Windows 7: Cross Platform LAN Error Fix
How to Fix LAN Error 0x8007046a between XP and Windows 7 PCs
Published 13 Apr 2010
Featured Tutorial
Driver Install - Device Manager
How to Install a Driver in Device Manager
Dual Boot - Windows 7 and Linux
How to Correctly Setup a Dual Boot with Windows 7 and LinuxMint13
Clean Up Factory Bloatware
Clean Reinstall - Factory OEM Windows 7
How to Clean Reinstall a Factory OEM Windows 7
Troubleshooting Windows 7 Failure to Boot
How to solve "Error 0x8007046a: Not enough server storage is available to process this command"
I ran into this error recently and found the following solved my problem. This may work for other cross platform LAN problems also.
warning   Warning
this involves editing the registry. You should backup your registry before making any changes
1. Click the start orb and type "regedit" in the search box
2. Right-click regedit.exe and "Run as Adminstrator"
3. Advance to
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\LanmanServer\Parameters
4. If IRPStackSize exists in the registry, change it's decimal value to 20 (or more if needed to a max value of 50)
5. If it doesn't exist, create a New DWORD and set it's value as above.
WARNING: You must enter it exactly as IRPStackSize.
6. Still in the registry, advance to the location below and change its value to 1. NOTE: This tells Windows that you want to use this PC as a file server.
HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management\LargeSystemCache
7. Now, advance to the location below and change this value to 3.
HKLM\SYSTEM\CurrentControlSet\Services\LanmanServer\Parameters\Size
Tip   Tip
This should be done on all PCs on the LAN.
8. Reboot all PCs
Need more help? Try searching our extensive help and support site.
Loading
Comment
 Cross Platform LAN Error Fix problems?
Tutorial Tools
Similar help and support threads for: Cross Platform LAN Error Fix
Windows 7 Tutorial Category
Cross-platform Wirenet Trojan targets Mac and Linux users Security News
Cross Platform Trojan steals Linux and Mac OS X passwords... Security News
Playing Cross-Platform games? Gaming
JPG files cross windows 7 to XP platform Music, Pictures & Video
Cross-Platform Boonana Botnet Open for Anyone to Misuse Security News
