy editor.
A) In the left pane, select Network List Manager Policies. (see screenshot below)
B) Go to step 3.
OR
2. Open the Local Group Policy Editor.
A) In the left pane, click on to expand Computer Configuration, Windows Settings, Security Settings, and Network List Manager Policies. (see screenshot below)
3. In the right pane, double click on Unidentified Networks. (see screenshots above)
4. To Restore Unidentified Networks to Default Not Configured
NOTE: This allows Windows 7 to set the unidentified network to be either Public or Private (work) as it so determines automatically.
A) Under Location type, select (dot) Not Configured and click on OK.
B) Go to step 7.
5. To Set Unidentified Networks to Public Network Location
A) Under Location type, select (dot) Public and click on OK. (see screenshot below step 4A)
B) Go to step 7.
6. To Set Unidentified Networks to Private Network Location
A) Under Location type, select (dot) Private (Work) and click on OK. (see screenshot below step 4A)
7. Close the Local Security Policy or Local Group Policy Editor.
8. Open the Network and Sharing Center to see the change.
NOTE: You can open the Network and Sharing Center from within the Control Panel, or by right clicking on your Network icon in taskbar notification area.
Unidentified Networks - Set as Private or Public OPTION TWO Unidentified Networks - Set as Private or Public
Through a REG File Download
1. To Restore Unidentified Networks to Default Not Configured
Set_Unidentified_Networks_Default-Not_Configured.reg
download
B) Go to step 4.
2. To Set Unidentified Networks to Public Network Location
Set_Unidentified_Networks_Public.reg
download
B) Go to step 4.
3. To Set Unidentified Networks to Private (Work) Network Location
Set_Unidentified_Networks_Private.reg
download
4. Click on Save, and save the .reg file to the desktop.
5. Right click the downloaded .reg file and click on Merge.
6. Click on Run, Yes, Yes, and OK when prompted.
7. Open the Network and Sharing Center to see the change.
8. When done, you can delete the downloaded .reg file on the desktop if you like.
02 Apr 2010   #1
theruds
Windows 7 Home Premium
I am using Home Premium. I tried Option 2. When i get click on Run (in step 6) it opens notepad. How do i continue as there is no Yes option?
UPDATE:
I managed to get my wireless connection working. I went into the wireless connection properties and changed the settings for Internet Protocol Version 4 properties to Obtain an IP address automatically. Such a simple fix for so many frustrating hours.
02 Apr 2010   #2
Brink
64-bit Windows 10 Pro
Hello Ruds, and welcome to Seven Forums.
I'm happy to hear that you got your problem sorted.
However, it sounds like your REG file associations are not correct. Double check in Default Programs to make sure that the .reg file extension has it's "Current Default" program set as Registry Editor (C:\Windows\regedit.exe) and not Notepad.
03 Apr 2010   #3
theruds
Thanks. I have changed my default program.
I had problems connecting to my wireless network again. After connecting to ethernet it worked. I disconnected the ethernet and rebooted the computer and the wireless still worked. I am not sure why. I will test it a few more times and seek further advice if necessary.
04 Jul 2010   #4
alexba
Hi all,
thank you very much for this :-) I was looking a long time to find a solution for Windows Home Prium without the Policy possibility.
So I downloaded the "Set_Unidentified_Networks_Public.reg" script and run as Administrator. The information was finally add to registry. Fine.
I then added to a new network but the Pop Up appears again. I was asked to which network I wanted to add it ???
Did I understand this article wrong? Does the Pop Up always come even after defining the network?
Or is it possible that tis only works on English release an not other languages (mine is German)
Thank you in advance
Alex
04 Jul 2010   #5
Brink
You're welcome Alex, and welcome to Seven Forums.
It may be some issue with the language difference. After you selected which network you wanted, did it apply it properly and not come back?
Could you post a screenshot of this registry location below from your computer?
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows NT\CurrentVersion\NetworkList\Signatures\010103000F0000F0010000000F0000F0C967A3643C3AD745950DA7859209176EF5B87C875FA20DF21951640E807D7C24
05 Jul 2010   #6
NoN
One question Shawn...
What if i click on the Icon, comes up a window telling me priority of the network, just underneath it tells me if i want to merge both network together...What's the consequences of doing that?
Thanks.
05 Jul 2010   #7
Brink
Hello NoN,
It would be like if you are connected through one wired connection (ex: Network 1), that is your default network, and one wireless connection (ex: Network 2), then if one connection drops, the other one will automatically take over.
06 Jul 2010   #8
NoN
Quote   Quote: Originally Posted by Brink View Post
Hello NoN,
Ha, allright, so i'll have to be both wired and wireless connected. It is just bizarre to me that one call "virtual Wi-fi" and the other "Wi-fi" network, and the first one could serve needs for a hot-spot wi-fi. It shows ethernet cable with turned on, that why i'm a little puzzled about it.
Thanks!
06 Jul 2010   #9
Brink
NoN,
No, that was just an example above. You can have any type of connections that you like and merge them.
All networks unidentified, except tethering
Problem: Can't identify networks (both WIFI & cable) except tethering from my phone Background: A few months back i started experiencing a couple of network issues after installing the VPN client from Private Internet Access & a DNSLeak fix. I could only connect to networks if I used that...
Network & Sharing
How Public and Private Encryption Key Works???
Hi guys, I need to understand how PGP or GPG keys works! 1) I need to send a email encrypted for a person. I have to send to her my public key and my secret password? 2) I encrypts and signs my message with my private key and my password? 3) My password is needed only to encrypted...
Software
Threats From Public Networks
Hi, Can somebody tell me what are the threats from public networks and exactly in what aspects should I be careful? Thanks in Advance!
Network & Sharing
Make a Public Network Private?
I need help doing this for windows 7 home ed. x32 I have my xbox 360 connected via cat 5. I cant access files unless the network is private
Network & Sharing
Public or private
Hi. I have a pc networked to a laptop, both running W7 ultimate. Pc is wired to the router and laptop is wireless. Everything was working OK until I installed samsung cell phone software and in trying to get it to work I followed some (bad) advice and deleted Teredo. I think this is something to...
Network & Sharing
Check this out.. Private and public network?
So this is my home pc that I run a private network on with my brothers computer and mine.. No idea now after a ran a tweak program I have public and private setup. http://i28.tinypic.com/16k96yx.jpg How do I just keep the private setting on rather then the public trash to? Also My jump...
Network & Sharing
