Graphics Card - Overclock
Page 3 of 4 FirstFirst 1234 LastLast
  1. Posts : 6,885
       #20
    I do not have a 5770
    ~Lordbob
  2. Posts : 177
    ~Lordbob
    I have also used them to overclock my own cards (a GeForce 9500GT, ATI HD5770, and GeForce 260).
    Didn't you oc a 5770?
  3. Posts : 6,885
       #22
    GlobesStudios said:
    ~Lordbob
    Yes, but I returned it due to disgust with ATI's drivers.
    ~Lordbob
  4. Posts : 177
    Lordbob75 said:
    GlobesStudios said:
    ~Lordbob
    ~Lordbob
    I OC'd using MSI afterburner should I apply the new settings through ccc?
    or do i have to have msi afterburner run on startup for my oc to apply?
    what is the advantages of using ccc or msi ?
  5. Posts : 6,885
       #24
    ~Lordbob
    MSI Afterburner is definitely a better program. I don't know if it is required to start up at startup to keep the OC, but I don't think so.
    ~Lordbob
  6. Posts : 12,177
       #25
    Don't need MSI Afterburner to run, the card will keep the OC.
  7. Posts : 6,885
       #26
    Thanks for clarification.
    ~Lordbob
  8. Posts : 12,177
       #27
    You're welcome.
    I use MSI Afterburner to OC my graphics card and have never had it leave it running or re-start it, CCC shows the settings that I set with MSI A.
  9. Posts : 25,847
       #28
    Excellent work. I'm running FurMark at this time.
    GPU-1
    Core: 870 MHz, mem: 1846, temp: 69 c
    Fan 77% auto
    GPU8 load 99%, mem: load 11%
    Gpu volts: 1.000
    ___________________________________
    Does anybody have any suggestion for settings? Please see my specs.
  10. Posts : 353
    Windows 7 Ultimate
       #29
    What are the benefits of OC'ing your gpu?
