#20
One other question: when I resize the Virtual PC window with the VM it seems to login again. It prompts me for the credentials again. This is somewhat anoying..
So, when I go to full screen or when I just increase the size of the window a little bit. I have only tested this with XPM, it might not be the case with another OS in Virtual PC Beta.
Have you guys got the same?
See if restarting the computer may help with that. After I had restarted, my Vista VM had changed the way it shutdown to what is in the tutorial now.
Is it possible to run a virtual machine created with VPC 2007 in this new beta? The vmc file extension is not associated with the new version and I can't find any other way to try to open it aside from changing the file extension to vmcx. When I do that and double-click the file, it says:
"Could not register the virtual machine. The virtual machine could not be registered because the configuration file does not exist. You should create a new configuration file for the virtual machine."
The new VPC beta forced me to uninstall VPC 2007 so why would it take away the ability to open VMs created with VPC 2007?
Hello Throwman, and welcome to Seven Forums.
I have not tested it yet, but you should be able to use any VHD file. When you get to step 6 of this tutorial, select (dot) Use an existing virtual hard disk instead and browse to and select the VHD file.
i cant find the vpcwizard :/ idk what build im running i disabled the water mark and cant remember how to check
