Windows 7: Restart Time
30 Jan 2013   #80
Brink
64-bit Windows 10 Pro
12 Feb 2013   #81
SweetAeromotion
Windows 7 Professional 64 bit
20 Feb 2013   #82
Jerlys
Win7/8 64 bit/
I don't think this thing is reliable. It time stamped my PC time at 67 seconds, yet I stop watched it between 20-24 seconds consistently. I can't even count to 67 before my PC is back to the desktop.
20 Feb 2013   #83
Brink
Hello Jerlys,
The script in the tutorial measures the amount of seconds it takes to restart and boot the computer from the second you click on Restart. Thus "restart time" and not "boot time".
It sounds like you may be only measuring the cold boot time, and not the full restart time.
Hope this helps.
20 Feb 2013   #84
Jerlys
Win7/8 64 bit/
Quote   Quote: Originally Posted by Brink View Post
Hello Jerlys,
Hope this helps.
I stop watched them side to side. started the timer the same time I clicked the restart button. After 10 runs I have concluded that this script adds on average between 15 to 25 seconds to the actual restart time. on 2 of the runs, including the first one, the difference was drastic. I followed the tutorial on the first post, had nothing running in the background. I halted the stop watch as soon as my desktop was visible. The timer prompt would show some time later. So I think its still counting until it can show you the OK button.
Perhaps my PC just doesn't like this thing.
20 Feb 2013   #85
Brink
It may be the time it takes for all startup programs to finish loading for the time difference.
20 Feb 2013   #86
Jerlys
Win7/8 64 bit/
Ill give it a try in a few killing all start up programs, oddly I only have 3. Nvidia control panel, EVGA precision and Intel rapid storage. I try to keep my computer as clean as possible. The only thing I know might slow things down is I have photo slide show for my desktop.
13 Dec 2013   #87
gldndragn
Windows 7 Home Premium (64 bit)
Here is mine
13 Dec 2013   #88
derekimo
Quote   Quote: Originally Posted by gldndragn View Post
Here is mine
Attachment 297348
Pretty good numbers.
You can post it here too if you want to compare a little,
ReBoot Time [2]
05 Feb 2014   #89
Scoop
Windows 7 Home Premium 64 bit
I can't get the script to restart my PC. I unblocked using Properties.
When I run the script, a msgbox says "close all running applications and click 'ok'".
When I click the "ok" button, the PC doesn't restart. When I click the vbs icon again to run it again, the
msg box appears and says "you computer takes [x] seconds to completely restart."
I noticed that the script timer works. If I wait before clicking the script icon the 2nd time, it will return the currect time elapsed from the first time I tried to run the script to the 2nd time.
[edit]
I tried it using a manual "restart" (I restarted from the Win Shutdown Menu a couple of seconds after I launched the vbs script) and the elapsed timer worked if I add in the time that I restarted using the Win menu.
My time's not great, around 125 seconds, but that's what I expected as I haven't run any tools to streamline my startup time.
It's not an issue with me as long as I know the approx. elapsed times required during a couple of steps:
- The black Windows logo screen. That always takes about 26-28 seconds on my Desktop and Laptop PC's. That's the time when the logo screen begins after POST and when the "Welcome" screen appears.
- "Welcome" Screen time. That will vary on my Desktop PC but usually takes ~10-15 seconds before the desktop launches.
[edit 2]
The script started to work after I moved the script to one of my folders in my Documents folder, a PC mystery but my restart time is about 85 seconds.
That make me feel better . Improvements are needed on my system but as long as I can boot with consistant (no error) results, that's the main point for me.
 Restart Time
date and time changes on restart
every time I restart my Laptop, the date and the time changes to 1/1/2010 and 12PM. I have windows7 professional service pack1 32bit. Can anyone help me with this problem?
General Discussion
Windows time changes every time I restart
I've installed snow leopard (hackintosh) on a separate partition and since then I've been having trouble with the clock it reads 3 extra hours than the original time So I deleted Snow Leopard and formatted the partition and checked the time again and no change at all Any help please
General Discussion
Computer suddenly freezing need to restart from time to time
Computer is suddenly freezing from time to time and i need to restart to undo it dont know what is causing this. Thanks for looking into the .dmp file.
BSOD Help and Support
Time Resets to GMT On Restart
I have an issue with Windows 7. Whatever time I set Windows 7 to (i.e. Eastern Time, Western Time, Coordinated Universal Time, etc.), on restart it sets itself to GMT, while still showing that I've selected the previous time zone I set (i.e. Eastern Time). Any help would be appreciated.
Performance & Maintenance
restart time 258 seconds
:confused: I have just run the restart time checker coz i'm seeing my sony vaio 6mth old pc getting slower and slower plus getting probs with start up from(fresh) and also shut down. My restart time is 258 seconds is this ok? i don't think so??:sarc: I Have run all sony diagnostics plus i have...
Windows wants me to restart evey time I log in
Well not every time, but every time AFTER the first login. I start up my computer and log in, no problem. Then I log out, and log back in again. As soon as Windows finishes loading the desktop, the following pop-up message appears: You must restart your computer to apply these changes. Before...
General Discussion
