Windows 7: Memory Diagnostics Tool
22 Dec 2011   #30
Brink
64-bit Windows 10 Pro
You're welcome.
31 Dec 2011   #31
mcbreeden
win7 home premium 64bit
memory diagnostic tool looping
I did an internet search to get here and have the same problem that thumper started this thread with. I've tried all the things he tried as well except when you pull memory, bios won't let the system start hardware 101. I haven't tried this yet from another poster from somewhere else because I only have a restore disk that's not pulling up a repair page. From command prompt, he says "bcdedit /bootsequence {memdiag} /remove" Now is there a way to get to repair with f8 f7 not working due to memory test starting before f8 can be initiated?
Update: I downloaded a repair disk from Microsoft, and through a dozen attempts at booting to it, due to the memory test starting so quickly, I finally got the repair disk to boot and was able to repair boot, and system, as boot didn't seem to have any affect. It was VERY difficult to boot to repair disk though. It took many tries to hit it just right. Hitting F8 over and over and over.
31 Dec 2011   #32
Brink
Hello McBreeden, and welcome to Seven Forums.
You could try opening a command prompt at boot using a Windows 7 system repair disc or any retail installation disc for this.
29 Jan 2013   #33
sfwul
Well, I did step 1, arrived at step 4, after a few minutes my monitor went into standby mode. After 15 minutes there was quite some disc activity but actually nothing showed up on my monitor, after another 15-20 minutes (with hardly any activity) I restarted the pc. Assume that it won't take more than half an hour, else Microsoft should warn users that it may take a long time.
16 Feb 2013   #34
Wrend
Windows 7 Professional SP1 64bit, Debian GNU/Linux 64bit (virtual machine on a RAM drive)
Wow, this test takes forever. Just added another 32GB to my PC and wanted to check it, but this test is kind of ridiculously long. They should have said "This might take several hours."
It's been about 3 hours now on the first and only pass, and holding at 21% complete for maybe a couple hours or so. No problems detected yet. I am having it do the extended version of the test though.
Is this typical?
16 Feb 2013   #35
Brink
Hello Wrend,
Yes, this is normal. The more passes you set to run, the longer it is takes as well.
17 Feb 2013   #36
Wrend
Thanks.
It's still at 21%, and has now been there for almost 20 hours. I did have it run the extended test, and I have 64GB of RAM, so maybe that is making it take so long.
I want it to finish almost on principle at this point, but if it doesn't finish today, I'll have to stop it to get back to crunching and hosting a Minecraft server. Some of my players wanted to play yesterday and last night.
17 Feb 2013   #37
Brink
Oh my. Yeah, that could take a long time.
18 May 2014   #38
Intuit
X32, V64, S64, E64
Greetings Brink. Thanks for the years of super-detailed information. Your time is appreciated.
Another way to access the memory diagnostic tool, was to keep tapping the "F1" key just before booting to a Windows 7 DVD. That would bring up the following display...
At that point, you could press "Tab" key and then hit "Enter" after the Windows Memory Diagnostic option is highlighted. (note: the GUI option to reboot into the diagnostic is designed to work with on-drive recovery and won't work with boot-dvd recovery)
Bad memory often will not allow you to load into a full-blown operating system, whether via optical disk, flash drive, hard drive or otherwise. I've had systems where Windows PE would not load from DVD, (both DVD & optical drive good,) but would load and run the memory diagnostic tool; and it would flag a fault.
What's curious, the "F1" key doesn't seem to work with the Windows 8.1 (and assume Windows 8) DVDs.
Question, did Microsoft change or eliminate this option with the Windows 8 or 8.1 boot DVDs ?
Haven't been able to get a search engine hit on this.
Thanks Brink.
18 May 2014   #39
Brink
Hello Intuit,
That would be about the same as step 2, but with F1 at boot instead. I'm not sure if F1 is the same on all PCs though.
You're supposed to be able to press Shift+F8 instead in Windows 8/8.1, but there's so little time available to do so, it's just about impossible to do. You could also disable the new GUI in Windows 8/8.1 to have the old menu again if you like.
Startup Options - Enable or Disable in Windows 8
windows wont boot without running memory diagnostics
When ever I properly shut down my system it wont boot normally. Here is what happens: It goes to the screen "Starting windows" and gets stuck. I press the power button, and then press it again to start the system. I am given the screen with two options: run system repair and start windows...
Performance & Maintenance
Memory Diagnostics Tool - Read Event Viewer Log
How to Read Event Viewer Log for Windows Memory Diagnostics Tool This will show you how to read the Event Viewer log to see the results of the Windows Memory Diagnostics Tool in Vista, Windows 7, and Windows 8. If you just ran the Windows Memory Diagnostics Tool, then it may take a bit...
Tutorials
BSOD (SF Diagnostics Tool is Not Working)
Hi I d/l SF diagnostics, but, it freezes up, so I have uploaded the .DMP file in a zipped folder.
BSOD Help and Support
Windows Memory Diagnostics Tool Reports Errors
Ok, I will try to make a long story short. I've had issues with BSOD off and on for sometime now. They don't happen at any particular time and mostly occur in the middle of the night. They occur about every 3 to 4 months. I used Bluescreenview to look at the dump files. The driver it pointed to...
BSOD and help with windows memory diagnostics
Hi, I have recently been having random blue screens of death and i downloaded the Windows memory diagnostic tool, ran the diagnostics tool (http://oca.microsoft.com/en/windiag.asp) and a few things happened: 1- It threw up a message before the scan saying then memory map could not work with 4gb...
Hardware & Devices
directx Diagnostics tool stopped working?
When I try to go to run and type dxdiag.exe Is tells me this. Also I have been trying to get a game to work. On my PC it will not work. I have been talking to EA sports about it for 4 days now. This is the only other thing they have told me to try was update direct x Now I did and it is doing this...
Software
