Quick Launch - Enable or Disable
Page 12 of 39 FirstFirst ... 2101112131422 ... LastLast
  1. Posts : 13
    Windows 7 Ultimate (64-bit)
       #110
    Kika said:
    Thanks for this great tutorial :) But does anyone know how to add "send to quick launch" under mouse right-click when clicking on file? Must be some registry setting I guess.
    This works in Win 7 also:
    Send To Context Menu - Vista Forums
  2. Posts : 8
    windows 7
       #111
    i had proprem with QL: i had add QL for taskbar but i can't see it when i reset PC!!!Why!!thanks
    Sorry My English is not good.
  3. Posts : 72,055
       #112
    Hello Erosvn, and welcome to Seven Forums.
    Did you do a clean install (format) of Windows 7, or upgraded Vista to Windows 7. If you upgraded, then it may be remnants of Vista messing it up.
  4. Posts : 8
    windows 7
       #113
    thanks Brink. no i didn't upgraded vista to windows 7!! i instal win7 pro!!!
  5. Posts : 72,055
       #114
    Erosvn,
    You might see if doing a repair install can fix this for you.
  6. Posts : 8
    windows 7
       #115
    Brink said:
    Erosvn,
    ok thanks Brink :)
  7. Posts : 4
    Windows XP Pro and Windows 7
       #116
    I got the quicklaunch to add to the taskbar fine, I'm trying to find a way to automate that without having to go through the steps, like say put this in a troubleshooting pack. I'm curious if there are any registry settings tieing the quicklaunch to the taskbar?
  8. Posts : 72,055
       #117
    Hello Brambo,
    That would be an interesting approach, but I have not found any registry entries tying QL to the taskbar like that yet. Please post back if you do find a way though. It would make a good tutorial for you. :)
  9. Posts : 381
    Windows 7 Ultimate x64 | Windows XP Pro x86 | Windows Vista Ultimate x86
       #118
    Thanks a lot. Gives me the feel of XP on 7. It's a nice feeling.
  10. Posts : 72,055
       #119
    You're welcome Nikolay. :)
