Internet Options - Add or Remove Connections Tab
    How to Add or Remove the Connections Tab in Internet Options
    This will show you how to add or remove the Connections tab in the Internet Options properties window of Internet Explorer for all users in Vista, Windows 7, and Windows 8.
    • If opened from within Internet Explorer, it is called Internet Options.
    • If opened from the Control Panel, it is called Internet Properties.
    EXAMPLE: Connections Tab in Internet Options
    OPTION ONE
    Using a REG File Download
    1. To Add Connections Tab to Internet Options
    Add_Connections_Tab_Internet_Options.reg
    B) Go to step 3.
    2. To Remove Connections Tab from Internet Options
    Remove_Connections_Tab_Internet_Options.reg
    4. Double click/tap on the downloaded .reg file to merge it.
    5. Click/tap on Run, Yes (UAC), Yes, and OK when prompted.
    6. Log off and log on, or restart the computer to apply.
    7. When done, you can delete the downloaded .reg file if you like.
    OPTION TWO
    Through the Local Group Policy Editor
    2. In the left pane, click on to expand User Configuration, Administrative Templates, Windows Components, Internet Explorer, and Internet Control Panel. (see screenshot below)
    3. In the right pane, right click on Disable the Connections page and click on Edit. (see screenshot above)
    4. To Add Connections Tab to Internet Options
    A) Select (dot) either Not Configured or Disabled. (see screenshot below step 6)
    B) Go to step 6.
    5. To Remove Connections Tab from Internet Options
    A) Select (dot) Enabled. (see screenshot below step 6)
    6. Click on OK. (see screenshot below)
    8. Close and reopen Internet Options if already opened.
  1. Posts : 2
    windows7
    Great tutorial, but I'm only able to merge the .reg file under administrative login (accounts). I'd like to restrict the tab under a standard user account and when I go to merge I'm told I don't have sufficient privileges to make the merge. If I manually attempt to regedit, I'm told the same. If I switch the standard account to administrative, I can then merge the .reg file, but the minute I switch the account back to standard, the tab reappears. Any advice here? Thanks again. edit: the second method using the local group policy editor did not work either, set to enabled, filter on.
  2. Posts : 72,052
    Hello Ken, and welcome to Seven Forums.
    I have updated the REG downloads for this. Please try the new ones. They should work for all accounts now.
  3. Posts : 2
    windows7
    Brink said:
    Hello Kenzo, and welcome to Seven Forums.
    Thank you, Brink! You are an absolute gentleman .
    Made my day as resolves a reoccuring security issue a friend is having with her staff and work PC.
    For those interested, the entry now includes:
    [HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Internet Explorer\Control Panel]
    "ConnectionsTab"=dword:00000001.
    Many thanks,
    Ken
  4. Posts : 72,052
    You're most welcome Ken. I'm happy to hear that I was able to help. :)
  5. Posts : 1
    Thank you!
    Thank you so much for this easy steps. It worked fine for me!!
  6. Posts : 72,052
    You're most welcome Angela, and welcome to Seven Forums. :)
  7. Posts : 1
    windows 7 professional 32bit and 64 bit
    I joined to this site just to say thank you for the .reg file! You're a lifesaver for solving a problem we had with windows 7 starter edition.
