Imaging with free Macrium
  1. Posts : 6
    Windows 7 x64
       #1520
    thank you DavidE and kado897 for the help!
    i can't get into "Burn Rescue Media" screen because im stuck in the "Prepare Windows PE Image" screen,
    i checked the ReflectDL.exe and ReflectDLFull.exe and they are the same,i used WinMerge to check.
    i don't have a 500mb file, could it be the downloaded pe5x64.zip? i selected the PE 5 rescue components only, and got a 188mb zip file, i test the zip file using 7zip and it does not show any error, so i assume its fine.
    will download it again and see. will report back soon.
    UPDATE:
    something is not right, i was downloading a 460mb size pe5x64 component, but end up with a 188mb zip file, just like before. is this right?
    extracted it and got a 208mb size folder, its missing 200mb+ that i downloaded.
    also, is there a http url of the pe5x64.zip component? i like to download it using FreeDownloadManager or wget.
    Thank you again guys!
    Attached Thumbnails Attached Thumbnails Imaging with free Macrium-macrium-error.png
  2. Posts : 6,330
       #1521
    I downloaded the pe5x64.zip and i see similar results as far as sizes reported vs actual.
    I don't think that is the issue, it's a multistep process that "repackages" the WADK components.
    You can read about that here: Unable to create rescue media (USB) on an offline Macrium Reflect Installation (V6)
    In your Prepare Windows PE Image screen print it looks all the fields are disabled, and i think that is an issue.
    If you click on View Log do you see any permissions or security errors ?
    Try starting MR with "Run as administrator" and see if that makes a difference getting the fields enabled.
    Do you have UAC turned off ?
    whs, the tutorial author has a Skydrive link at the very beginning of this tutorial.
    You could try downloading and using that ISO to create recovery media.
    On the first Create Rescue Media window I clicked on Change PE Version.
    That got me to the Prepare Windows PE Image window like yours, but you can see my fields are enabled.
  3. Posts : 10,455
       #1522
    It's not a good Idea to use WHS's ISO as I believe that is for Macrium V5 which is not compatible with V6 Images.
  4. Posts : 6,330
       #1523
    Good point, and you're absolutely correct
    However, it might still be a good idea to try it, just to test if studiostarstuff can create a rescue media that can boot up ?
    I have no idea why those fields are disabled (as i see it)
  5. Posts : 10,455
       #1524
    Me neither.
  6. whs
       #1525
    Yeah Keith is right. My iso is for a backlevel version and at least 18 months old. Not a good idea to use it with V6. Maybe someone can upload a more recent version. I would do it but I am currently under the weather fighting that nasty lung cancer.
  7. Posts : 10,455
       #1526
    Sorry to hear of your troubles Wolfgang. I wondered why we hadn't heard from you recently.
    I would do it but I don't have the free version. I don't think Macrium would be too pleased if I posted that as it has extra features.
  8. Posts : 17,545
    Windows 10 Pro x64 EN-GB
       #1527
    Wolfgang, I am very sorry to hear your news. From the bottom of my heart I wish you all the best. Take care of yourself.
    I have huge OneDrive storage available, using some of it to store these images would be no issue for me. If you tell me which WinPE version I should select I could create and upload both 32 and 64 bit ISO images within a few minutes:
    But: will these images work for all users? I mean, in my case the image would contain drivers for my setup:
    If you think the images should be re-uploaded I will do it. Just tell me which WinPE version I should use.
    Kari
  9. Posts : 17,545
       #1528
    OK geeks, I went ahead and uploaded some images. You will find both WinPE 3.1 and WinPE 5.0 Macrium Rescue ISO images, 32 and 64 bit versions here: Macrium Reflect Free Rescue Images
    The images work both on legacy BIOS and UEFI systems. The Macrium Reflect Free version is 6.0.
    Kari
  10. Posts : 9,600
    Win 7 Ultimate 64 bit
       #1529
    It's good to see you posting again, Wolfgang. Keep hanging in there!
