Windows 7: Icons - Change Using Resource Hacker
How to Change Windows 7 System Icons Using Resource Hacker
Published by Arc
23 Mar 2010
Arc's Avatar
information   Information
A few days ago I faced a question How do I change icons using restorator???? . I provided the suggestion there; latter thought if there is a tutorial, it may help many guys asking the question.
Note   Note
Tools required :
1. Resource Hacker : Now supports 64 bit system and .png files. Download it from : Download New Updated “Resource Hacker 3.5.2 Beta” with 64-bit and PNG File Support - Tweaking with Vishal
2. IcoFX : A free application that can be used to get a ready reference of the system icons. Download it from IcoFX - The Free Icon Editor - Download
Download and install the above mentioned programs.
Now it starts :
Suppose we are changing the default games icon with this one Icons - Change Using Resource Hacker-chinaz5.png
Though almost all of the system is changeable in this process, it is just an example
1. Go to C:\Windows\System32\imageres.dll and take a copy if it in a secured place (i.e. take a backup of it)
2. Now Take Ownership of the imageres.dll
3. Open IcoFX. Click on Tools > Resource Editor.
4. In the resource editor window , click on the folder icon. The Open Resources window will appear.
5. In the open resources window, give the filename "imageres.dll" and click open.
6. So in the resource editor window, The games icon no is #14
We are to moderate it using Resource Hacker. Now we may close IcoFX.
7. Open Resource Hacker. Click on File > Open . It will automatically open in System 32.
8. In the incoming box, give the file name "imageres.dll" and click "open".
9. Now, Click on the "+" sign in front of "Icon Group"
10. You will look the Icon group tree expands, and an item "*1033" there. Click on "*1033" and see the games icon revealed in the right side pane of the window.
11. Now right click on "*1033" and click on "replace resource"
12. In the upcoming box, click on "Open the file with new icon" and browse for it.
13. Now, first click on "Select new icon" and then click on "replace"
Repeat upto step 13 for the icons you want to change at a time, and when all of your icons are replaced, go to step 14.
14. We are almost done. We successfully modified the imageres.dll file. Now it is to save it. Cilck on File > Save as, give the filename "imageres,dll". Save it on your desktop.
15. Go again to C:\Windows\System32\imageres.dll. Rename it to inageresOLD.dll or something. Now copy the modified imageres.dll in that location. The last thing is to restart ... either you may restart your computer, or you may restart explorer.exe using task manager.
16. After restart, Click on start menu and place your pointer on the games link. you will get it
I agree with you that the process is lengthy and labourous But it is the free of cost way to change all the system icons.
Enjoy yourself. And again,dont forget to backup your original imageres.dll before starting the process
24 Mar 2010   #1
scoopeeedoo
Thanks Arc! Nice tuto!!!
Very interesting dll to customize, but what a huge work to do it all!!!
24 Mar 2010   #2
Arc
Quote   Quote: Originally Posted by scoopeeedoo View Post
You are welcome , pal!
Really time consuming ! But you know, it is the only way to get access over all your system icons without reducing your pocket ! Many paid programs are there who either doesnot allow to change all it icons (like tuneup) or doesnot provides flexibility (like stardock iconpackager). But yah... you may mention restorator !
When you provided the 64 bit reshacker link , I planned for it. So again we are mutually thanking each other
30 Mar 2010   #3
Muneem
Windows 7 Ultimate x86
Nice very tuts!
ThNnx Yew bro
30 Mar 2010   #4
CarlTR6
Windows 7 Ultimate 32 bit
Nice tutorial; even I can understand it. Thanks.
30 Mar 2010   #5
Arc
Quote   Quote: Originally Posted by Muneem View Post
Nice very tuts!
ThNnx Yew bro
I am glad that you liked it
Quote   Quote: Originally Posted by CarlTR6 View Post
Hi Carl ! At least I know that there is no enough reason to underrate you in such a manner Though its my pleasure that you approved it. It's important to me.
30 Mar 2010   #6
iseeuu
Very well done Arc, nice job!
30 Mar 2010   #7
Arc
Quote   Quote: Originally Posted by iseeuu View Post
I value your words, Robert
30 Mar 2010   #8
Everlong
Thanks for this tutorial. Was exactly what I needed
30 Mar 2010   #9
Arc
Quote   Quote: Originally Posted by Everlong18 View Post
Feeling nice that it may fulfill some of your needs. Most welcome for your comment.
Devices and Printers - Change Device Icons with Custom Icons
How to Change Icons in "Devices and Printers" with Custom Icons This tutorial will cover how to change the icons in Devices and Printers with a custom icon of your choosing and be device specific, eliminating resource hacking and/or overwriting Windows 7 default icons. You'll need to be...
Tutorials
ExplorerFrame.dll, Resource Hacker Help
Hi, I'm having a bit of an issue changing my forward/back buttons. I'm running Windows 7 x64 Ultimate. The buttons came with the theme I'm trying to install (PongMaster Suite) , along with an x86 ExplorerFrame.dll file, which initially I had tried to put into system32. The site is in Russian...
Customization
Can't Change Back to Default Windows 7 Icons from another Themes Icons
Hello, when i first got my compute i installed a custom theme changing basically evrything about my computer and its apearence on the desktop. This includes the icons as well. When i tried to revert back to the original windows 7 icons it seems that this theme (which is third party I should mention...
Customization
Weird problem, explorer toolbar icons sometimes change to other icons
hi there i start to get really weird problem lately... the Explorer toolbar of windows 7 sometimes show me different icons only in progrems that use admin rights, relate to windows, use..java? o_O it show the icons of the last progrem i used, like if i will enter to Utorrent window,...
Browsers & Mail
Resource Hacker x64 beta
Hi! Maybe said yet, a x64 version for Reshacker (see the green frame), tested and it works... (Restorator too expensive!!!:sarc:). This is not a x64 version but an updated x86 which allows x64 files edition!!! Resource Hacker x64 beta version :D:D:D
Customization
Download New Updated “Resource Hacker 3.5 Beta” with 64
Download New Updated “Resource Hacker 3.5 Beta” with 64-bit and PNG File Support For all you extreme tweaks,. Resource Hacker has finally been updated. The possibilities are endliess with this prugram. "Resource Hacker" is one of our favorite software which is used to edit various system...
Customization
