Windows 7: Icons - Change Using Resource Hacker
02 Dec 2012   #80
Britton30
Microsoft MVP
Windows 7 Ultimate X64 SP1
Quote   Quote: Originally Posted by JonathanV View Post
Great tutorial! Nice Arc!
I have a question. Will running sfc /scannow replace the modified icon to the default ones?
It did change some of mine back to default. My Pc does screwy things though.
03 Dec 2012   #81
Arc
Quote   Quote: Originally Posted by DancingRain View Post
Quote   Quote: Originally Posted by HoMysterious View Post
Quote:
12. In the upcoming box, click on "Open the file with new icon" and browse for it.
Browse for what !? .ico file !? when i open .ico with Resource Hacker, it says "out of memory".. i want to replace my app icon with this .ico files..
I apologise for being the newbie who brings up the ancient thread, but I'm receiving the "out of memory" popup, too, and it fails to add the new icon. I've taken ownership, and tried adding it with resource hacker several times, to no avail. Help, please?
Welcome aboard.
If you get the out of memory dialog, ignore it. Save the imageres file on desktop and then replace the system file as drscribed there.
if it is still a problem, let us know.
03 Dec 2012   #82
DancingRain
I tried again this morning, and it worked. Go figure.
26 Dec 2012   #83
mskll5
Windows 7 Home Premium 32bit.
many thanks for a simple step by step how to you the mannnnnnn
26 Dec 2012   #84
Arc
After changing the icon/icons, where are you saving the final result?
28 Mar 2013   #85
bcannariato
I am new to this forum and I didn't want to bump it, but its only a few months and perhaps others are having the same issue.
So I have successfully changed a few of the icons I have tried using Resource Hacker.
Here's my problem. I replaced my Firefox icon with something, and now I am attempting to change it again to something else. The first time I changed it, everything works, I pinned it to the taskbar (Windows 7), it opens up with the correct icon, everything. Now when I change it again I get the newer icon working on the shortcut, pin that to the taskbar, but then when I open it it shows the old icon I changed it to. I have tried multiple times to re-change the icon to no avail.
Any help here would be great!
28 Mar 2013   #86
Brink
64-bit Windows 10 Pro
Hello bcannariato, and welcome to Seven Forums.
Did you change the icon of the shortcut or the actual .exe file for Firefox?
If you did change the icon for the .exe file, then you might see if rebuilding the icon cache may help.
29 Mar 2013   #87
Arc
I am adding a little to Brink's suggestion, for most of the third party icons (those are not having a MSI based installer), the best way to change the icons is Taskbar Pinned Icons - Change.
It takes the effect system wide.
08 Sep 2014   #88
ThrashZone
Win-7-Pro64bit 7-H-Prem-64bit
Quote   Quote: Originally Posted by Arc View Post
Hi Archie seems you had me in mind with that link
I was under the impression icons needed to be bmp's ? or is that just start orbs :/
How about sizes ?
@125 dpi screen resolution for an ie10 .exe for taskbar 66x198 for all three states :/
It's a round icon for what it's worth
Cheers.
08 Sep 2014   #89
Arc
Hi Mike.
Icons, when applied as system icons or any other third party program icons, they must be .ico files.
Size doesn't matter. All good icons are multi-sized.
When icons are applied in docks etc, they needed to be .png.
Some other system resources including the start button are .bmp images. And, a start button image is not a single image but a combination of three images. For 100% DPI the three .bmp images are 6801, 6805 and 6809 in explorer.exe.
Devices and Printers - Change Device Icons with Custom Icons
How to Change Icons in "Devices and Printers" with Custom Icons This tutorial will cover how to change the icons in Devices and Printers with a custom icon of your choosing and be device specific, eliminating resource hacking and/or overwriting Windows 7 default icons. You'll need to be...
Tutorials
ExplorerFrame.dll, Resource Hacker Help
Hi, I'm having a bit of an issue changing my forward/back buttons. I'm running Windows 7 x64 Ultimate. The buttons came with the theme I'm trying to install (PongMaster Suite) , along with an x86 ExplorerFrame.dll file, which initially I had tried to put into system32. The site is in Russian...
Customization
Can't Change Back to Default Windows 7 Icons from another Themes Icons
Hello, when i first got my compute i installed a custom theme changing basically evrything about my computer and its apearence on the desktop. This includes the icons as well. When i tried to revert back to the original windows 7 icons it seems that this theme (which is third party I should mention...
Customization
Weird problem, explorer toolbar icons sometimes change to other icons
hi there i start to get really weird problem lately... the Explorer toolbar of windows 7 sometimes show me different icons only in progrems that use admin rights, relate to windows, use..java? o_O it show the icons of the last progrem i used, like if i will enter to Utorrent window,...
Browsers & Mail
Resource Hacker x64 beta
Hi! Maybe said yet, a x64 version for Reshacker (see the green frame), tested and it works... (Restorator too expensive!!!:sarc:). This is not a x64 version but an updated x86 which allows x64 files edition!!! Resource Hacker x64 beta version :D:D:D
Customization
Download New Updated “Resource Hacker 3.5 Beta” with 64
Download New Updated “Resource Hacker 3.5 Beta” with 64-bit and PNG File Support For all you extreme tweaks,. Resource Hacker has finally been updated. The possibilities are endliess with this prugram. "Resource Hacker" is one of our favorite software which is used to edit various system...
Customization
