Windows 7: Power Plan Settings - Change
10 Mar 2012   #30
Brink
64-bit Windows 10 Pro
Quote   Quote: Originally Posted by sasha007 View Post
Quote   Quote: Originally Posted by Brink View Post
Hello Sasha,
You might not have hibernate enabled for hybrid to show up.
Hibernate - Enable or Disable
I always enable hibernate by using the cmd command , but after every 2-3 reboots , hibernate is automatically disabled . Why is this .?
Hmm, I've never seen that before. You might see if running a sfc /scannow command may help if it's a corrupted system file at fault. You might also run chkdsk on your Windows 7 drive to see if there may be any HDD corruption that could be messing with the hiberfil.sys file.
06 Mar 2014   #31
maddy530
I think this might be a dumb question, but I would like to know if power options work in safe mode?
06 Mar 2014   #32
Brink
Hello Maddy, and welcome to Seven Forums.
Not a dumb question at all.
Yes, the power options will work in Safe Mode.
Did you have any specific power options in mind though? I'll be happy to test it if you are having an issue with it while in Safe Mode.
Whatever you set and apply in power options while in Safe Mode, does stay set the same while back in normal mode.
03 May 2014   #33
BugMeister
every so often my PC (desktop) stops running..
not sure if this due to an incorrect power setting..
what settings should be applied if one didn't want any sleep or hibernation to occur
and which would therefore allow the PC to run at maximum power and performance at all times..??
03 May 2014   #34
Brink
Hey BugMeister,
You could select to use the "High performance" power plan, and set the "Sleep" -> "Sleep after" and "Hibernate after" options to "Never".
04 May 2014   #35
BugMeister
cheers, Brink
- nice one!!
04 May 2014   #36
Brink
You're welcome.
23 Sep 2014   #37
George C
Windows 7 64 bit
I am running Windows 7 on a desktop and want to change the power level settings to Never switch off the display. I have selected the Balanced plan and changed it to do this but every time I boot up the computer it reverts to the previous settings. I have tried setting up a new custom plan but it still reverts to the Balanced plan when I reboot. How can I get the settings to "stick"?
23 Sep 2014   #38
Brink
Hello George, and welcome to Seven Forums.
Since this is Sony (OEM) computer, Sony most likely has it's own power management software that came preinstalled on the computer that is overriding Windows power settings like this.
If you find this software installed, then you could make the changes in it, or uninstall the software to use only Windows power settings.
Hope this helps for now,
02 Dec 2014   #39
too
Windows 7 x64 Ultimate
I'm having issues with the power plan.
I created an specific power plan, tried to modify an windows power plan, either way, I cannot change the torn off monitor and sleep after features.
Once I reboot the system it changes back to the default values.
I'm doing all this as an administrator.
What can be?
Thank you.
Missing power state controls in advanced power plan settings
Hi guys, I'm new here and this is my first post. I have an Optiplex 745 running Windows 7 Professional. Normally in the advanced setting section of the power plan option I have the option to change the power state, however all of a sudden these options have just totally disappeared. Any help is...
General Discussion
Power plan - do not keep settings!
Hi, I'm running Win7Pro 64bit in a Tecra R840 laptop. My power planning regarding LCD brightness is 40% if running on batery and 100% if plugged in. The problem is that, for some reason, I can't keep these settings and Windows (?) change it to 40% on batery and plugged in. Example: I...
Performance & Maintenance
How can I change power plan and run scripts based on power state?
I overclock my CPU by changing its FSB and I have scheduled (Task Scheduler) this script to run every time I logon to Windows. But I would like to schedule it to downclock when I pull the power cord and then overclock as I plug it back in. Is this possible? It would also be nice if Windows changed...
General Discussion
Power Plan - Create Shortcut to Change Power Plan
How to Create a Shortcut to Change Power Plans in Windows 7 and Windows 8 This tutorial will show you how to create or download shortcuts that will allow you to change or switch to the High Performance, Balanced, Power Saver, or a custom power plan instantly without having to go through Power...
Tutorials
Power Options/Power plan settings?
From Windows 98SE/2000/XP SP3 I always set my power settings as always on/never shut down (hard drive always on) with the exception of turn off display after 10 mins. Both my PCs are on for about 16-20 hrs each day and I always shut them down manually every night. Now in Windows 7, I created a...
