How to Create a "Personalization" Shortcut in Windows 7 and Windows 8
This tutorial will show you how to create or download a Personalization shortcut that opens directly to the Personalization window to change the visuals and sounds settings in Windows 7 and Windows 8.
The
Windows 7 Starter and
Home Basic editions do not have the personalization feature included in them. This shortcut will open
Windows Color and Appearance instead in the these two editions.
EXAMPLE: Personalization
OPTION ONE
To Download a "Personalization" Shortcut
1. Click/tap on the Download button below to download the file below.
Personalization.zip
2. Save the .zip file to your desktop.
3. Open the .zip file and extract the Personalization shortcut to the desktop
4. Unblock the
Personalization shortcut. (See screenshot below)
5. In
Windows 7, you can now
Pin to Taskbar or
Pin to Start Menu, add to
Quick Launch,
assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
6. In
Windows 8, you can
Pin to Taskbar on desktop,
Pin to Start screen, add to
Quick Launch,
7. When done, you can delete the downloaded .zip file on the desktop if you like, or save it to use again.
OPTION TWO
To Manually Create a "Personalization" Shortcut
1. Right click on a empty area on desktop, and click/tap on
New and
Shortcut.
2. Copy and paste the command below into the location area, and click/tap on the
Next button. (See screenshot below)
rundll32.exe shell32.dll,Control_RunDLL desk.cpl,,2
3. Type
Personalization for the name, and click/tap on the
Finish button. (See screenshot below)
4. Right click on the new
Personalization shortcut on the Desktop, and click/tap on
Properties.
5. Click on the
Shortcut tab, then click/tap on the
Change Icon button. (See screenshot below)
6. In the line under "Look for icons in this file", copy and paste the location below, and press
Enter. (See screenshot below)
%windir%\System32\themecpl.dll
7. Select the icon highlighted in blue above, and click/tap on
OK. (See screenshot above)
NOTE: You can use any icon that you would like instead though.
8. Click/tap on
OK. (See screenshot below)
9. In
Pin to Taskbar or
Quick Launch,
10. In
Windows 8, you can
Quick Launch,
