Quick Launch - Enable or Disable
Page 34 of 39 FirstFirst ... 243233343536 ... LastLast
  1. Posts : 24,479
    Windows 7 Ultimate X64 SP1
       #330
    Brink said:
    Garry,
    I don't see them either. Are you sure that you have the option unchecked to have the taskbar unlocked?
    If so, try the other options below as well to see if one of them may unlock it to show the dotted separator lines.
    Taskbar - Lock or Unlock
    Yessir, I'll have a look at your link tomorrow. :)
  2. Posts : 41
    Windows 7 x64 Ultimate English + language kits
       #331
    I attached mine with the dots on each side of the Quicklaunch bar for reference.
    There should be no checkmark in the space in front of "Lock the taskbar" in the context menu.
    The screenshot shows how it appears, and in red, how it should not appear if it's unlocked.
    Regardless of the appearance, can you grab and move the toolbars around as described in the tutorial?
    Edit: Sim posts! ^-^
    Attached Thumbnails Attached Thumbnails Quick Launch - Enable or Disable-dots.png
  3. Posts : 24,479
       #332
    Tried all the options including the registry add, still no dotted lines, so there is no place to grab.
  4. Posts : 72,091
       #333
    Gary,
    Strange.
    Did you restart the computer after merging the REG file in Option Three?
    Did you or any installed programs may have applied any tweaks that may have affected the taskbar?
    You might see if running a sfc /scannow command may help. If this only start recently not having the dotted line, then you might consider doing a system restore using a restore point dated before this started.
  5. Posts : 41
       #334
  6. Posts : 24,479
       #335
    Shawn, Chimel I have it figured out. When I Add a new tool bar then the dotted lines appear when unlocked. I don't have a Quick Launch tool bar but pinned items to the task bar.
  7. Posts : 72,091
       #336
    LOL, mystery solved.
  8. Posts : 1
    Windows 7 Home Premium
       #337
    Thank you!!
    I appreciate the time you took to get this up here, you saved me a lot of time and agony.
    Cheers,
    Luke
  9. Posts : 72,091
       #338
    You're most welcome Luke, and welcome to Seven Forums. :)
  10. Posts : 72
    Windows 7 Ultimate 64 Bit Sp1
       #339
    From where i can download the reg file for it can you give me the link for it mate appreciate it
