How to Use a Batch File to Create a Command Prompt Menu to Execute Commands
This tutorial shows the process one goes through when creating a batch file that opens a command prompt menu allowing you to launch commands, programs and more.
I will only be executing programs in this tutorial,...
the thread that i made previously only got 1 answer that really didnt have anything to do with my problem so thought it would be ok if another one was made, and not trying to spam, here are the commands for the batch file
netstop sppvc
cd...
Good day, afternoon, night.
As the title explains I was trying to create a new primary partition in my Hard Disk Samsung HM500JI that I use as External Disk with an Acteck Enclosure USB 2.0 and with DISKPART I selected the Small Partition recently created and used the command "clean" (thinking...
Hello Everyone,
I want to create a utility software where i can create my own custom commands like copy, rename, move, delete etc. But i don't have any idea how should i proceed so please help me in this regard that how should i proceed further.
Which language i should use to create it?
OS...
Okay im trying to make a mini-fool for my friend :D
And i want to my friend donot see the bat file
Is this the code to he cant see it?
attrib +h %0
Thanks.
- kuchiyo
