Motherboard - Install in a case
  1. Posts : 3,300
    Win7 Home Premium 64x
    The standoffs look like little pegs that have a screw on the bottom and screwhole in the top. They keep the motherboard raised off the case. In your pics you dont need standoffs because each post for the screws are already raised.
    I think for any case that fits multiple form factors (like mATX and ATX) have holes for both and you put the standoffs in the holes that line up for your Motherboard.
    Just thought I would mention it in case someone building a computer is confused. As I was when I had to install standoffs.
    Another thing to mention would be the front panel connectors as this goes from the case to the motherboard. It is different depending on what the front panel has, but sometimes the included instructions are vague.
    Edit: Thanks Sergio
  2. Posts : 3,639
    sergiogarcia9 said:
    Thank you Thorsen
    I dont know about those standoffs tho, i never used them.
    I had to use them with my desktop as well, for the record.
    Nice tutorial though. You has such a prettyful couch!
    These are standoffs, serg.
    25-Brass M3 Standoff Screws-Standoffs Screw Hex Lian Li - eBay (item 350244511877 end time Apr-22-10 11:03:44 PDT)
  3. Posts : 11,990
    Windows 7 Ultimate 32 bit
       #12
    sergiogarcia9 said:
    Added, thanks Thorsen and Carl
    Very good and very nicely done.
  4. Posts : 3,300
    I guess front panel connectors would be in the next Tut on connecting everything. Looks great Sergio
  5. Posts : 4,755
       #14
    Exactly I will make a tutorial on how to connect it all
    DarkNovaGamer said:
    sergiogarcia9 said:
    Thank you Thorsen
    Thanks Steve :)
  6. Posts : 12,177
       #15
    Good job Sergio,
    Looking forward to see the rest of the series.
  7. Posts : 4,755
       #16
    Thanks Dave
  8. Posts : 1,443
    Win 7 Ultimate SP1 x64
       #17
    Good tutorial, pal.
  9. Posts : 4,280
       #18
    Nicely done Sergio. Looking forward to see the final build result. Fabe
  10. Posts : 5
    Windows7x86, Windows7x64, Mac OS X 10.6.3 Snow Leopard
       #19
    I installed my brand new Gigabyte GA-G41M-COMBO and ASUS EAV-5570 graphics card for with my brother for 3 hours.... Had to reinstall windows
