Windows Experience Index - Reset
Page 2 of 2 FirstFirst 12
  1. Posts : 1,002
    XP Pro (x86) | 7 HP (x86) & (x64) | 7 Pro (x64)
    Why do we need WEI ?
    I assume gamers might need WEI info ... but for us wrinkled-lizards-in-the-sun , do we really need WEI ?
    Correct me if I am wrong ...
    - WEI is almost non-existent in Win-8.1 (requires 3rd party app -OR- a cmd, to read WEI) ... and abandoned by MS in Win 10 ?
    - I disabled WEI in my first Win7 PC a Toshiba laptop.
    Is WEI always being recalculated or is it a one-off assessment ?
    - in this answers.microsoft.com thread it appears WEI is most valuable in evaluating new PCs ... ?
    - and some confusion by many
    If I run the elevated command
    winsat formal -restart
    ... will that reset WEI to be perpetually running (if that is what it does) ?
  2. Posts : 72,037
    It's not that you need it, but just another tool. :)
    The Windows Experience Index is a basic measurement that tells you how well your PC works with Windows and uses a base score to rate the experience you can expect.
    Windows Experience Index - Update or Refresh Score
    Engineering the Windows 7 ?Windows Experience Index? - Engineering Windows 7 - Site Home - MSDN Blogs
  3. Posts : 1,002
       #12
    Thanks Shawn for a lightning quick response :)
    You were too quick for me while I edited my post to add "stuff"
    I notice my WEI page in Control Panel has values. Would they be correct with WEI disabled.
  4. Posts : 72,037
    No problem.
    Sorry for the late reply now. I was heading off to sleep for a bit when I answered last.
    If you disable WEI, then the score your see most likely would not be up to date.
    That command would just rerun all assessments for WEI. See OPTION TWO below for more on this. :)
    Windows Experience Index - Update or Refresh WEI Score in Windows 8
