Shortcut Extension - Remove or Restore
How to Remove or Restore the "Shortcut" Name Extension in Windows 7 and Windows 8
This tutorial will show you how to remove or restore the "- Shortcut" extension from a shortcut file name when any new shortcut is created in Windows 7 and Windows 8.
   Warning
This will only remove or restore the "shortcut" name extension for newly created shortcuts afterwards, not for previously existing shortcuts.
EXAMPLE: A New Folder with the New Folder Shortcut
NOTE: When you create a new shortcut or New Folder, by default, it will add the Shortcut extenstion to the file name. The last icon is an example of when you create a shortcut of New Folder with the Shortcut extension set to be removed.
OPTION ONE
To Add or Remove "Shortcut" Name Extension using a REG File
1. To Remove the Shortcut Extension
A) Click/tap on the Download button below to download the file below, and go to step 3 below.
Remove_Shortcut_Extension.reg
Download
2. To Restore the Shortcut Extension
Restore_Shortcut_Extension.reg
Download
4. Double click/tap on the extracted .reg file to merge it.
5. Click/tap on Run, Yes (UAC), Yes, and OK when prompted.
6. Log off and log on, or restart the computer to apply.
7. When done, you can delete the downloaded .reg file if you like.
OPTION TWO
To Add or Remove "Shortcut" Name Extension in Registry Editor
1. Press the Windows + R keys to open the Run dialog, type regedit, and press Enter.
2. If prompted by UAC, click/tap on Yes.
3. In the registry, go to: (See screenshot below)
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer
4. In the right pane of Explorer, double click/tap on link to modify it. (See screenshot above)
5. To Remove the Shortcut Extension
A) Change the value to 00 00 00 00 and click/tap on OK, and go to step 7 below. (See screenshot below)
NOTE: To change the value, press the Delete (Del) key once and type 00.
B) Go to step 7.
6. To Restore the Shortcut Extension
A) Change the value to 1E 00 00 00 and click/tap on OK, and go to step 7 below. (See screenshots below)
NOTE: To change the value, press the Delete (Del) key once and type 1E.
7. Close regedit.
8. Log off and log on, or restart the computer to apply changes.
beta 7000 doesnt seem to add "shortcut".
Windows 7 Professional 64-bitIntel E8400 3GHzKingston PC3-10700H 4GbXFX Radeon HD 5850 BlackEd.
self built
Intel E8400 3GHz
Intel DX48BT2
Asus Xonar DG
2x Samsung SM-T220HD 22"
1680x1050 on two monitors
OCZ Vertex 2 120gb 3.5" (OS)
Seagate Momentus XT 500gb
Samsung F3 1Tb (games)
2x Samsung F1 1Tb
Thermaltake ToughPower 850w
Thermaltake Armor
Scythe Mugen II
Microsoft Comfort Curve USB
Razer Diamondback 3G
Are you sure!!
Windows 7 Ultimate Vista Ultimate x64Core 2 Duo E8500 3.16Ghz @ 3.8Ghz2x2Gigs Patriot PC2-6400 LLInno3D GeForce GTX260 216 SP
Home Brew
eVGA 750i FTW
SATA 150GB
SATA II 250GB
USB IDE 750GB Ext.
Liquid Cooling System
Logitech G15 Gaming Keyboard
Logitech G9 Gaming Mouse
Hi Swarfega,
I must agree with Mr GRiM. The Windows 7 Beta (7000 build) show the "Shortcut" prefix for me still when I create one from a New Folder on the desktop.
Is there an easy way to remove the shortcut overlay? Besides third party apps, I never found a "windows" way to remove them.
Systems by SmartEyeball
8 Pro x64
i7 3770K 4.6GHz
ASUS P8Z77 WS
x3 Dell U2410 / 58" Samsung
5760*1200/ 1920*1200
Noctua NH-D14
IE, FF, WaterFox
Bloody Big Grin
Closest I came to that was this reg hack with a blank .ico. Works for me as it did in Vista. Read the readme so you know which to use (for 32 or 64 bits). Got it on Neowin a long time ago.
Win7 x64 Ultimate RTMIntel i7 920G.SKILL 6GB DDR3 1333VisionTek ATI 4870 512 x2 (Crossfire)
Home Made / Numero Uno
Intel i7 920
Gigabyte GA-EX58-UD4P
Onboard Realtek HD
HP W2408 24 inch
1920x1200
WD VelociRaptor x2 (Raid 0)
Western Digital Caviar Black WD1001FALS 1TB (2 partitions)
KINGWIN Mach 1 1000w
Antec 900
Air - Coolmaster V8 CPU Heatsink
Microsoft Basic (love it)
Logitech 518
Not as fast as I would like
Smarty,
The only safe and easy way I know is with a 3rd party app as well. The other methods usually messed up the shortcut icons. I have not tried this in Windows 7 yet, but I see no reason why it wouldn't work though.
Shortcut Arrow - Vista Forums
VegasDen,
THe link you link you posted comes back as invalid. :(
Home Brew
eVGA 750i FTW
SATA 150GB
SATA II 250GB
USB IDE 750GB Ext.
Thank you Mr GRiM.
does this just work for folders? i still have the arrow overlay on my shortcuts i have sent to the desktop.
Windows 7 RC Build 7100 x86 / Windows Vista SP2Intel Core2Duo E84003 Gigs DDR2 6400Asus NVIDIA GeForce 9500 GT 512MB
Internet-Junkie
Asus Rampage Formula
3 Gigs DDR2 6400
Sound Blaster FX Extreme Audio PCI-E
Sceptre X22WG Gamer 22" 1080p Widescreen LCD
1680 x 1050 32bit
OCZ 64gig SSD Western Digital 300gig VelociRaptor 10,000RPM
Two Seagate Barracuda 320gig 7200RPM
700 Watt
U2-UFO Black Powder Coat - Solid Top www.mountainmods.com
Ultra ChillTech Thermo Electric Cooler/7 120mm 2500RMP Fans
Logitech diNOVO Edge
Logitech LX 8 Cordless Laser Mouse
7 MBPS Down / 784KBPS Up
Hauppauge WinTV HVR-1800 Dual Tuner
shortcut arrow is gone
i lied. i guess it just took a couple of restarts for some reason. thanks for the download. i have always disliked the arrow overlay. i do not need an arrow to tell me the icon is a shortcut. thanks again.:D
Internet-Junkie
3 Gigs DDR2 6400
1680 x 1050 32bit
700 Watt
LOL, you're welcome System001. :)
Help, after applying shortcut remover in Windows 7 the shortcut overlay displays a small black square where the shortcut arrow was previously. How do I fix this? Thanks!
Windows 7 HP 64bit
Windows 7 HP 64bit
Thanks for the help. I used the tutorial and after a couple of reboots the icons are back to normal.
Windows 7 HP 64bit
Windows 7 HP 64bit
You're welcome Kelly. I'm happy to hear that you got it sorted. :)
Perfect! Thanks a lot!
Windows 7 Ultimate x64Intel Core I5 750 @ 2.67 GHzDDR3 10GBATI Radeon HD 4350
Dell Vostro 430
Dell Inc. 054KM3
DDR3 10GB
ATI Radeon HD 4350
Dell S2740L, Vizio SV470XVT1A
1920X1080, 1920X1080
Western Digital Caviar Black WD5003AZEX, Seagate Barracuda ST31500341AS
50 Mbps
