Join Forum
Login
Today's Posts
Tutorials
Vista Forum
Windows 8 Forum
Windows 7 Help Forums
Windows 7 help and support
Tutorials
Windows 7: Power Plan Settings - Change
Page 3 of 4
1
2
3
4
04 Dec 2008
19
Brink
64-bit Windows 7 Ultimate SP1 & Windows 8 Enterprise
Texas
How to Change the Power Plan Settings in Windows 7
Click here to read the entire tutorial
02:45 PM
My System Specs
Intel i7-3930K 3.2 Ghz (O/C 4 Ghz)
ASRock X79 Extreme11
32 GB (8GBx4) G.SKILL DDR3 Quad PC3-19200 2400MHz
Graphics Card
Sapphire HD5870 Eyefinity 6 2GB
SB Recon 3Di Integrated Chip
3x 27" Asus VE278Q
Logitech Cordless Desktop MX 5500 Revolution
OCZ Series Gold OCZZ1000M 1000W
Corsair Hydro H100
256GB OCZ Vector 160GB OCZ RevoDrive X2 2 x 1TB Samsung HDD HD154UI SATA
50 Mb/s Download and 2 Mb/s Upload
Microsoft LifeCam Cinema Lite-On iHBS212 12x BD Writer Samsung CLX-3175FW Printer Netgear WNDR3800 Router Motorola SBG6580 Cable Modem 2x APC Back-UPS XS 1500
Brink
View Public Profile
Find More Posts by Brink
18 Apr 2011
20
Brink
Texas
The
Turn off hard disk after
option is to turn off (spin down) HDDs after X amount of minutes of being idle (unused).
The "Sleep after" option is to put your computer to sleep after X amount of idle minutes.
It would be pointless to have he HDDs turn off at the same time you put the computer to sleep.
Hope this helps.
My System Specs
Graphics Card
3x 27" Asus VE278Q
Corsair Hydro H100
Brink
View Public Profile
18 Apr 2011
21
GradeAbra
So turn off HDD should be after sleep?
My System Specs
Acer eMachines EL1850
Pentium(R) Dual-Core CPU E5800 @ 3.20GHz
eMachines EL1850
4.00 GB
Graphics Card
Intel(R) G41 Express Chipset
1600 x 900 x 32 bits (4294967296 colors) @ 59 Hz
(1) Hitachi HDS721032CLA362 ATA Device (2) Generic- Compact Flash USB Device (3) Multiple Flash Reader USB Device
GradeAbra
View Public Profile
Find More Posts by GradeAbra
18 Apr 2011
22
Brink
Texas
Before sleep if you wanted to.
Can't turn the HDD's off if the computer is already in sleep mode. In sleep mode, the HDD's are turned off by default.
My System Specs
Graphics Card
3x 27" Asus VE278Q
Corsair Hydro H100
Brink
View Public Profile
18 Apr 2011
23
GradeAbra
When i set to default, the HDD is turn off after 20mins but sleep is only after 15mins. I assume that is wrong?
My System Specs
eMachines EL1850
4.00 GB
Graphics Card
GradeAbra
View Public Profile
19 Apr 2011
24
Brink
Texas
It wouldn't work very well for the reason above.
My System Specs
Graphics Card
3x 27" Asus VE278Q
Corsair Hydro H100
Brink
View Public Profile
20 Apr 2011
25
GradeAbra
If i am downloading a large file and left the computer untouched, will the download stop if the computer go into sleep mode or turn hdd off mode? How do i prevent this from happening?
My System Specs
eMachines EL1850
4.00 GB
Graphics Card
GradeAbra
View Public Profile
20 Apr 2011
26
Brink
Texas
The computer and HDD would still be in use while downloading, so the computer wouldn't go into sleep mode.
My System Specs
Graphics Card
3x 27" Asus VE278Q
Corsair Hydro H100
Brink
View Public Profile
10 Mar 2012
27
sasha007
Windows 7 Ultimate 32-bit
Allow hybrid sleep option is not being shown in the power options under sleep option . What to do .???
My System Specs
sasha007
View Public Profile
Find More Posts by sasha007
10 Mar 2012
28
Brink
Texas
Hello Sasha,
You might not have hibernate enabled for hybrid to show up.
Hibernate - Enable or Disable
My System Specs
Graphics Card
3x 27" Asus VE278Q
Corsair Hydro H100
Brink
View Public Profile
10 Mar 2012
29
sasha007
Quote: Originally Posted by
Brink
Hello Sasha,
I always enable hibernate by using the cmd command , but after every 2-3 reboots , hibernate is automatically disabled . Why is this .?
My System Specs
sasha007
View Public Profile
Page 3 of 4
1
2
3
4
Power Plan Settings - Change problems?
Shut Down, Restart, Sleep, and Hibernate Commands - Add or Remove
Local Group Policies - Apply to All Users Except Administrators
Tutorial Tools
Printable Version
Email this Page
Similar help and support threads for: Power Plan Settings - Change
Windows 7 Tutorial
Category
Power Plan - Restore Default Settings
Tutorials
Power Plan - Create Shortcut to Change Power Plan
Tutorials
Power plan settings aren't persistent
General Discussion
Power Options/Power plan settings?
Performance & Maintenance
01:59 PM
Contact Us
Windows 8 Support
Windows Vista Support
Legal
Privacy and cookies
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
