Windows 7: Power Plan Settings - Change
15 Apr 2011   #10
Brink
64-bit Windows 10 Pro
Did you already enable hibernate?
15 Apr 2011   #11
GradeAbra
Yes but still no hibernate option.
i followed your tutorial above to turn on the hibernation but it does not seem to appear in the starts menu arrow.. what is wrong here?
15 Apr 2011   #12
Brink
If you mean in the Start Menu, then you will only see Hibernate listed in the Start Menu power button arrow menu unless you have Hybrid turned off in the Advanced Power Plan Options.
15 Apr 2011   #13
GradeAbra
Hybrid is turned on. I guess something must be wrong with it.
Regarding the above setting, so Hibernation is always +5min after hard disk is turned off correct?
16 Apr 2011   #14
Brink
LOL, you have to turn off Hybrid to see Hibernate in the Start Menu.
Hibernate will be after however many minutes you set it to be in your advanced power plan settings.
16 Apr 2011   #15
GradeAbra
oh..., i will try it. By the way if i would like to go into hibernation immediately after i click on the sleep button at the start menu. So what would be the best way to set it?
16 Apr 2011   #16
Brink
If you wanted to go immediately into hibernation, then you could just click on the hibernate option in the Start Menu instead.
16 Apr 2011   #17
GradeAbra
Which do you prefer, Hybrid sleep or Hibernation for your desktop?
16 Apr 2011   #18
Brink
I prefer sleep since I'm always using off and on at all hours of the day and night. This way it starts instantly for me.
It just depends on how and how often you use your computer and what would work best for you though.
18 Apr 2011   #19
GradeAbra
Hi brink,
Isit ok if i set "Turn off Harddisk after.." and "Sleep after.." at the same time? For example 15mins?
What is the different between Sleep and Turn off harddisk actually?
Missing power state controls in advanced power plan settings
Hi guys, I'm new here and this is my first post. I have an Optiplex 745 running Windows 7 Professional. Normally in the advanced setting section of the power plan option I have the option to change the power state, however all of a sudden these options have just totally disappeared. Any help is...
General Discussion
Power plan - do not keep settings!
Hi, I'm running Win7Pro 64bit in a Tecra R840 laptop. My power planning regarding LCD brightness is 40% if running on batery and 100% if plugged in. The problem is that, for some reason, I can't keep these settings and Windows (?) change it to 40% on batery and plugged in. Example: I...
Performance & Maintenance
How can I change power plan and run scripts based on power state?
I overclock my CPU by changing its FSB and I have scheduled (Task Scheduler) this script to run every time I logon to Windows. But I would like to schedule it to downclock when I pull the power cord and then overclock as I plug it back in. Is this possible? It would also be nice if Windows changed...
General Discussion
Power Plan - Create Shortcut to Change Power Plan
How to Create a Shortcut to Change Power Plans in Windows 7 and Windows 8 This tutorial will show you how to create or download shortcuts that will allow you to change or switch to the High Performance, Balanced, Power Saver, or a custom power plan instantly without having to go through Power...
Tutorials
Power Options/Power plan settings?
From Windows 98SE/2000/XP SP3 I always set my power settings as always on/never shut down (hard drive always on) with the exception of turn off display after 10 mins. Both my PCs are on for about 16-20 hrs each day and I always shut them down manually every night. Now in Windows 7, I created a...
